MX5 Daily Skid n Track Project
Thread in 'Project Cars and Builds Threads' started by richie_k83, Mar 31, 2013.
  1. James998
    James998 Member
    Looking good so far! Clicked this thread randomly browsing the project forum, second photo thought 'sure I recognise that jazz with the blue wheels...'
    Looking at the photos you live around the corner from one of my best mates, how weird hah! You'll probably see my bm there every so often!
  2. richie_k83
    richie_k83 Well-Known Member
    Lookin good dude! I like your style haha
  3. richie_k83
    Haha, its a small world lol. What u drive? May of seen u about... Lol
  4. richie_k83
    Small progress update but nowt too constructive. Picked up these from work ready for the engine rebuild;
    Standard size ACL Race Rod and Main Bearings and Thrust Washer, hopefully wont be long untill it starts going back together...
    Seen a few people retrimming their door cards too so thought i would give it a go, so pulled them off;
    Stripped them down;
    And wound up matching it with the front fender;
  5. stefan_used4
    stefan_used4 Member
    MATE! I love the zebra thing.. we are the zebra bros! :wack:
  6. richie_k83
    Yea dude! Looks ace man haha
  7. richie_k83
    So the other day I decided to take the block to the local engine shop to get the bores deglazed so we're all ready for the rebuild.
    Pistons need cleaning up so i busted out the petrol and an old tooth brush and got scrubbing.
    Before and after,
    Chuffed with how well they came out, also got the new piston rings on order and fitted some ARP rod bolts,
    Took a while to get them all done but was worth it in the end!
    Cant do much else at the moment so decided to clean up the crank and do some block work whilst i await the piston rings.
    Started off with a clean and dropped in the ACL Main Bearings and ARP Main Studs,
    Greased up the bearings with assembly lube and dropped the crank back in, all torqued down and ready to rock!
  8. richie_k83
    Not much else to do now other than wait for the new Piston Rings to arrive.
  9. Woocash
    Woocash Member
    Amazing work dude, specially in a garden shed :thumbs:
    Mx5's are worth it, took to Spain and Poland.
    It was my daily, trip tourer, lifestyler and drifter :smokin:.
    Now it's a garden ornament, to many cars/projects...
    Ur thread is inspiring man, keep up the good work :thumbs:
    BTW about 1,5year ago (before respray)cI used to roll like that,
    on the other side was a TIGER WING :wack:
    Woocash
  10. richie_k83
    Thanks dude, its all getting there slowly lol!
  11. richie_k83
    Small update, still waiting for the Piston Rings to arrive so decided to clean up some parts and do what i can...
    Cleaned up the Oil Cooler and chucked it on along with a HKS Oil Filter, placed the head on too just to get all excited about how its gonna look :D ;
    Also had new front and rear Crank Seals so chucked those on too after stripping and cleaning the oil pump;
    More cleaning on the Sump Baffle and Pick Up Pipe, only clean place i had to keep them was on the engine so they will need to come off again when the Piston Rings land...
    Thats all for now, next update will be the Rods and Pistons going in, when they get here....
  12. richie_k83
    Small parts update, managed to pick up a cheap set of new Samco Rad hoses for £40 and a water pump, wont be long till its running now....
  13. richie_k83
    Sooo, Piston Rings have been delayed with the supplier so I am slowly running outa things to do....
    On a plus side, I Picked up a set of shiney new core plugs and bashed them in;
    Also bashed on a new water pump whilst i was at it...
    Managed to score a set of mint front seats from my pal at work, alot better than the leather ones and aslo more supportive having been reconditioned, so I chucked em in;
    And chucked on a new sticker...
    Fingers crossed my fookin Piston Rings turn up before the weekend....!
  14. Phil Mann
    Phil Mann Member
    You either need to get some proper seats or hack the foam out of those. They won't be very good if you ever get round to drifting it.
  15. richie_k83
    Yea this is true, may get away with harnesses to start with, will see how i progress when it eventually gets driftable....
  16. Stavros
    Stavros Active Member
    Only a minor thing, but if I was rebuilding an engine I'd spend 10min removing all those god awful rough casting marks in the block.
  17. richie_k83
    True, not that much of a perfectionist mind. Just want seat time now though so it would only add a few more hours to the build...
  18. richie_k83
    Not really had much of an update for a while but i am happy to say that things are starting to move quite quickly once parts arrive that is.
    That being said I should have a built and driveable car in the next few months...
    A small part of my order arrived at work yesterday to kick things into gear, a new KAAZ LSD with spare Oil, Mishimoto Thermostat and Mishimoto Exhaust Wrap with Stainless ties and spare HKS Oil Filter;
    Also a IL Motorsport Race belt and bearings from MX5 Parts;
    Expecting more parts over the next few weeks such as;
    Hard Top
    Mishimoto Alloy Radiator
    Samco Auxilary Hoses and Hose Clamps
    Magnacor Leads
    Exedy Organic Clutch Kit
    Goodridge Stainless Clutch Line
    Clutch Slave Cylinder
    Piston Rings
    Diff Bearings and Seals
    TR Lane Harness Bar
    TRS 4 point Clubman Harnesses
    Busy times ahead so watch this space...!
  19. richie_k83
    Posted Today, 02:04 PM
    So today, i finally got the Piston Rings delivered and promptly got to work fitting them;
    Half done;
    Once that was all done, i got to work building the rest of the engine.
    Dropped the ACL Rod Bearings in, torqued everything up, dropped the Head Gasket on along with the Head. Fitted the new Cambelt and kit and timed it all up.
    Then decided to get the Manifold wrapped up...
    Really starting to come together now!
    Will try and get roung to fitting the oil pan later, also picking up a hard top tomorrow ready for the Winter!
    #59 richie_k83, Aug 10, 2013
  20. richie_k83
    Over the weekend I picked up my Hardtop, needs re painting so will I be going for the usual Satin Black...
    Also yesterday i got the sump fitted and sealed up and took delivery of a few more bits, Exedy Clutch Kit, Slave Cylinder, TR Lane Harness Bar, Diff Selas and the gearshifter seals;
    Then today at work i received my 4 Point TRS Harnesses, Mishimoto Rad and Magnacor 8.5mm Leads;
    Thats pretty much all of the parts now, looks like i should be fitting the engine and transmission next weekend....!
