Hi all. In the process of fitting ca18 in my is200 and trying to level it up and was wanting to know is there any part of the engine that can be levelled up from. The engine is complete so cant level it up on the block. [emoji17]
If you're looking to increase the power from the engine then the following mods are good for 280ish BHP Free flow air filter Free flow exhaust Boost controller to achieve 17psi boost pressure Uprated intercooler T28 hybrid turbo Uprated fuel pump 444cc injectors from a GTiR (SR20DET engine) or Skyline (RB26DETT engine) Z32 AFM Stage 3 ECU Chip
oh rite, I completely mis-understood Have you got any pictures on how it's currently sat in the car??
It sits at an angle to the left, but the bottom of the sump is flat when you look from underneath. So side to side I would go from that. Also the top of the inlet is flat... Pitching forward and back won't matter much I should just see where the tail of the gearbox puts it. Hope this helps...
