Low idle, runs rich hesitant throttle
Thread in 'Technical Questions' started by Kyle k, Jan 24, 2017.
  1. Kyle k
    Kyle k New Member
    *** ALL HELP APPRECIATED *** ( if you can find my problem i will e transfer 100$ ) have a 2jzgte out of an aristo auto ecu and i cannot seem to get it out of limp mode.
    Cold start is very hard cranks and cranks, idle dropped down to 500rpm and if you hit the gas it will want to bog out on you, afr is around 11 11.5, cuts at 3k rpm . ( car has sat for a few years it ran fine before, so there is old / shitty fuel in it, swapped out rear ends did the clutch and then this )
    What i have done
    New tps ( old one was shot )
    Different coil ignitor
    Different map
    Tested IACV
    Tested cam sensors
    New Coil pack connectors
    No vac leaks
    (There is more i am missing cannot list off the top of my head )
    #1 Kyle k, Jan 24, 2017
  2. Kyle k
    Kyle k New Member
    Also car is all stock besides walbro 255 pump, aftermarket exhaust and Greddy BCC
  3. Ikeaaxel
    Ikeaaxel Member
    Put fresh fuel in it before you waste your time doing anything else
  4. thenextdk
    thenextdk Member
    Herefordshire
    Tried cleaning maf?
  5. Kyle k
    Kyle k New Member
    Dont think the fuel is the full issue im sure something else is going on, No maf sensor on this just MAP on intake
