My Poor Rotten S13
Thread in 'Project Cars and Builds Threads' started by pj9ar, Mar 24, 2014.
  1. pj9ar
    pj9ar Member
    well its been a long time coming i have owned my s13 for almost 7 years now and i drove it for about 2 of those :euge: and i've always been meaning to start a project thread, i spend most of my time on here or sxoc so i may as well contribute a bit :nod:. i'm also hoping it will help me keep up my enthusiasm to finish it. anyway this is what it looked like when i bought it, bog standard
    and it WAS clean no rust on it.
    so far i have (i tried to do it in order):
    rebuilt the engine
    removed aircon
    staged 1 the engine (walbro, filter, chip, exhaust ect.)
    blitz turbo timer (the one with the boost pressure)
    lowered it on springs
    got some uber rare s13 driftworks orange seats :smokin:
    apex alloy rad
    bought some wheel (there volks but cant remember what there called)
    large spacers (4-5 stud converters)
    coilys apex gen 2
    50mm origin rear over fenders
    magic aero sideskirts
    unknown 20mm front over fenders
    kouki front bumper + lip
    stage 2 the engine (intercooler, chip ect.)
    blitz half din boost controller + the other half din extra that does lots of awesome things i cant remember :D
    z32 tt front and rear brakes rears aren't fitted yet
    defi gauges boost, oil pressure, oil temp.
    adjustable front and rear arms
    poly rear sub frame bushes
    ive probable forgot a bunch of stuff but oh well.
    now this is what i've been doing in the past few weeks;
    from storing the car for years it got a bit rusty :cry: especially the drives side and so ive decided to do something about it and try to inject some life back into the poor old girl.
    so here we go
    the engine bay is the was the worst so i pulled the engine out
    as you can see not too pretty so i started chopping, one of the chassis rails where too far gone so i had to replace it. please bear in mind i only have basic tools and a home made sheet metal bender so the work is not perfect.
    made new wheel arches and welded up the holes in the suspension turret made new reinforcement pieces on top of the turrets
    replaced the bottom cross member, hoping it will stiffen up the front.
    made a mount for the intercooler
    i had to cut out another part of the drivers chassis rail under the car, this is what i had to be cut out
    #1 pj9ar, Mar 24, 2014
  2. pj9ar
    pj9ar Member
    i havent totally finnished this yet but its half welded in i will get some pics when i finish it off tomorrow.
    i didnt have enough steel to copy the reinforcement so had t make do it seem strong enough
    these are the main bits i've cut out minus the wheel arches, they got scraped
    these are all the parts for the front sub frame got the tein rod ends coming next week ive also got the solid steer bush already fitted i want to get some engine mount as well if my budget can stretch. there is also the intake gasket for the engine as i think it need replacing
    i wanted to move the rack and mod the knuckles but i want to do track days in this as well as drift and i don't know if it affect it for track driving, can anyone tell me if it will? and do you need to extend the lower arms if you move the rack forward?
  3. Loopy_drifter
    Loopy_drifter Member
    Aberdeenshire
    Good fabrication work :smash::smash:
    Nice write up too... :worthy: :thumbs:
    Why move the rack? Won't DW offset rack spacers do the same thing, without moving the rack? :confused:
  4. pj9ar
    pj9ar Member
    thanks
    mainly because its free to do but i don't think i will bother, i need to learn to be a better drifter before i worry about worry about massive extra lock, i just thought as I'm doing all this it would be good to do it all together but i think the tein rods and spacers will be enough for me for now.
  5. S6 Dan
    S6 Dan Member
    Good work glad to see another s13 being saved and not just scrapped
    keep up the good work its well worth it in the end
  6. Chunky Nugget
    Chunky Nugget honkeytits!!
    Aldershot
    Awesome work sir.
  7. pj9ar
    pj9ar Member
    thanks guys
    here is today's work :)
    i finished off the chassis rail
    i also repaired part of the suspension turret
    then i striped down the the front sub frame de-rusted and painted
    and the same with the rack
    and the same with the lower control arms i also welded in some reinforcement and i used ballistic steel so now they are literally bullet proof lol
    if i don't have to do any work again tomorrow i will assemble the front sub frame and start priming the engine bay, i got a feeling the other chassis rail is rotton in the same place so i will check that out too, which means i need more steel :smash:
  8. schnabulator
    schnabulator Member
    Germany
    you got a ton of rust 8P
  9. pj9ar
    pj9ar Member
    yea lucky me :(
    well we got work in so i haven't been able to do much.
    i cut out some round pieces
    used a magnet to hold them in place
    and welded up all the holes in the slam panel
    i then ground everything down and treated all the areas that had surface rust (i ground it all back to good steel anyway but just treated it to make sure) and etch primed everything
    i assembled the rack with the tein rods and ends, the new boots and bushes then i had to de-rust and paint the rack mounting brackets
    that's it for now i did a bit more today but forgot to take photos so will get some tomorrow.
