MCNSPORT: Need for Speed D-Mac 86
Thread in 'Project Cars and Builds Threads' started by Darren McNamara, Aug 13, 2010.
  1. Darren McNamara
    Darren McNamara SR86 pilot
    Buttevant
    Some of you have seen this already but its time to do an official build thread with extra pictures
    Here is the press release from Speedhunters
    DRIVER BLOG: DARREN MCNAMARA>> ANNOUNCING THE TEAM NFS D-MAC 86 - Speedhunters
    Originally this was to be our Prototype ae86 but then Need for Speed came on board and we decided to build something extra special
    We started off with the battered re86....
    And we began to remove bits we deemed unnecessary
    Until we ended up with as much or a little ae86 as possible
    We started by welding up all the holes that would leave tyre smoke or rain water into the cockpit
    Then we fabricated the rear strut bar that will be integrated into the rollcage and also the rear chassis bar
    We then started to position the centre hoop so we could fab the platforms for it to sit on
    We moved to the front then as we had no where to mount our tension rods and anti roll bar so we fabbed a new front chassis section from scratch
    We cant wait to show you more, stay tuned to Speedhunters for the latest build updates
    Darren
  2. mint
    mint touch my fruit
    Scotland / Japan
  3. FlikstRR
    FlikstRR 330D powered
    Surrey, UK
    got your work 'cut out' then .. hahahahahahaahahahahaa see what i did there? hahahaah
    *ahem*
    sorry, I mean.. good luck D, I have faith this will be bad ass. :D
  4. DaveM
    DaveM flickwandoops
    Stroud / Fife
    Awesome.
    What's happening with that AE86 that was going to be built then raffled?
  5. SRRay
    SRRay mr fussy!
    Ireland
    Great stuff Darren!!:thumbs:
    Should be savage when its done:smash:!!
  6. TimmyA
    TimmyA New Member
    Denmark
    Cant wait to see more! work harder ;)
  7. Patrickr32
    Patrickr32 Member
    Breda, the netherlands
    damn that's gonna be a lot of work, nice to see another great project in the making
  8. Darren McNamara
    Buttevant
    It's update time !!! The Need for Speed D-Mac '86 is coming along very nicely at MCNSPORT HQ. Let's take a look at some of the interesting details of the build so far......
    I wanted a way to be able to add caster to the front suspension without pulling the wheel forward so we got these tops made up and welded in place ... simple but effective!
    The scuttle or wiper panel has been removed and the roll cage has been extended to the strut tops and reinforced further with swagged plates. I love swagged plates like these, they look so cool :-)
    The passenger side also gets this treatment. Here you can also see the air intake for the heater has been sealed up along with the bulkhead for the AC pipes. No AC in this hachi!
    We have started to fab the chassis mount for the track control arms. These should be fully finished in the next update.
    The rear end has seen most of our attention. We have decided to go with a rear four link. Three forward facing links and a panhard bar for various reasons. One of them being the position of the fuel cell behind the passenger seat (car is RHD). You can see one of the mounting brackets for the cell in the picture above. Placing the cell behind the passenger seat gives us the best possible weight distribution. Oh and this is only a mock up like arm, the final one will be much nicer.
    Here is a good shot of the rear section of the roll cage. You can see the tabs welded at various intervals on the main hoop section. This will be paneled off to prevent Falken tire smoke, water, dirt and flames from entering the cockpit. You can also see how the third link has been integrated into the roll cage and has four different mounting positions for different suspension setups.
    More rear end detail; The original Panhard Rod mount has been removed from the chassis and 2 more have been fabbed, one on each side. They are much shorter than the original cos this car will be much lower than Toyota intended or at least the axle is. As with any live axle vehicle, the bigger the wheels you use the closer the axle gets to the floor. The chassis panhard mount remains slotted until the vehicle is dropped onto the floor and the final suspension geometry is done. At that point a tab with 3 to 4 holes in it will be welded over the slot in the correct position. Also we can see the axle has been triangulated for strength, we'll take a closer look at that two pictures below.
    This is the rear most structural part of our AE86 chassis. if we bend this we are after hitting hard! The bolt flange you see welded on is just for mounting on our rotisserie but the same flange will be used to mount the removal bumper bars front and rear.
