Wanted Large Ali powersteering pot
Thread in 'Parts for sale' started by yassa, Jan 24, 2015.
  1. yassa
    yassa Member
    Hi. I'm having issues with my powersteering on my 1jz s14. Im thinking of running bigger diameter pipe work and a larger pot. Does anyone know where I can get a larger pot please ? Thanks in advance
  2. Ruishy1
    Ruishy1 Active Member
    whats the issue ?
    Increasing the diameter of the pipework will lower the pressure you do realise.
  3. yassa
    yassa Member
    Pumps keep failing. Although only used second hand so far. I've now got a new pump. I'm using a 350z pump as told it would be better.?
    - - - Updated - - -
    I'm running wisefab
  4. Ruishy1
    is the pumps pressure compatable with the pressure the rack needs ?
    Doesn't matter what your suspension components are, its all down to your rack and pump.
    Is there any chance your system as any debris ? is the rack in good nick ?
    Is the fluid over heating ? there are numerous questions to be asked and answered.
  5. yassa
    yassa Member
    Im running a 1jz in my S14 using a 350z pump on s14 rack with no cooler but about to fit a Driftworks cooler
