Nissan 200sx 1985 (S12) #rb25 #fullcage #s13
Thread in 'Project Cars and Builds Threads' started by rb25_s12, Feb 10, 2014.
  1. rb25_s12
    rb25_s12 Member
    Come read this , crazy build here
    Hi guys, am from quebec canada, i follow this forum for a while and one of my friend told me to put my build here. Am not an anglophone so please excuse me if my sentences are kinda weird sometimes but i will do my best. I will update the thread shortly to explain and everything.
    2013 History:
    I bought this "car" as a non-rolling chassis in February 2013. The chassis was in good condition so far (here in canada we have huge winters so our cars don't have the life easy). The car was stored since 2008 but it ran only for few months. Before theses months his last days as a daily driver was back in 2002.
    Photo when i bought it:
    The car needed a lot of work to put it back as a rolling chassis. Maybe i will update the progress someday. Here's what it looks in the beginning of may
    I painted the car myself with some rustolum paint, decent job
    When i bought the car it has no engine. I got a deal for a rb25det.
    I redo and repainted all the interior too.
    The last owner tried to swap an s14 coils-over on the car but his shock tower was horrible as you see in the beginning pictures, i had no choices to redo them but the s14 struts are extremely long so it looked like crap.
    Dyno ready
    Putted down 264whp at stock wastegate psi (8 i think)
    I drifted the car all summer long but the problem with theses cars are the rear semi trailing arm suspension geometry. I bend my two lower trailing arms in the summer (poor arm conditions because of rust). So i thought to myself that it would be nice to have an s13 rear subframe assembly to get their geometry so it began as my winter 2014 project. Heres some random pic of the car in the summer:
    So this is it for tonight and for 2013. I will update the post tomorrow for the 2014 build-up.
    Here's a preview:
    #1 rb25_s12, Feb 10, 2014
  2. rb25_s12
    rb25_s12 Member
    2014 winter project.
    This winter my project for the car was:
    1-Fix the overheating issues (i had a stock rad and a push type fan set up.. )
    2-fitting the s13 subframe assembly
    3-Full interior roll cage
    4-tubular front end (for rad clearance)
    5-custom s13 overfenders + fender flare in the front
    6-Ackerman cancel + widened lower table in the front+push the steering rack forward + custom knuckles
    7-new suspension set up
    So it began slowly in november 2013.
    With the lack of a lift, and with the amount of work underneath the car i decided to flip it upside down.
    Old subframe assembly
    S13 subframe assembly test fitting
    With the amount of work to do, i decided to correct the rollcenter. So i pushed the subframe the farthest up to the inside of the car.
    The subframe pik up points goes directly into the rollcage, so in the front i made some sitting plate and putted my tube straight in the inside of the car
    I also putted the exhaust straight into the car frame rail. For more ground clearance.
    Car flipped , ready for the rollcage.
    For the cage, the idea was to build a chassis structure that will support the subframe and his forces stress. So i began with the roll bar.
    I had to build the rear subframe supports. I made them directly in the cage
    The seat bar, note that the seat will go down.
    Here comes the bracing time. I had to build new shock tower because of the subframe so i saw on the net that some folks from GKTech.aus were doing an s13 tubular chassis. I got my inspiration from them to do the shock towers. A good friend of mine here in quebec build drift cars for maybe 4 years. He gave me a lot of tricks and helped me a lot. His shop is called Pro-fusion. So here's the rear cage structure.
    Update on next post
    #2 rb25_s12, Feb 10, 2014
  3. rb25_s12
    rb25_s12 Member
    I also redo the driver floor pan
    And i finished the rear brace for the frot subframe pick up points
    I had to close all the floors too
    Finished the A-pillars
    I did my doors bar this week saturday
    I also welded my a-pillar gusset and my roll bar gusset
    Fitted the asd e-brake
    Shaved up the bay and started the front end
    The upper rad support bar is missing in the front. After that it will be done for the front end. The last picture is yesterday (sunday 9th February) so the next updates will be done in comments.
    Thanks
    Alex.
    #3 rb25_s12, Feb 10, 2014
  4. rd-jon
    rd-jon Member
    Coldstream, Scottish Borders
    Looks interesting :thumbs:
  5. DanMateX
    DanMateX Member
    in for the progress updates, love a s12
  6. rb25_s12
    rb25_s12 Member
    Massive update
  7. chodjinn
    chodjinn Active Member
    Awesome work on the cage!
  8. rb25_s12
    rb25_s12 Member
    I just pick them at the post .
    Hicas canceller plates
    Test fitting the ride height
    #8 rb25_s12, Feb 10, 2014
  9. rb25_s12
    rb25_s12 Member
  10. sparky_s13
    sparky_s13 Active Member
    South Wales
    Holy shit that is awesome!
  11. DORI STYLE
    DORI STYLE Member
  12. Doritofu
    Doritofu Active Member
    NZ
    It's awesome to see an S12 being done properly and looking this badass. You gotta keep the steelies.
  13. t3nhp
    t3nhp Member
    Epsom
    Quality s12 build, looks the business
  14. adisoruc
    adisoruc Member
    Aberdeen
    i love your project! Good luck guys!!
  15. rb25_s12
    rb25_s12 Member
    Thanks guys. For the wheels i put them :
    #15 rb25_s12, Feb 12, 2014
  16. rb25_s12
    rb25_s12 Member
    The quality is amazing
  17. rb25_s12
    rb25_s12 Member
    Passenger seat
    Front end rad fitting
  18. Radiuz
    Radiuz Member
    Nice work, always good to see someone building their own cage themselves too!
  19. poju89
    poju89 Member
    Awesome work!
  20. rb25_s12
    rb25_s12 Member
    Rad support /hood pin support.
    Extended lower control arm
    And the car take some fresh air to allow me to clean the garage
    Tomorrow my buddy from wideworks canada come to fit his custom s13 overfenders on my s12. Should be sick.!
