Mx5 wheel fitment issue...please help.
Thread in 'Technical Questions' started by Nick_Racing green, Aug 13, 2019.
  1. Nick_Racing green
    Nick_Racing green New Member
    Newbury
    I'm I need of some advice on getting a set of BM8s Et0 to fit nicely on my mx5. Arches have been rolled and coilovers are ready to get the vehicle low, however it looks as if the wheel arches are going to sit on top of the tire tread when lowered from these images. Does anyone have any advice that may help? Thankyou.
  2. Mig1375
    Mig1375 Member
    Kilmarnock uk
    Once you fit your coilovers and lower it it will be fine as the top of the wheel will camber in . I had 8.25 wide et0 no problems with 195 wide tyre
  3. ianlea73
    ianlea73 Well-Known Member
    Bristol
    Easiest way to have a visual check is to jack up the car & put it on stands then put the jack under the suspension lower arm & jack it up.
  4. Nick_Racing green
    Newbury
    Thanks Mig1375, that's what I was hoping for, however due to them look so wide at the moment I was very sceptical?
    Do you have any pictures of yours. And if so did you need and arch work done. As I've rolled mine already.
  5. Mig1375
    Mig1375 Member
    Kilmarnock uk
    Check in build threads theres pics. i just rolled fronts back was fine
  6. Mig1375
    Mig1375 Member
    Kilmarnock uk
    There you go
    Screenshot_20190806-175822.
  7. Nick_Racing green
    Newbury
    Looks good, nice stretch on the tires. Are you geting any rub from any of the arches at all?
  8. Mig1375
    Mig1375 Member
    Kilmarnock uk
    No none av actually took these off now and fitting 16x9 et20 205 50. Once tyres arrive
  9. Nick_Racing green
    Newbury
    Good luck with that, looking forward to seeing them fitted. I was tempted by 16s but the BM-8's that I really liked maxed out at 15's unfortunately, otherwise I would have rather gone for 16's with an even smaller tyre wall and pos more strech. Now I know I could have easily gone for 185/45/15 but played it safe with a 195/45 as I'm new to this.
  10. Mig1375
    Mig1375 Member
    Kilmarnock uk
    Only reason am going 16 is i i was scraping the floor with 15 tryed 17 but didn't look right
  11. Nick_Racing green
    Newbury
    Yeah I was concerned about scrapping on 15s but as I saw lots of others going for it as the 15" is so popular and the wheel I preffered would only go up to the max radius of a 15 I had no choice. Also I though a16" would have more chance of catching the inner fender liner bumper attachment mounts.
  12. KillboSlaggins
    KillboSlaggins Active Member
    Hampshire
    F8ECF8B0-9D2B-4CCB-926A-47AD7D79E1B9.
    mk1’s look good on 13’s imo
  13. Mig1375
    Mig1375 Member
    Kilmarnock uk
    Yeah the deffo do but to have a nice stance height wise ur quite low for ground clearance
  14. Nick_Racing green
    Newbury
    @Mig1375 I just want to thank you for your advice mate. You were right about the wheels cambering in upon lowering. Happily sat a little lower now ☺
  15. Nick_Racing green
    Newbury
  16. Mig1375
    Mig1375 Member
    Kilmarnock uk
    That looks the part
  17. 5ooty
    5ooty New Member
    West Midlands
    Looks good, I stopped running my car super low because it drive like ass, but they still drive good if you don't tuck the tyres in chthe arch too much.
    My nb1 is on 16x8 et5 front, et10 rear and needed a good roll to fit with 195 rubber
  18. PanozGTR
    PanozGTR Member
    East Sussex
    The lower you go the more camber you get and the wheel pulls in more, this is a 15x8 et28 with a 25mm spacer. Raised the car ~10mm since this. The tyres are also obnoxiously chunky looking due to having wheel protector side wall things.
    DSC_1365.
