I got one of thies and don't need it now its in black, £65 posted This is Wat drift motion says Item Description This 3-wire, 4-pluse magnetic pulse amplifier will convert ANY Toyota vehicle with a standard 22x1.50 mechanical speedometer drive to an electronic speedometer system. Features a standard Toyota VSS Plug for your convience. The Applications are unlimited, converting both 4WD and 2WD 22x1.50 mechanical speedometer setups to electronic 3-wire, 4-pulse speedometer setups. Can be used on Aristo or Soarer when converting to an R154 or W58. Many other applicaions also. For Toyota trucks: Now installing a Tacoma Engine into a Hilux or Land Cruiser is a snap! Works on both Gear and Chain Drive Transfercases! For 1992-95 V6 Applications, when converting to a Gear Drive T/Case Setup, the only previous option was to use a 1992-95 Factory Toyota 4cyl 5-speed Gear Drive T/Case VSS, that sells for $210.
