Knocking noise when i shift from 1st to 2nd
Thread in 'Technical Questions' started by alecsilvia, Oct 11, 2012.
  1. alecsilvia
    alecsilvia New Member
    Hey guys:) I have a 1992 240sx s13 coupe with a welded diff(soon going to switch to vlsd) I noticed when i shift my car from 1st to 2nd it makes a pretty obvious knocking noise. I really want to know whats the problem, it's been killing me! I hope you guys have some feed back!
  2. Mitch
    Mitch In moderation
    Have you checked for;
    Loose gearbox crossmember mounting bolts and the 12mm ones on the gearbox mount
    Worn rear subframe bushes
    Worn Propshaft
    Worn Driveshafts
    Worn Diff?
  3. kam
    kam I've touched Chris Parry
    Mitch is right :) Add to the list engine mounts, IC and pipework, suspension arms.....
    The list goes on. Get under the car and shake the shit out of everything, starting at your engine and working back.
