MAZDA b2200 drift build
Thread in 'Project Cars and Builds Threads' started by BLK_ANVL_GRG, Sep 1, 2015.
  1. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
    1JZ MAZDA b2200 drift build
    Welcome!
    To start off, my name is Alex and this is my drift truck build. Ive always been a fan of these trucks as I currently daily drive one but wanted something a little different to bring to the track.
    This is my daily
    20509879679_b2fb203708_b. IMG_5365 by Alex Lachance, on Flickr
    20074009354_780d335878_b. IMG_5366 by Alex Lachance, on Flickr
    My main inspiration definitely comes from Nigel Petrie (from engineered to slide) if you haven’t seen his amazing work please take a second to check out his Toyota Hilux.
    http://www.speedhunters.com/2013/10/the-final-entry-engineered-to-slide-hilux/
    Also a big influence is Viktor Martensson with his 1JZ powred VW Caddy.
    http://www.speedhunters.com/2013/04/united-nations-of-car-culture-1jz-vw-caddy/
    With the combined attention to detail and the hands on approach of both of these builders, i cant help but be inspired.
    Moving on! The plan is essentially:
    Motor: 1jzgte
    Frame: custom built fully caged
    Suspension/drivetrain: s13
    Day one...
    Picked up the donor cab from the local scrap yard for $56 CND with the help of my Pops and some good friends.
    20075336624_20af5e80b6_b. Untitled by Alex Lachance, on Flickr
    20076969023_e850644252_b. Untitled by Alex Lachance, on Flickr
    Then was off to pick up my steel order.
    20074310504_f66f51482a_b. IMG_5342 by Alex Lachance, on Flickr
    I quickly cut out the floor and started mocking everything up
    20703636731_5c05dfe2f9_b. IMG_5343 by Alex Lachance, on Flickr
    20508840010_c762bfb5ea_b. IMG_5345 by Alex Lachance, on Flickr
    20687523472_175249168c_b. IMG_5353 by Alex Lachance, on Flickr
    This will be the ride height when finished
    20074153304_4bc5a3afba_b. IMG_5357 by Alex Lachance, on Flickr
    #1 BLK_ANVL_GRG, Sep 1, 2015
  2. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
    So next was the frame. Started by laying out and tacking together what I wanted the main support would be. I essentially want nothing to hang below the 4”x4” pieces of wood I have it sitting on. Having everything tucked above will be key in case I accidently go off track (and I will).
    [​IMG]IMG_5400 by Alex Lachance, on Flickr
    Measured up and tacked in place my transmission support.
    [​IMG]IMG_5369 by Alex Lachance, on Flickr
    [​IMG]IMG_5459 by Alex Lachance, on Flickr
    Moved on to the front end.
    [​IMG]IMG_5450 by Alex Lachance, on Flickr
    [​IMG]IMG_5451 by Alex Lachance, on Flickr
    [​IMG]IMG_5456 by Alex Lachance, on Flickr
    [​IMG]IMG_5454 by Alex Lachance, on Flickr
    Things all tacked in place. Taking shape fast!
    [​IMG]IMG_5468 by Alex Lachance, on Flickr
    [​IMG]IMG_5465 by Alex Lachance, on Flickr
    [​IMG]IMG_5466 by Alex Lachance, on Flickr
    Some of my frame welds
    [​IMG]IMG_5473 by Alex Lachance, on Flickr
    Added some braces to help reduce flex.
    [​IMG]IMG_5494 by Alex Lachance, on Flickr
    [​IMG]IMG_5490 by Alex Lachance, on Flickr
    Finished up the majority of my welds
    [​IMG]IMG_5491 by Alex Lachance, on Flickr
    Added another brace up front. It’s essentially lower then the lowest point of the oil pan by 1-1/4” to hopefully protect it as much as possible.
    [​IMG]IMG_5497 by Alex Lachance, on Flickr
    Next up was the actual trans mount.
    [​IMG]IMG_5498 by Alex Lachance, on Flickr
    [​IMG]IMG_5500 by Alex Lachance, on Flickr
    All tacked in place.
    [​IMG]IMG_5504 by Alex Lachance, on Flickr
    And a couple pictures of how it sits now. Things are moving along pretty well.
