Hi guys. After searching low and high I'm officially stuck. Basically I have a 1999 316i compact with EWS 3.D I have thrown in a M50B25 vanos with a 413 red label ecu out of a 1993 auto coupe. The issue I'm having is that the car cranks but no spark or fuel. I've done a similar conversion a few times but all have been m52s and ews 2 and is fairly simple to start and wire. I've tried copying what I've done on previous swaps but nothing. Apparently the 413 ecu has no EWS rolling code or chip. So should be plug and play. Also from what I know the engine it obd 1 and car is obd 2 as it's a later e36. Any ideas or help is welcome please. Also I've looked in many forums but can't seem to find a true answer.