    #9 pj9ar, Mar 27, 2014
  10. pj9ar
    pj9ar Member
    I've had a lot of work so I'm stuck to only working on it evenings and Saturdays :( but anyway what
    i done yesterday
    i removed the gearbox and exhaust to get ready to spray and the gearbox needs cleaning up and spraying, ive also been doing a bit of filler work to smooth out some of the welds, and yesterday i made a mount for the rad.
    i then striped down the hubs and cleaned up the knuckles and hubs, i through away the brake disc covers as they were rusty as hell I'm hoping there not to important been trying to search to see if anyone else is running without them but found nothing.
    bit of a before and after
    finally Ive had all the rust nuts and bolts in a tub of vinegar and they came out clean as a whistle but within 5 mins they started going rusty again as it had striped all the anodized coating off so i sprayed them with a long term corrosion protection spray, hopefully it will do the job :)
  11. pj9ar
    pj9ar Member
    been a while since i updated, i been busy at work not had much free time but back at it now so here goes.
    as i expected the other chassis rail was a bit rotten, its surprising as from the outside there was only one small rust bubble :eek: i was actually contemplating not doing it im glad i did, so heres what i cut out
    and here is only half of what i cut out, and the least rusty parts lol
    floor pan
    this is part of the front chassis rail and i was using exactly the same thickness steel this time so i copied them as closely as possible (with a few extra welds)
    welded in
    chassis rail
    made a template and cut out
    bent
    made adjustments and drilled holes for to weld
    welded in support
    and welded it in
  12. pj9ar
    pj9ar Member
    made some holes for for the intercooler pipes, use some 4 inch pipe to make it look better.
    and made some plates for the suspension mounting points
    got some pipe bent to brace the suspension turret to the fire wall which im guna do this weekend
  13. bigdave z20
    bigdave z20 Member
    Awesome metal fab skills dude. Impressive.
    Remind me never to buy an s13, they are almost all rotten!lol
    Good luck with the rest of the build! :)
  14. nathanielro
    nathanielro Member
    Milton Keynes
    Great work, it's nice to see another one saved
  15. Roo-ster
    Roo-ster New Member
    Ashford
    Good effort man
    Keep up the good work :)
  16. pj9ar
    pj9ar Member
    thanks for the comments
    welded in the bar
    filled and preped everything
    i cut the rad mount off because i didnt like it look a lot better without, i will have to figure out anther way of mounting the rad later
    test fitted the sub frame and nismo power brace to check everything is still strait and it is :D and so i can move it to clean the area for paint.
    got some dimple dies recently so added a piece to add some strength.... i think lol. it looks good anyway.
    a pic of about 3/4 - 2/3 of all the rust i cut its a great feeling seeing it all on the floor and not on my car.
    good to see her back on her feet
    i made my self a getto spray booth lol
    primmed
    4 coats of jet black base coat
    had a problem with the paint its gone wrinkly in 2 places both in exactly the same place either side does anyone know why its done this?
    thats all for now :thumbs:
  17. pj9ar
    pj9ar Member
    small update:
    got the lacquer on yesterday i used kapci lacquer which Ive read is good stuff certainly came out nice and shiny :) and i used some gold flake in the clear to jazz it up a bit:wack:
    this is 3 coats of flake and 4-5 coats (lost count i was working quick it went off quick lol) of just clear. im pleased with how it turned out, its hard to photograph when i get it rolling again i will get a pic out side with my slr.
  18. wigwambam
    wigwambam Member
    Nottingham
    Looked at a couple of crusty Nissans but people seem to want megabucks even for shells that aren't looking too clever at all. Walked away from a couple that were not as bad as yours. Awesome work that man!!!
    Just out of interest what thickness of steel were you using as it looks quite thick? I was struggling to bend 1.5mm into anything useful in my garage at home...I will be making some sort of makeshift bender before the next project I reckon.
    Golden flake looks well sexy
    #18 wigwambam, May 18, 2014
  19. pj9ar
    pj9ar Member
    the first steel i used was thick, im not sure what exactly it was but id say it was getting close to, if not 2mm the second lot i got was 1.5 and the original steel on the chassis rail was 1.4 but also used some 1mm for the floor pan and a few other bits.
    i will get a pic of my home made bender tomorrow maybe give you some ideas.
  20. bigdave z20
    bigdave z20 Member
    Paint in the bay looks class dude, nice one. Spray booth work a treat?
