For Sale MX5 TURBO 280HP - BIG SPEC
Thread in 'Drift cars for sale' started by Johnnysupra, Oct 14, 2019.
  1. Johnnysupra
    Johnnysupra New Member
    Here for sale is my sleeper turbo mx5, It’s a 2000 1.8s so comes with better suspension and a lsd from factory, the shell mileage sits at 99k, The original engine unfortunately suffered rod knock due to an overly aggressive launch control and I have sourced a low mileage one at 80k which was fitted in April this year. The sills have been rid of rust aswell as the bootlid which is another common place for rust on mx5s, the rear arches are fine and both sills have been undersealed,the car was resprayed from the wing mirrors back, in March last year, it’s not the best of jobs but she cleans up nice. Full years MOT, I have a folder bulging with receipts the car was serviced by me every year in my ownership, as it’s easy enough to do and I enjoyed it. It’s a fast car, not to be underestimated and having said that, all test drives will be done by me unless you have the cash in your hand!
    The power is currently at 280hp (with printout done a couple months back) which is considered the maximum for stock internals, boosts great all the way to redline. The turbo kit was originally installed by skuzzle whilst it was in the previous owners possession, I have the original receipt for it, I bought the car standard apart from the turbo kit, it had standard brakes,clutch, interior and engine bay, so I’ve put a lot of money and hours into this car. Car comes with 2 keys and 2 Clifford remotes. Slight cracked paint on rear bumper.
    Exterior:
    • Debadged and Smoothed front bumper
    • Mx5parts front grill sprayed in sparkling graphite
    • Sparco tow strap sprayed in sparkling graphite
    • Debaged and smoothed rear end
    • Clear repeaters and reflectors lightly sprayed in sparkling graphite
    • Hardtop with heated window, sprayed in sparkling graphite
    • Softtop with heated glass window - softtop has a rip in it, but no water gets through
    • 15” ATS cups - did have ad08r’s all around but due to winter I have put some winter tyres on the rear
    Engine:
    • Stoney racing coolant hoses in red
    • Stoney racing breather hoses in red
    • Stoney racing brake servo hoses in red
    • Red vac & washer hoses in red
    • K&N air filter with heat shield (filter could do with a clean)
    • Okuyama carbing aluminium radiator cooling panel
    • Mx5 engine strut bar
    • 52mm core aluminium radiator
    • Front mount aluminium intercooler
    • Fuse box cover
    • Red Jackson racing ignition leads
    • Air horn
    Interior:
    • Style bar
    • Stepper motor boost gauge
    • AEM wideband
    • Dragon gauge water temp
    • Dial overlays with colour change
    • Nardi made to order black and blue steering wheel
    • Black and blue RARE door cards
    • Black with blue stitch handbrake and gear nob gaitors
    • Mk2.5 heated seats with switch’s on side of centre console
    • Nakamae black leather with blue stitch seat covers
    • Nakamae black leather with blue stitch transmission tunnel cover
    • Nakamae black leather with blue stitch innerside kick plate
    • Switch panel with push start, launch control and flat foot shifting
    • Blue footwell lights
    • Blue shift light
    • Carbon fibre effect radio and gear surround from 10th anniversary
    Security:
    • Clifford 650 alarm - remote start, turbo timer, proximity sensor,auto lock, impact sensor and boot release.
    • Optional valet mode
    Turbo kit:
    • Chinese td04 very strong
    • Log manifold
    • 3” exhaust from manifold all the way through with sport cat and back box, not loud untill you put your foot down which is great on motorways and keeps the car as a sleeper.
    • Unknown boost controller
    • Megasquirt 2 pnp ECU
    • Rx8 blue 540cc injectors
    Brakes:
    • HEL braised brake lines
    • Drilled vented brake discs
    • Yellow Ebc pads
    Transmission:
    • 5 speed manual
    • Stage 3 competition clutch
    • Oem flywheel
    Brand new alternator
    Brand new battery
    Brand new steering wheel
    Brand new ignition leads
    The engine was last serviced when it got swapped in and all new tensioners and seals too. Have a few spare parts to go with the car if price is met.
    Few little things will need doing such as sorting the original horn as I hadn’t had a chance to run the cable through the new steering wheel (have installed a horn on a switch) steering wheel will need straightening up which will be done when the horn is wired in. Very Slight bubbling on one sill, would be just surface rust and I’ve considered this in the price.
    Looking for £4800 with plate, offers considered.
    CAR HAS NEVER SEEN THE TRACK, ONLY ROAD USE.
    COMES WITH BOOT FULL OF SPARE PARTS.
    F86FE320-3F3A-4816-A8DF-4F01B5493BBF.
    DF5B11AE-50D1-4007-B6B2-696FBC92FE5C.
    67FAEDD8-E2C8-4512-A134-594BE0534EF6.
    23477480-B61E-4A9E-95B0-AE551AEF14E0.
    84A873BF-8980-4F30-82B7-A56E23185A62.
    41C036FA-F333-488A-BA5C-27DA4A6A441F.
    89490560-35F2-4C86-BDBD-D583242E4FEB.
  2. Johnnysupra