    Here we can see the axle triangulation. I don't think this much torque has been put through an AE86 before especially with only 3 forward axle links. So to prevent the axle twisting we strengthened it at its weakest point.
    Time to drool! Here are the Work Meister S1's in 17x10 with negative 39 offset. The most gangster wheels ever to be fitted to a hachi ! Big thank you to Work Wheels for their support and enthusiasm for this project
    Here is where the wheels would be if they were fitted to a standard car. Out of focus you can see the swagged plate continues from the engine bay up the "A" pillar.
    The powerplant is finally at MCNSPORT HQ. A Hayward Rotary built Bridgeported 13B.
    Here you can see our amazing MCN / AVO AE86 Rear Coilovers. The best AE86 shock absorbers on the market shall be used to transmit 500BHP to the pavement.
    The majority of the roof skin has been removed and will be replaced with our FRP roof skin. The section behind the centre hoop will have a drop vent to provide air for the rear mounted radiator.
    Our WRC inspired roll cage is now fully finished
    This swagged plate is just awaiting welding in to complete the strengthening of the floor mounted axle link points
    The new disposable rear is ready ahead of time. It's a complete clam shell style mould of a JDM spec ae86 rear with tail lights and all in place. This will make wall rubbing inexpensive and quiet spectacular but best of all panels can be replaced easily between runs.
    A nice stack of Work Wheels ready for Falken Tires and some serious abuse
  9. alex_evo
    alex_evo Member
    amazing !!!!!!
  10. FlikstRR
    Surrey, UK
    awseome engine and awesome wheels.
    Carls engines are awesome.. your in good hands :thumbs:
  11. Jord
    Jord drifted.com
    Peterborough
    Impressive fab work and a pretty monumental project! Is this to be used in competition in FD or elsewhere? Just wondering which series' regulations it will meet with the overhaul of the suspension pick-up points.
  12. Darren McNamara
    Buttevant
    suspension pick up points are prob less modified than a 4 linked mk2 escort and no1 has a problem with them
  13. Jord
    Jord drifted.com
    Peterborough
    I'm not sure how many FD scrutineers have ever come across a 4 link mk2 escort so I'm guessing its aimed at UK/Euro series then which is good news!
  14. Darren McNamara
    Buttevant
    this car is to be used in Europe
  15. yohann
    yohann New Member
    wow! looks really really good looking forward seeing this "thing" sideways.
    i have a few question, you dont have to answer them if you dont want to.
    if you looking at the 500 HP mark. why not going for a lexus V8, or 3sgte. what made you go for rotary? (dont get me wrong. this is the most awesome engine ever made :p)
    secondly . what is the idea of going with 3 rods on the rear axle? you are the first one to do so. im intrested to see what is the improvment of doing so.
    and last thing . if you were woried about the rear axle strenght why dont you put a stronger axle . even a multi link one. im sure you dont mind fabribating a few more mounts . haha
  16. Sweeps
    Sweeps Active Member
    In the garage or at work
    Can i ask why a 4 link system rather than a 5, more the reasoning for a central/third link bar as much as anything?
  17. Darren McNamara
    Buttevant
    The 13b is much more compact and has a much lower centre of gravity than other piston engines
    There is a few reasons we went for the 3 link rather than 4 or more
    with the axle being so close to the floor the standard ae86 4 link ends up in an undesirable position so needs to be changed. The usual solution would be to box into the floor but this would intrude into our fuel cell area so some other system must be used
    The 3 link has be proven very successful in oval racing and has performed better than 4 or 5 links and as the objectives are basically the same (getting the power to the ground) this should work very well for us
  18. Darren McNamara
    Buttevant
    hope the above post answers this for you Sweeps
  19. angrydan
    angrydan raaage
    Sittingbourne, kent
    Hhhmmmmm im not a mega fan of crazy 86's but as this looks like its going past retatded i think it could be awesome BUT as awesome aa the wheels are they are just so big lol will take some getting used to!!!
    Best fab work i seen from u guys to really clean and well thought out hays off man and glad i might actually get to compete against u and this car next yr!!
  20. Darren McNamara
    Buttevant
    Thanks Dan,
    i think we will be able to pull off the wheel size cos of the aero thats going on this
    see what you think in the next update
