MkIV Supra TT - to drift or not to drift!
Thread in 'Project Cars and Builds Threads' started by turbobungle, Feb 15, 2011.
  1. turbobungle
    turbobungle Member
    I've had my UK spec Supra TT 6 speed for nearly 8 years now although it's been off the road since July '09 as I've been too busy with work, getting married, kids and an R35 GTR!
    I've now sold the GTR and have decided this is the year I try drifting and I'm trying to decide whether to resurrect the Supra or buy something better suited.
    The Supra is slightly modded running approx. 420bhp on std. internals, 6 pot brakes, Rota GTR's, Toyo R888's, BC Racing coilovers
    I don't know if I could bring myself to get rid of it but not sure if it's any good to drift, obviously it goes sideways but I'm thinking it might be a bit heavy for proper drifting? I've certainly not seen many on DW!
    Is there much out there for modifying Supra's to drift properly? Any easy cheap mods available to improve it? Or should I just buy something more suited? Any advice welcome!! Thanks
  2. jamespayne5
    jamespayne5 Active Member
    There not used because there still fairly expensive cars, i don't see any reason why it wouldn't be awesome. The wheelbase isn't that small is it?
  3. mestew87
    mestew87 Member
    As jamespayne5 said, the main reason they arent used is they are still quite an expensive car to buy and to modify, The soarer is quite popular with drifting and it shares roughly the same chassis as the supra and weight
  4. dcarrter21
    dcarrter21 Member
    Get on and drift it! Mines fine!
  5. nissanr34cal
    do it man if not your a rageing homo :D haha no do it you will be different and cool
  6. nissanr34cal
    also they drift, this one is an auto with a welded diff and some coilovers exhaust and an air filter and thats it
  7. MeSs
    MeSs Member
    Well, in Norway Supra MKIV is the most popular driftcar atm :wave:
    Id say drift it!!
  8. turbobungle
    turbobungle Member
    cheers guys, step 1 has been taken! Managed to clamber over all the stuff in my work store to find the Supra get the battery and charge it. She just started 1st time no probs after 18 months sat gathering dust! Just need to spend a day with the forklift trying to get it out of the store now!!
  9. nissanr34cal
    good man, now weld the diff, up the boost and go slideing haha
  10. mart s13
    mart s13 Member
    [ame=http://www.youtube.com/watch?v=7VDHLFhjYwI]YouTube - Marcin Supra DRIFT AT SILVERSTONE( for 1st time in new car)[/ame]
    Thats my mates one and is prfect for drift.
  11. jdm156
    jdm156 New Member
  12. V-con Pro
    V-con Pro Active Member
    the jza80 supra has the same wheel base as the jzz30 soarer doesnt it? will handle mint with the right suspension good luck.
  13. trd dan
    trd dan Member
    a uk spec tt6 in black is worth a few quid dude , if your wanting to get into drifting id sell and buy a jspec with loads of goodies ;)
  14. Mr Doricar
    Mr Doricar JDM Loose yo
    Supra's are cheaper in England than Japan. That would be a bad move.
  15. trd dan
    trd dan Member
    no i mean a jspec already over here dude , u can pick up a nice single for 13k , this car has gotta be worth around that condition dependant
    dan
  16. ma70jake
    ma70jake Member
    you should have no problem skidding it as is? what suspensio mods do u have?
  17. Blackadder
    Blackadder Rawr!
    I don't know what diff these have as standard, but surely with 420bhp it shouldn't have much trouble spinning up the rear wheels ? And with the money from selling the R35 (I don't know you circumstances so i'm just going to make a presumption you still have a bit of it left) personally I would spend £600 on a good 2way :)
    Looks awesome dude, and a bit of inspiration from the guys at Formula D
  18. mitsi_matt
    mitsi_matt dorihomo
  19. dicko
    dicko Member
    whats with coming off a trailer at the nurburgring? did it not go well? or did you trailer it there?
  20. Raceworx
    Raceworx Member
    sounds like all you need is a diff and you have a competative drift car.. if you dont mind it getting abit bent up then go for it..
