Keeve's Lowstyle S13
Thread in 'Project Cars and Builds Threads' started by prblmslvrs, Jun 5, 2015.
  1. prblmslvrs
    prblmslvrs Active Member
    Inverness/London
    Was up for a wedding at the weekend and did what I think is a pretty polarising move.
    79184A5F-3A67-4A49-8382-5F94F8874105.
    Plan was to replace it with a really light blue so it gave it an OEM look but the 70% VLT that came from China was grey/smoked not blue and I fucks with the car so much more with no tint so it’s gone. Surprised I left it on for so long (3 years) when I look at photos of it now I think it looked SO pish haha.
    F74E7BDC-E97D-4729-883D-5B69B761CF3B.
    DC150A42-A2CB-47E5-9851-CDF338672428.
    5EC4B619-C23B-41E1-B796-477F7D956605.
    Also started fitting the Brix using an old seat rail. All bolted up in the rear but I need to weld in an extra piece on the front section of rail since it dips down.
    CA6F74B0-BB2D-4C6F-A1BE-69BD642DCA85.
    Finally here’s a couple more photos that have arrived from STL4 from a comfortable photographer.
    9D93880B-942B-4DAB-B960-37DAFE28AE6D.
    5557E330-CA84-4970-B88E-7B93969CC54B.
    DA721435-7014-4685-81EC-9C733C2CB032.
    9A6BB398-A6DF-4B35-8944-77B5EDC9DACD.
    F33E8843-B789-4553-8B6C-DE0BF6C0381C.
    Proper excited now to get it all sorted with more power for a couple events this year. Hoping to get to three events this year now my work is a bit more flexible I shouldn’t have to burn holidays to do events even when they’re at the weekend.
  2. StuartyAlec
    StuartyAlec New Member
    Inverness
    Really cool thread mate.
    I remember seeing this car in various stages when I worked at Capgemini in the car park and always wondered who owned it (and I secretly wanted it)!
    Good to see she is still being loved after all these years xD
  3. prblmslvrs
    Inverness/London
    Haha thanks mate, it's changed a lot since then.
  4. prblmslvrs
    Inverness/London
    Managed to get up the road to do some schassis matsuri preparation. Unfortunately after stockpiling everything I needed to get up the road and fit my TD05 we ran into a problem with modifying the manifold so I had to switch gears and just do all round maintenance.
    So first off was the intercooler swap. I’ve been running solid up headlights since the car was MOT’d because I hated pig nose bumpers with headlights down. Obviously I now have a kouki bumper but my bodged mid mount stops me from getting my headlights down. Picked up an intercooler from Dan Joyce that already had two 90* bends already welded into it (I also had bought two 90* bends to weld in but never had the time to pull the IC and get someone to do it).
    IMG_6536 copy.
    Got it fitted and had to trim my headlight brackets a bit more but was able to get them down fully in the end.
    IMG_6542 copy.
    Obviously since I had a new intercooler with different entry/exit points I’ve had to re-do the boost pipes. I decided instead of doing my hack flare with mole grips I should make a diy boost pipe beader. I welded an old alternator bracket and exhaust clamp into to a pair of mole grips. Tested on some offcuts and worked well.
    IMG_6538 copy.
    Then I started trying to bead a slightly thicker bit of boost pipe so stuck it in a vice to help with the clamping power....
    IMG_6539 copy.
    turns out that half of the boost pipes were stainless and I killed the beader before I got started with it haha. Went back to flaring with mole grips and got it all bolted up. Boost leak tested to 2 bar so at least it works.
    IMG_6541 copy.
    I also bought an adjustable actuator as I was suspicious that my t25g isn’t boosting properly. It was bullshit and pish and I didn’t even fit it. Put on the actuator that came with my t25g (I had on a t28r actuator) and it seems to take a fair bit more pressure before opening so hopefully the turbo will hold boost a bit longer before tailing off.
    My bay is a total state from driftland pits. I need to give it a clean but don’t have the time, and it will just get clarted again the next time it’s driven.
