L reg S13 Breaking in bedfordshire
Thread in 'Parts for sale' started by valman, Jun 16, 2013.
  1. valman
    valman Member
    hello, got an s13 thats being broken for parts, shell is very rotten :(
    please ask if you require anything. have all of the bodywork available. engine, stage 2 ecu, HSDs have been sold. HKS NUR exhaust (crazy sound) Pair of Rota Drifts with nearly Brand new maxxis MAz1 victra tyres. lots more bits available too,will post up pics as they are all removed.
    thanks!
  2. deadringer247
    deadringer247 Member
    You have pm........
  3. Spanair
    Spanair Member
    Enfield, Middlesex
    Pm me your number bud, after a couple of bits and im heading up there for jap show in 2 weeks so could collect it then. Thanks.
  4. valman
    valman Member
    everyone replied to, specific pictures can be text to mobiles for ease of faffing with photobucket. thanks!
  5. Spanair
    Spanair Member
    Enfield, Middlesex
    Cheers buddy!
  6. valman
    valman Member
    got the following bits,sensible offers on all parts accepted as sets or on their own:
    front bumper with questionable air flow mod (needs the metal panel behind cutting through to be functional) this can be done if so desired by me,alternatively cover it up with a number plate like the previous owner did!
    rear light reflector unit
    complete rear light set.can be sold individually or as a whole
    rear underlight panel.pretty mint no dents or rust
    BMC carbon fibre air filter (not sure if an effect? looks legit though) bolted straight to AMF sensor
    driver's side flip light complete assembly with bulbs and motor
    the plastic light surround has been painted white but its cracking off in places
    passenger side flip light, same as above
    flaking more evident on this light
    Drivers side front wing, bit bubbly where the spats/side trim mounts but not rotten. bit bubbly on the arch lip but solid.bottom mounts behind the wheel have been cut off as they were rusty,wont affect mounting. has a slight dent from another wing falling on it,
    As new Rota Grids, as new-no marks. 16x8j et20 offset 4x114.3 PCD maxxis maz1 victra tires fitted,only covered 400 miles.
  7. valman
    valman Member
    passenger sidefront wing,more rusty than the drivers side (pictured) again, mounts for the plastic spats arent affected and would cover this up... lightweight version?
    plastic lower trim that goes on the bottom of front wings
    rear bumper in white,could do with a rubdown and respray due to paint flacking off (pictured)
    Blitz Nur spec stainless exhaust, cat back
    bit scratched on the bottom - was fitted to a lowered car so caught the floor now and then, no leaks or anything of the like very nice sound.comes with a baffle that goes in the back box too
    118mm exit pipe
    3" system all the way through
    shown here with decat/turbo back pipe
    more pics to come as bits removed. brakes etc all available.
    Diff too - currently open, but will be plating it and welding it
    subframes etc
    cheers!
    #7 valman, Jun 16, 2013
  8. valman
    valman Member
    got a radiator too,bit tatty but no leaks - 10er for it if anyone needs
  9. valman
    valman Member
    power steering pump, reservoir, rack and lines all available
    ABS unit complete with control box and brackets
    wiper motor
    Set of APEX lowering springs.£30 with free mismatched dampers lol. only fronts pictured.
    standard(ithink) ARB 1 inch diameter
    other things available that ive removed but no pics -
    Engine loom (ECU - sensors, coils etc)
    Dashboard in black good condition
    set of clocks, painted silver complete with surround
    Sendai 4x45watt headunit £20
    heater control panels
    pair of mint doors (no rust or dents), come with glass and door cards
  10. Spence
    Spence Active Member
    Gillingham, Dorset
    How much would you want for front struts, all arms and hubs etc?
  11. valman
    valman Member
    make us an offer mate,, dont expect alot for those bits, cheers
  12. valman
    valman Member
    my pm box is full, sorry if ive not replied been doing vlong shifts at work. i cant clear it out till later tonight.
  13. kmck
    kmck Member
    Glasow
    are you sending me the pictures mate ?
  14. db1
    db1 Member
    Sunny Norwich
    Hi I'm after a temperature sender from a ca or sr motor.
    It's the little dash sender next to the coolant exit pipe (11mm hex shape nut on the bottom) if you can help?
    Ill gladly make it worth your time/postage costs
  15. valman
    valman Member
    yes kmck, ive lost the pm with your number on ill empty my pm box tonight and send you some across
    and ill have a look for you db1
  16. valman
    valman Member
    bump, pm box now empty
  17. Spence
    Gillingham, Dorset
    Have you got pics of the bits I want?
  18. valman
    valman Member
    bump!! lots still available,
    -gearbox
    -diff
    -prop, rear subframe
    - Blitz nur spec exhaust full system withdecat.
    -generic 3" exhaust system
    -panels ; mint doors, door cards
    pair of brand new rota grids with new maz1s in 16x8 £230
    - lights front and rear with motors
    - dash
    -heater/blower
    and im sure some stuff i missed. offers welcomed on all the above parts deals can be arranged for multiple items. give me a text on 07984 664 789!!
  19. shelbz S14A
    shelbz S14A Active Member
    essex
    How much for the nur spec ??
  20. CrossOverPics
    CrossOverPics Member
    Essex/Cheltenham
    Any more info on the engine? Im after a CA to replace my low compression dirtbag.
    How many miles on it? etc.
