My 350z Build/Drift progress thread...
Thread in 'Project Cars and Builds Threads' started by richie_k83, Apr 5, 2019.
  1. richie_k83
    richie_k83 Well-Known Member
    West Midlands
    Few snaps from yesterday...
    67618667_2439121046324668_4117067912353677312_o.
    67628487_2439121079657998_5744409850914275328_o.
    67783314_2439121236324649_7546084580738990080_o.
    67825096_2439121316324641_5230696754034245632_n.
    67916813_2439121152991324_4322389536903528448_o.
    67949348_2439121252991314_4179357973371420672_n.
    68738211_2439121139657992_6818850586352418816_o.
  2. richie_k83
    West Midlands
    48481025366_503d03255c_z.
    48480906646_b145bbcd9b_z.
    48481060867_68d58d8aeb_z.
    48481061477_6f9c5c7c82_z.
    48481064462_67d1b9ea33_z.
    48480909841_c4ee76a2c1_z.
    48481062937_a472ff90d0_z.
    48480908676_a336a13534_z.
    • Winner Winner x 1
  3. richie_k83
    West Midlands
    On the ramps at work, Kaaz 2-Way LSD is going in.
    9A9133EE-6043-4D9C-984D-5B378ECED6EC.
    Other Jobs to sort are clicking driveshafts and general check over. Alignment to sort out at some point before Pod​
  4. Rippon766
    Rippon766 Member
    Wolverhampton
    These wheels are growing on me haha.
    I'm not sure how much research you have done,but clicky shafts can be sorted by putting some grease inside the hub/half shaft spindle. The noise comes from a dry joint apparently.
  5. richie_k83
    West Midlands
    They do, although the colour is a heap load better in person lol
    I have read this, shafts are coming out once the diff is sorted.
    One other thing i need to sort is the Revs, they seem to be slow to drop. is yours the same? not sure if its normal on these or not.
  6. richie_k83
    West Midlands
    Diffs in, big boy skids inbound... :smokin:
    68922736_10219227890438505_7705533360407314432_n.
  7. Rippon766
    Rippon766 Member
    Wolverhampton
    Not that I've noticed. seems normal when I drive it.
    That diff looks the dogs!
    You should come to Birmingham Wheels if you are after a local drift day.
  8. richie_k83
    West Midlands
    I did used to drift there every so often with the Flatout Factory guys, but i'm going to be using 3 Sisters as my new Track. Super easy to get to and seems like a good day there. only up the M6, easy as to get too.
  9. ShawnSlide
    ShawnSlide New Member
    USA
    What trick did you use to disable the driving assist stuff? Like the stability control and stuff for burnouts and skidding? I've seen various things like pull pin 101, cut one of the fuses, unplug the grey connector at the abs pump. So I figured I'd ask someone who is actually using a 350z for drifting like I'm trying to do.
  10. Rippon766
    Rippon766 Member
    Wolverhampton
    My car does not have VDC so I just remove the ABS plug. If you remove pin 101 you dont have any brake lights.
    Have a look at this for VDC/Brake disable mod
    https://www.350z-uk.com/topic/12406...ass-burnout-mod/?tab=comments#comment-1814836
  11. richie_k83
    West Midlands
    On mine, i have unplugged the VSC Switch and G-Sensor as well as cutting the ABS Fuse
  12. richie_k83
    West Midlands
    Santa Pod closing in and i find myself needing a new clutch.
    Cheeky burnout the other week fried what was left of the Clutch.
    So, back on the ramps we go for a Comp Clutch and Braided Clutch line.
    DE51A421-5822-4086-A90C-17BF3B176AA6.
    81EBF313-E26E-4E87-8094-0D0E665B3690.
    79C0C7B3-ADE3-42E4-A612-EF962BF662EB.
    Just as well it died now, rather than at Pod i guess...​
  13. richie_k83
    West Midlands
    Making space, well, trying too..!
    Rear speaker framework and trim is coming out. Absolute mission, cutting and drilling spot welds;
    32.
    31.
    Making space for spare drift wheels and also a cage.
    Should be worth it in the end i'm sure...
  14. richie_k83
    West Midlands
    Finally out,
    70307858_10219484455612474_6407289030295158784_n.
    Goof few KG's right there.
    Plus loads more room for activities!
    70114773_10219484455852480_2432161785550209024_n.
    Just some cleaning up to do and couple of little bits left to cut/drill out and we good.​
    • Winner Winner x 1
  15. richie_k83
    West Midlands
    Wheel alignment on Saturday over at A-Line.
    70632335_10219529582700623_8980506612816936960_o.
    Car was all square, unfortunately couldn't dial the Camber out of the rear end as the bolts were seized.
    Need to get a load of new bolts and some adjustable arms too. But will sort that another day.
    Santa-Pod next week, buzzing.​
  16. Simon998
    Simon998 Member
    Looks great. These things seem to hang really well, the americans love them for missiles.
    did you bin the Bose sub? I'm looking something small to shove in my daily.
  17. richie_k83
    West Midlands
    Yea, i have seen a few US guys nailing them. Seem to go pretty well.
    Everything i stripped out has been binned i'm afraid!
  18. richie_k83
    West Midlands
    Few snaps from Saturdays Coffee Morning at Work.
    48816436713_42931d0a7f_k.
    48816793581_ba9cd6c1db_k (1).
    48813074193_e44d5cd140_k.
    Pod tomorrow too, cant wait :)
  19. richie_k83
    West Midlands
    Santa Pod on Wednesday was awesome. Taking the opportunity to learn the car and getting back to basics, seeing as I have only ever drifted on an oval track.
    The Car was solid all day, apart from the Clutch Pedal, which seemed to only want to come up about half way when hot...
    Still, it didn't stop me, clutch kicked through it lol
    Morning was spent in the play pen, doughnuts and figure of eights on the agenda.
    Afternoon, we had a few goes in the Kidney Track, which took a few pointers and goes to get right. Managed a few consistent laps, which was really rewarding :)
    Nailing the Figure of eight lol
    Really looking forward to next time. Sort the Clutch issues out, morning in the Kidney and hopefully hanging on the big track later in the day :)
    #59 richie_k83, Oct 4, 2019
  20. Rippon766
    Rippon766 Member
    Wolverhampton
    Looks awesome, can I ask the specs of your wheels?
