New silvia "bricks" headlights aftermarket startup.
Thread in 'Parts for sale' started by Mike rempkowski, Sep 12, 2021.
If you don't want to pre-order, would you order if stock was on hand?
  1. Yes
    33.3%
  2. Still no
    66.7%
  3. I'm in for pre-order
    0 vote(s)
    0.0%
  1. Mike rempkowski
    Mike rempkowski New Member
    So we just started a company selling new "bricks" s13 headlights called brixxllc.. we are currently taking pre-orders to begin production. We need 450 more orders to afford to manufacture these. I will attach some prototype pictures to reference the fit of my design and some renders to show what the final product will look like when completed. They cost 383usd+tax and shipping, international total comes to around 520usd. We are based out of Mesa, Arizona, USA. US total with tax and shipping comes to around 420usd. The time to start shipping after the order quota is met or when we find an investor will be 60-90 days. The headlights will be constructed with ABS plastic with the reflectors being chromed post process and lenses will be polycarbonate like most headlights today. If you have any questions you can email brixxllcsales@gmail.com or message on Instagram or Facebook @brixxllc. The website for pre order purchase is Brixxautomotive.com thanks for the read.
    IMG_20210908_130011_553.
    IMG_20210908_135548_432.
    IMG_20210908_130011_405.
    IMG_20210908_130011_584.
    FB_IMG_1631455234873.
    FB_IMG_1631455229971.
    FB_IMG_1631455219518.
    FB_IMG_1631455224899.
  2. smokebillowing
    smokebillowing Active Member
    I'd take a set. Do you make any with clear lenses?
  3. crazyae86
    crazyae86 Well-Known Member
    any luck for s14 ( not S14A ) ???
  4. Mike rempkowski
    The final product will have clear lenses, the photos are of the prototype for fit references
  5. Mike rempkowski
    There's already a few options for the kouki. If anything I might look in to making zenki lights in the future
  6. omgyjya_switch7
    Are these lights designed for left hand drive cars only or will the lights sent to the UK be modified to suit right hand drive?
  7. Mike rempkowski
    It's complicated and simple. I'll try to explain. So the oem reflector that holds the bulb essentially holds the bulb slightly crooked to raise the beam on the lh side. I designed both sides flat so there is no left or right bias. If you use halogens there's nothing you can do about getting a higher beam to see street signs. But if you use LED's they have a ratcheting twist adjustment which someone could twist the curb side to be slightly up to be able to read street signs clearly. Hope this helps.
  8. r3k1355
    r3k1355 Well-Known Member
    If you're using reflectors and not projectors then it's illegal to use HID or LED bulbs in them over here, so that fix won't work.
  9. Mike rempkowski
    They are not intended for street use. Offroad use only. Like most other aftermarket parts.
  10. smokebillowing
    Sweet, yeah i'd be interested then
  11. smokebillowing
    Did you end up making these?
