Misfire when revved
Thread in 'Technical Questions' started by chicane1992, Nov 29, 2014.
  1. chicane1992
    chicane1992 Member
    Bournemouth
    My mates s14 has just started misfiring. It only does it when it's revved but never at idle. We have changed spark plugs and tested coilpacks but it's still there. Anybody have any ideas? Needs it sorted ASAP as he's supposed to be going to dwyb with me in a few weeks. Thanks
  2. NikH
    NikH Member
    London/Essex
    what mods are on it? checked all boost pipes?
  3. chicane1992
    chicane1992 Member
    Bournemouth
    We've had a once over but it does it when it's not under load aswell so assumed boost wouldn't be the problem
  4. NikH
    NikH Member
    London/Essex
    could still be a boost leak would make it idle a little rough or cause a misfire. Get some easy start and spray the joints... if the engine pitch changes you have a leak
  5. chicane1992
    chicane1992 Member
    Bournemouth
    OK bud, I'll have a gander tomorrow. Thanks!
  6. FAbity6032
    FAbity6032 Member
    I was watching a tv show today and they told me it could be the fuel injectors. Because as the fuel injectors age the spray pattern gets worse and it could cause a misfire.
  7. Tommoore99
    Tommoore99 Member
    Southampton
    Mine used to do this spent ages checking things like boost leaks, injectors, plugs, leads then it turned out to be a dodgy maf.
  8. chicane1992
    chicane1992 Member
    Bournemouth
    Cheers mate we will look into that today
  9. thenextdk
    thenextdk Member
    Herefordshire
    I was gunna suggest air flow meter too. Mines giving me a headache at the moment where it keeps getting covered in oil and making the car hesitate. Don't ask me how, or indeed how I'm gunna stop it happening.........grrrrr