    Talking of the pits being a state I cleaned out my Apexi filter which was fucked. Had compressed air on it and wasn’t really feeling it from the inside out in my hand. Gave it a good going over and finally my hand was able to feel the air rushing through. Poor wee bugger must have been horrifically choked up.
    IMG_6545 copy.
    Also realised that since I did the tubs there’s no fresh air actually getting to the filter and it’s just getting hot bay air. Bought a 3” piece of silicone ducting and drilled out a 3”(ish) hole to feed it to. - I fucking hated this job and have no idea how I didn’t find it so bad doing my loom relocation. Next time I’m paying for a metal hole cutter even if it’s for one job.
    IMG_6544 copy.
    Jammed the duct into the hole then ran the other end to my bumper and trimmed to fit.
    IMG_6555 copy.
    So for the first time in years I was able to get my lights down.
    IMG_6547 copy. IMG_6551 copy. IMG_6552 copy.
    Annoyingly the OS headlight cover was too low.
    IMG_6543 copy.
    I’ve never wanted to adjust them because I snapped two heads previously and naturally expected the other two to snap but went for it.
    IMG_6556 copy.
    Yeah you guessed it. Snapped. Drilled and trapped, raised the headlight cover but it was still too low. Bent the bonnet. Sorted.
    I also got a GKTech cooling panel to try and help the car run a bit cooler. I’ve added a universal overflow tank with a hole drilled in it to vent. I used to just let it pish water out and then when the windscreen got misted I knew it was time to stop (instead of ignoring the beeping defi) Going to do a coolant flush as well because the coolant will be pretty diluted by now and overdue a change.
    IMG_6598.
    Another thing I’ve been wanting to do for some time was sort out my interior. I’ve seen a few nice 180’s and 240’s pop up with nice interiors so the motivation was finally there to do something about it. I had been trying to figure out what pattern I’d go for but since deciding I was returning door cards I knew I was doing Harris tweed with the Harris tweed labels. Annoyingly when my fabric arrived I ended up with the massive labels so I need to get some more.
    IMG_6526 2.
    Started by lifting the original fabric and got some black vinyl underneath.
    I was thinking about retrimming this but thought it’d be best to get rid and stick directly to the doorcard, so cut the vinyl off and was left with this.
    IMG_6527 2.
    At this point I’d cut fabric to roughly the right shape and just stuck it down with some pretty aggressive spray glue.
    IMG_6560 copy.
    Finally went round the extra fabric with a Stanley in the fabric well and looks pretty good!
    IMG_6564 copy.
    IMG_6566 copy.
    Chucked it back on to admire my work.
    Got my old dear to whip out the sewing machine to do the gearstick gaitor and I followed the same process as the doorcards for the glovebox.
    IMG_6578 copy.
    IMG_6531 copy.
    Next up was dealing with my doorbars since one is black and the other is just raw and has been making a mess of my new brix and doorcard.
    IMG_6577 copy.
    No point taking photos as I’m sure everyone knows how to paint something from bare metal.
    IMG_6604 copy.
    IMG_6605 copy. IMG_6606 copy.
    Finished article of the interior. I’ve got some rear 1/4 panels and a bench to add in also but the car leaks water so going to wait til that’s sorted.
    So as part of “make my car not slow as shit” I was going to re-do my rear alignment after having some dodgy drift days with fucked alignment.
    Started by pulling my traction arms off to free them up and set them.
    IMG_6581 copy.
    Looks like someone has used them to change toe. No wonder the car had fuck all rear grip.
    At this point though I was running out of time for everything I had to do in two days so instead of doing the full setting I just chucked them to +22mm as I heard the figure someone with a low car said at some point. Them being even will be a good start anyway.
    Removed all arms and freed them all off ready to do an alignment. One of the camber arms was fully fucked though so I had to revert to a spare I had.
    Run a plumb line (golf tee taped to some other golf marker my old boy gave me) and got a centre line before setting toe on one wheel with it, then I got the toe plates out and evened up the other side before adding toe in.
    IMG_6580 copy.
    I picked up an HKS Hi-silent exhaust for quietening down my exhaust for when I go to the Greddy Wastegate.
