Low cost S13 Project (all mods inhouse where possible)
Thread in 'Project Cars and Builds Threads' started by steady eddie, Oct 16, 2009.
  1. gibbo s14
    gibbo s14 the yarco
    great yarmouth
    over 60 is mad lock
  2. steady eddie
    steady eddie Member
    Teesslider
    Mat, I just wanted to prove to myself that this angle could be obtained without spending £1500 or more.
    I'm happy with the results and to go any further I'd have to manufacture adapter plates to relocate the top mounts (which I'll probably do at sometime :) )
    See how the weekend does hey
  3. magicmat
    magicmat Active Member
    W.Yorks, Wakefield
    I think that if you can't drift with 60* mate, then you need to look at lessons, not more lock :p
  4. maggzy
    maggzy Member
    Radstock
    lovin the work dude :)
  5. steady eddie
    steady eddie Member
    Teesslider
    The first try out of the new lock attending the NDC went very well....
    This Photo taken by Dave Harper shows the lock pretty clearly going round South Bank bend at Teesside:
    Thanks Dave :)
    Steering took some getting used to as it now is very aggresive and I do have to steer the car now.
    I was going to start a new thread showing how I got over 60 Degrees but then I thought it better to show the people that read my thread before those that dont.
    If you've read the build you'll know I use a modified front subframe with the rack moved forward and lower arms that are extended 25mm so here's the new bits:
    Lower arms where notched so the trackrod end had more travel and adjustable lock stops added to the upper face, also notice another fixing point added close to the subframe:
    Custom made Adjustable Tension arms where the next thing needed as thats the next point that the tyres foul on.
    This is them fitted the the lower arms:
    I was going to make these as part of the lower arm but as the next stage is to extend the lower arms further and re-locate the top mounts I wanted them to be interchangable with all my lower arms
    Knuckles are my usual items that most will have seen (although luminous orange isn't my usual colour):
    This set-up was run without an ARB and going into the first corner on the West track for the first time was a bit nerve racking, but everything is good.
  6. ian200sx
    ian200sx Member
    Newcastle
    Top work there Eddie, radical thinking! like it. ;)
  7. spin-king
    spin-king Active Member
    wirral (merseyside)
    Jebuz that really is some lock.
    cracking build
  8. rbshuttle
    rbshuttle Member
  9. joeybear
    joeybear Member
    cracking work mate! love it!
  10. pointz
    pointz Member
    Insane lock and car looks good too! gonna keep an eye on this!
  11. Chuck_g
    Chuck_g Na = Waheeeyyyyyyy
    Cork, Ireland
    Just went through the whole thread.....truly awesome work mate :) Love the custom steering work!
  12. S13kasper
    S13kasper Member
    Llanelli
    Super lock fair play to you bud
    Sweet thread
    In the middle of the rack mod now will be done tomorrow
    Keep up the good work :)
  13. AndyTR
    AndyTR Member
    hemel hempstead
    Looks good. You've oviously put alot of thought into this project. Love the steering angle.
  14. Nathsx
    Nathsx Member
    Lock is amazing beast of a pic
