Mk2 escort engine swap ideas??
Thread in 'Project Cars and Builds Threads' started by Josh Drabble, Apr 13, 2020.
  1. Josh Drabble
    Josh Drabble New Member
    New Zealand
    I’ve recently finished building a mk2 escort with my dad, the time has come and the sad 1.3 just isn’t doing the trick anymore. I’ve done some research and I think the best bet is a SR20DET but want to know if anyone has any other good ideas? Ideally looking for a reliable Japanese 4 cylinder with some decent hp! Open to anything better then the original motor
  2. crazyae86
    crazyae86 Well-Known Member
    GR-UK
    best way is for sr20det
  3. Josh Drabble
    New Zealand
    Yeah I think it’s going to have to be the go, best motor for a drift build!
  4. Nismo
    Nismo Hachiroku Master
    someone on this forum put a 4age engine in his mk2 years ago.
  5. chopaholic
    chopaholic Well-Known Member
    Ireland/Lincoln
    Forget about SR20 or 4AGE, go for a Honda engine, K24 from an Accord.
    If I could start my whole project again it would be the way I go.
    • Like Like x 2
  6. Josh Drabble
    New Zealand
    Is this a very costly swap?
  7. Josh Drabble
    New Zealand
    Thank you, I’ll look into it
  8. Cruuz
    Cruuz New Member
    Berkeley, CA
    Big aftermarket support coming on for the rwd k2x swaps now. I bet Honda engines and bmw transmissions are fairly easy to come by for you over there?
    My other suggestion is a Mitsubishi 4g63t. Loads of easy cheap power to be had, many trans options for different power levels, super under rated imo. It's the lump sitting in the bay of my swap right now. I can say tho, the Honda and Mitsu swaps will be a bit more in depth considering they're both using a motor that started life in a fwd platform. You might just be able to scoop up an entire sr20 dropout, get a prop shaft made and be done with it
  9. Andy318ti
    Andy318ti Active Member
    Edinburgh-ish
    4 pot bmw engine with a turbo
    Volvo redblock
    Or as above, k series is hard to beat