    [​IMG]IMG_5503 by Alex Lachance, on Flickr
    [​IMG]IMG_5509 by Alex Lachance, on Flickr
    [​IMG]IMG_5508 by Alex Lachance, on Flickr
  3. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
    #3 BLK_ANVL_GRG, Sep 1, 2015
  4. jeepy
    jeepy Member
    suscribed as fuck :O
  5. Patt♣
    Patt♣ Member
    THIS is very cool man, love the fab work on this, not going to lie I WANT ONE:thumbs:
  6. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
  7. peterpan101
    peterpan101 Member
    Prefect. Had the privilege of driving one of these with a sr20det s13 with some mods. Very very impressive vehicle but looses traction very easily and not enough steering angle. Seems to working out that the proper way.
  8. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
    Yeah hopefully I'll be able to balance out the chassis and get a decent amount of angle with the s13 front end components. At least compared to the stock b2200 stuff.
  9. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
    Small update,
    Bent up the "A" pillar bars so i could begin working on the front shock towers.
    [​IMG]IMG_5544 by Alex Lachance, on Flickr
    [​IMG]IMG_5542 by Alex Lachance, on Flickr
    [​IMG]IMG_5555 by Alex Lachance, on Flickr
    then started fitting up part of the tube front. Still trying to figure out where exactly to run the bar. I want to make sure it won't interfere with anything now, or in the future.
    [​IMG]IMG_5547 by Alex Lachance, on Flickr
    [​IMG]IMG_5557 by Alex Lachance, on Flickr
    Ran the tube through the firewall and notched the piece as good as i could get it to the "A" pillar bar.
    [​IMG]IMG_5549 by Alex Lachance, on Flickr
    [​IMG]IMG_5553 by Alex Lachance, on Flickr
    [​IMG]IMG_5552 by Alex Lachance, on Flickr
    Still lots to do but its coming along.
    [​IMG]IMG_5548 by Alex Lachance, on Flickr
    I think Im planning on making my strut tower "plates" removable. So if down the road I was to play around with different caster or plan on widening the front end I can remake the top plate and push my coilovers outwards (kinda like the wisefab kits.
    #9 BLK_ANVL_GRG, Sep 10, 2015
  10. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
    Last night I got some things done.
    Removed my windshield. Wasn't as difficult as I thought once you have the right tools.
    [​IMG]IMG_5620 by Alex Lachance, on Flickr
    Then Finished off the night by bending up part of the front tube section. Brought My top plates to a local machine shop because lets face it... Hole-sawing 4" hole in two pieces of 1/4'' thick plate of steel with a hand drill isn't something I feel like doing. Id like to keep my wrists.
    [​IMG]IMG_5621 by Alex Lachance, on Flickr
    [​IMG]IMG_5624 by Alex Lachance, on Flickr
    Things are just tacked in place for now seeing as I still need to remove the cab later on for final and complete welding of the roll cage.
    [​IMG]IMG_5626 by Alex Lachance, on Flickr
    [​IMG]IMG_5629 by Alex Lachance, on Flickr
    Section that comes through the firewall.
    [​IMG]IMG_5630 by Alex Lachance, on Flickr
    [​IMG]IMG_5632 by Alex Lachance, on Flickr
    That's it for now.
  11. -Tommy.
    -Tommy. Member
    Absolutely awesome fab work man. I'll be watching this!
  12. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
  13. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
    Went and picked up my strut tower plates at the local machine shop and after talking to the owner for a bit, found out a little about the history of this shop.
    [​IMG]IMG_5633 by Alex Lachance, on Flickr
    This building has been standing in this location for over 150 years. From a Church, to Blacksmiths, and now a machine shop... its a crazy feeling you get walking into a building that's seen so many things come and go.
    [​IMG]IMG_5634 by Alex Lachance, on Flickr
  14. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
  15. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
    I went ahead and removed all the old under dash brackets that held the heater core, steering column and other things. They where about to interfere with the dash bar I was about to fit. Thanks to this little gem. This spot weld cutter made the job much easier.
    [​IMG]IMG_5637 by Alex Lachance, on Flickr
    All clean and ready for the next step.
    [​IMG]IMG_5639 by Alex Lachance, on Flickr
  16. BLK_ANVL_GRG
    BLK_ANVL_GRG Member
  17. chodjinn
    chodjinn Active Member
    Awesome work mate this is looking great.
  18. Dean85 S14
    Dean85 S14 Member
    definitely one of the best builds on here!
    how are you fitting the steering column? A plate/something on the dash bar?
  19. crazyae86
    crazyae86 Well-Known Member
    nice work man keep working
  20. jay-young
    jay-young Active Member
    Love it. Some serious fab work going on.
