MCNSPORT: Need for Speed D-Mac 86
Thread in 'Project Cars and Builds Threads' started by Darren McNamara, Aug 13, 2010.
  1. nissanr34cal
    mundford, norfolk
    ok this is mental
  2. grange
    grange Member
    Galway
    Small children can't be let near your turbo they would get sucked in that's sum lovly work
  3. sweeney
    sweeney Member
    Co.Tyrone
    That is amazing Darren, well done lads.
  4. special-k
    special-k Member
    bristol
    just awesome! can't wait to see it!!
  5. sapphire
    sapphire Member
    Wokingham
    thats is one mental ae86. cant wait to see this progress further.
  6. sidewaysirish
    sidewaysirish Member
    south wales
    mental car mate.
  7. Darren McNamara
    Darren McNamara SR86 pilot
    Buttevant
    This is a copy and paste from speedhunters
    Welcome to the third update of the Need for Speed D-Mac 86. I have to say looking at these pictures I'm starting to get excited about this car, its shaping up to be something really special. It hard to get your head around the placement of the Owen Developments GT3582HTA turbo in this pic so lets take a look at the next.....
    Now it makes sense.......well kind of. The turbo is mounted differently to the norm. We have turned it 90degrees and the exhaust now runs down the side it should on a ae86. The reason we had to do this is because of how far back the engine is mounted and being RHD everything is on the right side namely the pedals and steering column and the 60mm screamer pipe. No room left for the exhaust on that side. The Turbo we are using is pretty special, its a Owen Developments Motorsport GT3582HTA turbo with motorsport bearing and billet internal stainless heatshield and ported shroud compressor cover!!
    Here we see just how far back we have pushed the engine. Also you can see the Tial 60mm External wastegate also Supplied by Owen Developments. Big thanks to the guys a Owen for their help
    This looks awesome if i do say so myself apart from the mess. We just don't have time to tidy up the workshop at the moment. I'm happy with the progress we are making, a lot of the major hurdles are now behind us
    Here you can see how we mounted the steering rack. The rack was made removable so you can take the engine out, as the engine mounts are solid to the chassis. The bolts in out tube joiners are only temporary. The tube with the 2 holes is the beginning of our oil cooler mount. Also you can see the rack spacers that we machine to give us extra travel and the block spacers that offset our inner tie rods and the half tube welded into the towers to give clearance. All this is visible in the second pic down also
    Our new steering knuckles are now in their final position and eagle eyed viewers will notice the brake caliper has been moved to the rear of the disk to allow our knuckles to be mounted. I was going to machine new caliper brackets to do this but then i got the brainwave to just swap the drivers side and passenger side struts.....job done
    This is the new path for our 90mm exhaust. The exhaust is now completely finished except for the tailpipe which will be made once all our aero is fitted. Big thanks to Martelius Exhausts in Finland for supplying all the parts we needed
    Here you can see that the original pedal assembly remains untouched and our new bulkhead is now finished. You can also just see the corner of the swagged aluminium passengers footrest
    This carefully placed window is now where you replace the oil filter along with other things like TPS adjustment
    Passenger footrest removed, you can see the completed bulkhead, transmission tunnel and exhaust tunnel. The transmission tunnel has been slightly widened because of how far back the gearbox now is. The Supra R154 transmission is in place complete with custom RX7 bellhousing adapter which allows the RX7 bellhousing to be bolted on complete and retain the RX7 Slave cylinder and clutch fork along with Flywheel, Pressure plate and Starter motor. The great design of the Carbonetic Twin plate clutch allows us to just replace the clutch centre hub to suit a R154 Supra Input shaft. The Supra gearbox is not very long so the new gearlever position suits our slightly further back driving position
    This is our new gearlever position, seat position and our mock up ASD Hydraulic e-brake. Aren't these the sexiest e-brakes ever!! We will be using a slightly longer handle on the finished ca which is being machined in ASD North Carolina as we speak
    One of my favourite parts is the rear mounted radiator which is now finished and mounted, along with the in car piping. Also the Alu sheet you can see is the mock up for the cover of the fuel cell
    This is a sexy piece!
    So nice to see all these ideas that have been in my head coming together
    Speaking of coming together.......the rear FRP shell is now mountable and so is the tailgate. The tailgate will be held in place by two tubes extending up from the chassis and mounted to our GT wing mounts. So all down force created will be transmitted to the chassis and to the tires rather than just flexing the tailgate. The GT Wing mounts should be finished in the next update
    OK so that's it for now. Who knows how much we will have done next time Paddy calls but I'm hoping to get the chassis painted as soon as i can so we can begin the final assembly. Can't wait to get this thing out on track
    All comments welcome, i hope you guys like my brainchild
    Stay tuned to speedhunters..........
    Here is the direct link to speedhunters
    BUILDS>> TEAM NFS D-MAC AE86 - PT.III - Speedhunters
    please leave your comments guys
    D-Mac
  8. JonnyAE86
    JonnyAE86 暴走族 大石
    Japan
    this is the tittys! cant wait to see it finished
  9. Dori Mat
    Dori Mat Active Member
    oxfordshire
    love it :thumbs: :thumbs:
    so much thought gone into everything and some cracking fab work :smokin:
    hope you'll be able to run it in the UK so we get a good look at it :)
  10. DRAGONFD3S
    DRAGONFD3S Member
    Great work and ideas, manifold runner length is nearer optimum like that, just offset against weight distribution.
  11. sweeney
    sweeney Member
    Co.Tyrone
    Amazing fabrication work lads.
  12. milez
    milez Active Member
    wellingborough, northants
  13. BVSX
    BVSX Member
    Republic of Moldova
    epic build! :D
  14. Mattolodis
    Mattolodis Active Member
    Kent,Manston
    This is ......... EPIC :thumbs:
  15. Darren McNamara
    Buttevant
    GT wing braces have been added
    All downforce goes directly to the chassis and to the tyres. The tailgate goes between the brace and the wing mount so it is kept in place by this system also. No need for pins
    The brace is removable via these clever joiners allowing the tailgate and GT Wing to come off in one piece
  16. MeSs
    MeSs Member
    Norway
    Them axles on the wingmounts must weigh allot??..
  17. Darren McNamara
    Buttevant
    What?
  18. Darren McNamara
    Buttevant
    Via Speedhunters Facebook page
  19. thomas666
    thomas666 Member
    gloucester
    really nice build, like it.
  20. cookiemonster
    cookiemonster Active Member
    Durham
    WOW I havent looked in on this for a while really should have lol top work guys its really taking shape now !!