    IMG_6591 copy.
    Only problem was it was for an s15 so some modification was needed. I cut up an old japspeed backbox I used for MOT’s and welded the backbox onto it.
    IMG_6595 copy.
    Managed to impress myself by nailing the location of it with the first tacks off the car after figuring out the rough location for it. I also ran round the other sections of exhaust patching holes that have come up since the last time I had the welder and stainless out.
    IMG_6530 copy.
    • Winner Winner x 1
  5. prblmslvrs
    Inverness/London
    Hit the limit for photos in the last post so here is a dump from when I was finished. Headlights aren't fixed in place yet, I had plans to make a motor relocation but ran out of time and it wasn't as simple as I had initially thought. Got all materials ready though so next time. I also destickered my rear 1/4 windows and like it so much more. I need to remove all of the tint gunk and I might even put on my road legal light blue tint to see how it looks.
    Also all these photos are the bumper just resting in place, I don't bother cable tying it on because it has to come off to get on the trailer anyway.
    IMG_6608 copy. IMG_6610 copy. IMG_6611 copy. IMG_6612 copy. IMG_6614 copy. IMG_6615 copy. IMG_6616 copy.
    I need to bend this bit of the bonnet too it seems.
    IMG_6617 copy. IMG_6620 copy.
  6. nissanr34cal
    mundford, norfolk
    Great work keeve.
  7. Simon998
    Simon998 Member
    Jesus, what I wouldn't give to own this and be able to daily it that low on our shite roads. Looks amazing man, love it with the headlights down.
  8. prblmslvrs
    Inverness/London
    Cheers Cal, just a shame it wasn't fitting a Greddy turbo.
    Thanks mate. For the headlights I'm in the same boat as removing the tint, wish I did it ages ago...
    To be honest the state of the roads don't matter as long as you've taken measures to trust the cars not going to die when you hit a pothole/bump in the road. I've followed some people weaving about all over the roads avoiding potholes, going super slow over the tiniest bumps and shit and I've just stuck course and trusted the car would take it. My Chassis rails and tension arm brackets are absolutely hammered but its been fine. Although the exhaust used to fall off regularly but that's because I hadn't perfected how to get it tucked properly
    Proof of daily duties.
    Untitled.
  9. BenRice
    BenRice Well-Known Member
    New Zealand
    Dude, that interior update has me fizzing for retrimming my door cards & glove box. That colour combo fits perfectly with the rest of the interior
  10. prblmslvrs
    Inverness/London
    So I've started to make a blog with all my lessons learned from building this car. I've wanted to re-visit my build thread for a while since its at 16 pages over 5 years and I thought it's worth re-scoping it in such a way that when I tried to fix my exhaust in 2016, I'm also giving the definitive "This is what I did over 4 years of trial and error to get it reliable".
    https://highlandsports.wixsite.com/highlandsports
    Current topics posted that will be useful for others: Driveshafts, Exhaust, Front Wiring looms.
    Happy to have a discussion about anything posted. This is by no means definitive and if you have a differing opinion you're not wrong, everything I've posted is my first hand experience. I'm trying to steer clear of any second hand info and if I do provide any, I'm going to be clear that its not something I have experience with (I see far too much 2nd hand info on Facebook)
    • Like Like x 2
  11. Sammyboi
    Sammyboi New Member
    Finland
    This has so much truth and wisdom in it.
    So much of throwing 2 second solutions without proper thought and work gone into it, to actually help someone manage their problem.
    I freaking hate Facebook Tip sections and have started to do the same as you, with my own topic for my JZX100. So much shit has happened over the course of 5+ years. All the good and bad, tricks of the trade are what people need to see instead of just fame posting shiny bit installs for likes without proper context. Long live the Forums, eh?
    There is always a risk of being wrong, but at least it's well thought out instead of just blurting it out. Definitely following and great work so far, even though i'd be scared to shit, if i had my car as low as yours. :D
  12. jimycrimson
    jimycrimson Member
    Spain
    What spoiler is it? I love that build! <3
  13. Gooly
    Gooly Member
    london
    Glad to see this is still going, sick car
