MOT question
Thread in 'Other Chat' started by Big.D, Apr 11, 2014.
  1. Big.D
    Big.D Member
    Hi All
    If i take a car in for an MOT with some time still left on the existing MOT and the car fails does the existing MOT become null and void?
    Thanks
  2. Ruishy1
    Ruishy1 Active Member
    East Ayrshire
    not unless the garage says the failure is dangerous
    #2 Ruishy1, Apr 11, 2014
  3. r3k1355
    r3k1355 Well-Known Member
    How much time?
  4. GB / John
    GB / John NDC Runner Up 2012
    Washington / Newcastle UK
    If it fails the previous mot is still inforce until it ends.
    However it is an offence to drive a defective vehicle, a failed mot means vehicle is defective.
  5. Matts Turbo'd
    Matts Turbo'd Member
    North London
    my dad has done this and the car has failed the test and a failure certificate was issued meaning the car then had no mot however if it still has test on it ask for a failure certificate not to be issued but just pay for the test that was carried out as if a failure certificate is issued it will make the current mot void
    or at least thats what happened to my dad may be different
  6. Big.D
    Big.D Member
    It's got a month left
    Cheers for the responses guys the car went into today so i play it by ear as to what i'll do
  7. GB / John
    If you got a month left, and it passes, you will get unto a 13 mth mot.
  8. David Reid
    David Reid RB30 Charger
    NO ! Any failure is dangerous, that is the point of the MOT.
    If you fail an MOT it proves your car is not road worthy and invalidates any remaining MOT.
    The only way around this is to book a pre-mot test with your freindly mot centre, they will then effectively test your car to the mot criteria without entering it on the system, the advantage being when it fails you can still use it (assuming you still have mot, as it was not an official mot). The disadvantage is if it passes you then need to still put it through a proper test.
    This is what I do to ensure I remain 100% within the law
  9. jeta11
    jeta11 Member
    hampshire
    As said it's been proven to no longer be road legal, but still using it is a grey area it was wrote that you could as long as it was booked in at the soonest available time.
    #9 jeta11, Apr 11, 2014
  10. David Reid
    It is not a grey area, since the digitalisation of the mot system it is very clear. You fail the mot and it cancels any current mot, it is all recorded and available to the old bill should you drive past them.
  11. jeta11
    jeta11 Member
    hampshire
    It was wrote on the bottom of an mot refusal and when questioned at my last mot training they wouldn't answer either he didn't know or vosa have no specific answer.
  12. David Reid
    I specifically asked if the database is updated with the failure and was told yes. If it wasn't there would be no point this new system as you could just modify the paper mot certificate. What is registered on the database is all the police care about and prosecute with.
  13. Bolf
    Bolf Resident Nut Job.
    PE6
    Go to garage , ask for pre mot test.
    then if its good , ask for an mot , if its got faults highlighted , fix and book mot
