For Sale Navan S14 1994 310hp
Thread in 'Drift cars for sale' started by lintgfx, Feb 22, 2018.
  1. lintgfx
    lintgfx New Member
    FOR SALE
    Nissan Silvia S14 1994 import navan kitted
    310bhp mapped at Horsham Developments
    Engine rebuilt to high spec with forged pistons, HKS 256 cams etc. The car in it's current state is ready to reliabily run 400hp with a bigger turbo like a gt2871 or a td06-20g with an electronic boost controller.
    Clocks showing 108,9xx but were changed due to them sticking at 125,120 which was a mixture of km and miles, the new clocks had 96133 on them. I have the old mot certificates to show this. The car has MOT until July 2018.
    The car hasn't ever been tracked it was stripped underneath, cleaned up, treated and undersealed, rear subframe was cleaned up painted and poly bushes fitted in 2015. Has never had or needed and welding, no rot apart from a scratch along the passenger side and a small spot coming through on the rear arch from cider being spilled in the boot and not realising it had gone down into the arch.
    Bodywork and paint is very clean for the age as some minor dents and minor surface rust on the shell from stone chips but hard to notice as expected from the age. The car also has scratches on the passenger side skirt from the same incident that caused the rust on the side. Interior is also very clean but has age related marks and the dash is cracked from the Japanese sun.
    Serviced every year with genuine oil filters, z32 fuel filters, 5w40 oil, gear oil and diff oil recently changed, diff recently reshimmed to make it tighter.
    The original engine spun a bearing in August 2016 it was replaced with a freshly rebuilt SR20DET which has the current spec:
    Forged 87mm Apexi pistons
    Cylinderblock bored and decked
    Ported and polished cylinder head
    HKS 256 Step 1 camshafts
    BC valve springs and titanium retainers
    HKS 740cc Injectors
    Apexi air filter
    Z32 AFM
    Vernier cam pulleys
    New OEM rockers
    Rocker stoppers
    ARP conrod bolts
    Siruda 1.5mm MLS headgasket
    ACL main bearings
    ACL rod bearings
    High capacity baffled sump
    New gaskets throughout
    New timing chain
    FMIC with pattern pipework, fitted so bumper wasn’t cut
    BKR7E NGK sparkplugs
    Hdev exhaust manifold
    standard turbo, braided lines, manual boost valve set to 18 psi
    Forge recirc valve
    Japspeed downpipe
    Flexi decat also will come with standard CAT
    3” catback exhaust from a Japanese company I've never heard of
    Gearbox was rebuilt before I bought the car
    Nismo short shifter and gearknob
    Non abs model
    Air con fully working
    New battery
    Shimmed non abs diff
    Driftworks lightweight flywheel
    Competition clutch stage 4 clutch 6 puck
    Interior:
    Black leather fitted
    Nardi deep corn steering wheel with nardi boss
    Boost gauge
    Electric folding mirrors
    Climate control
    Non airbag dash
    Spare wheel with jack etc
    Uprated speakers and Eonon double din headunit
    Nismo black gearknob
    Exterior:
    Genuine navan front and rear bumpers with all lights and grills
    Fibreglass navan sideskirts
    Fibreglass navan rear spats
    Navan front grill
    Jdm boot spoiler with brake light
    Non brake light bootlid
    Non rear wiper rear window
    Glass headlights fitted
    Fog light in place of one reverse light
    Chassis:
    Yellowspeed coilovers
    Polybushed castor arms
    Polybushed rear subframe
    S15 front brakes
    Braided brake lines
    Fully cleaned up, treated and undersealed
    Rear arches have been rolled
    Work Emotion CR Kai 18x9.5 ET12 wheels 225/40/18 Uniroyal RS3 front Goodyear rears plenty of tread left
    Also have a spare set of AVS 17x8 front 17x9 rear wheels with 20mm spacers (last photo) that can be sold with the car instead of the Works although the rear tyres aren't road legal
    Fully laser aligned
    I have a set of Evo front brembos with second hand discs, pads, braided lines and adapters that are a straight bolt on fit that can be sold with the car.
    I may have forgotten a few things but if you have any questions don't hesitate to contact me.
    07495619765
    £6700 with work wheels and brembos
    £6400 with works OR brembos
    £6000 with AVS wheels no brembos
    Located GL11
    lBSUlhA.
    5sHMqy5.
    fawTVP7.
    Xc7atLB.
    hBXSSrq.
    spGyshc.
    5Z1aIrl.
    UM7TS3B.
    CCxQW2N.
    8NO6nku.
    WKLm4js.
    yOyiobc.
    au9oC02.
  2. lintgfx
    lintgfx New Member
    bump
    • Optimistic Optimistic x 1
  3. jackyg rs
    jackyg rs Member
    Be interested if I can shift my chaser!
  4. lintgfx
    lintgfx New Member
  5. japcarsbrett27
    japcarsbrett27 New Member
    callington cornwall
    ok im confused about the mileage as the mot history says miles on some and km on others and it goes back and forth? is it in km now and has the speedo been converted to miles?
  6. lintgfx
    lintgfx New Member
    I'm guessing that's just due to the tester because the speedo has kmh printed on it
  7. lintgfx
    lintgfx New Member
    Deposit taken.
  8. lintgfx
    lintgfx New Member
