*** mazda rx7 fc turbo vert PRICE REDUCED -no timewasters ***£2700**
Thread in 'Drift cars for sale' started by haza88, Jul 14, 2014.
  1. haza88
    haza88 Active Member
    up for sale is my mazda rx7 fc turbo vert
    this was sold but to a time waster please only genuin buyers
    iv sold this a few times yet no one has even been to view the car, please dont waste my time genuin interest only
    the engine was rebuilt by me using the best of parts and has 900 miles on it, correctly run in and now fully run in, jump in, start and hav fun
    the car its self is solid no bends or damage it has been welded where needed properly, the underside has been completely! undersealed and the interior is fully painted both fully rust protected first
    it has a BRAND NEW ROOF fitted which are rare and expensive, fully working on the button
    spec
    full aftermarket body kit
    aftermarket front wider wings
    kouki rear lights
    nardi steering wheel
    fixed bride bucket seat on runners
    sparco harness
    60mm greddy boost gauge
    innavate mtx-l wideband afr gauge-currently not working
    hks water temperature gauge
    hydraulic handbrake
    advan wheels with good tyres, maxxis on front
    50mm hubcentric rear spacers
    35mm hubcentric front spacers
    large rack spacers
    modified front knuckles
    mig spec rear diff
    coilovers
    straight thru exhaust to back box
    walbro 255 fuel pump
    fuel pump hard wired in via relay
    brake fluid changed and fully pressure bled
    diff oil changed
    gearbox oil changed
    engine oil and filter changed
    coolant changed- evans waterless coolant
    aftermarket aluminium radiator
    uprated ignition leads
    solid billet gearbox mounts
    excedy paddle clutch
    blitz airfilter
    baileys dump valve
    solid billet engine mounts
    x3 good irons used
    x2 good housings used
    x2 good rotars used
    rotar housings edges bevld
    south coast rotary unbreakable solid corner seals
    south coast rotary unbreakable tips
    full!!! oem seal/gasket kit inc water seals
    oem fd tip springs
    oem corner springs
    oem side seals
    oem side seal springs
    omp blocked runs premix
    double throttle removed
    thermo wax removed
    tps calibrated
    new water pump
    new belts
    new alternator
    ive propably missed a few bits will update ad when I remember
    this is an out and out skid car that can be used on the road and track, plenty! of lock plenty of power and the car its self handles very well
    any questions feel to pm or email me and ill get back to you asap
    harryarnold88@hotmail.com
    has long mot and tax
    located in kent
    £2700 - no offers
  2. haza88
    buuuuuuump
  3. GeorgeHampl
    GeorgeHampl Member
    I can't believe this is still here. If things work out in next two week and this is still here I am definitely buying it
  4. Pikey
    Pikey Active Member
    Why does the roof not have a back window in it? :-)
  5. haza88
    buuuuump
  6. Albóndiga
    Albóndiga Member
  7. haza88
    to the top
  8. bigal1987
    bigal1987 Member
    You got more pics please?
  9. bigal1987
    bigal1987 Member
    Also whats the power it pushing out n engine etc? Thanks
