For sale, possibly the biggest, most awesome, Man-spec Brembo brake setup! A pair of almost new Calipers, Discs and pads. These came off a 2016 GT V8 Mustang that was damaged, and have done literally 50 miles from new! They are in A1 condition. They are similar in size to the R35 GTR setup and are beyond belief! They make the R34 GTR setup look like pansies. 380mm x 35mm vented discs which have 5 x 114.3 holes so will potentially fit most Jap cars. Before messaging me, please acknowledge the following. Due to the sheer rarity of this setup, and the monster size, I do not know whether these will fit your car, i do not know whether they will fit under your wheels. You will more than likely need to have custom brackets made, BUT if you run a smaller diameter disc then you will have more options for clearance etc. The discs are a 5 x 114.3 bolt pattern so 'Will' potentially fit Skylines, S Bodies, RX7's etc. Pm me for anymore info, located in Surrey. £750. {} {} {} {} {} {}
Cheers. They will go over an 18 inch wheel as that's what is fitted to factory standard 2015-2017 Mustangs, but it depends on the wheel/offset etc... All PM's replied. Lee
Hi can you measure distance between mounting holes ?? , shame they are not radial mount , would fit stuff easy then !!
