Well it was time to get a new chassis I was after a DRB/DIB and decided to go for the FS01 I like the front motor look and active suspention from standard. Here it is out the box I have the full CS kit for it not sure if I should fit it or not Also fitted the alloy steering rack and cooling bars Spec is: MST FS01-D SAVOX TEKIN RS ESC TEKIN REDLINE MOTOR This is how it stands ATM Thanks Darcy
CS and front 1 way is needed, reverse your pinion too meshes better Random question but why are you running the balance lead on your battery?
I would turn the pinion but the bloody grub screw has rounded off so I can't be arsed to take the motor out and get it out I got a 10.5 to go in so I will sort that out when I change . The balance lead is only plugged in so it don't drag on the floor also so I don't lose it Darcy
Depends mate if I'm running 50/50 or Cs and what surface I have a few saved settings I have made for carpet Tarmac etc Darcy
Awesome mate it's a great chassis I have done loads more I will update this once I have fitted my other bits later Darcy
