Nissan 200sx s13 1jzgte
Thread in 'Drift cars for sale' started by Tomae86, Sep 2, 2017.
  1. Tomae86
    Tomae86 Member
    West Yorkshire
    nissan 200sx s13 drift car
    Basic run down of the car toyota 1jzgte engine with r154 box, front sump, driftmotion turbo rebuilt by universal turbos with garrett internals, driftmotion manifold, 46mm tial wastegate and screamer pipe, 50mm alluminum radiator, 90mm intercooler with 3" outlets engine makes 450 bhp at 1.4 bar boost 400bhp at 1 bar. mapped by greg gush of pro tuner. injectors are 550 with the correct resistors. custom engine and gearbox mounts. driftmotion light flywheel with act paddle clutch, prop shaft is a mix of r154 to nissan made by dave mack propshafts professionaly done. shell was a clean 1990 car when bought has had some welding but this is 25 years old so its to be expected. roll cage is a fabricage bolt in with double door bars. it has 2 bucket seats one is a recaro the other is a cobra monaco both are out of date complete with driftworks 3 inch harnesses. it has a fully built in fire extinguisher system complete with pull cables on the bonnet for engine cut off and fire. the dash has been cut around the cage, the original clocks have gone and it now runs a racetech tacho, oil and water temp. oil pressure and greddy boost gauge. driftworks hydraulic handbrake with wilwood slave cylinder. 50mm wider front wings with 50mm rear over fenders , the paint is not amazing but is clean and tidy. the fuel system comprises of a walbro lift pump with 2 litre swirl pot with bosch 044 pump all fuel lines are motaquip braided. it has meister coilovers with a mix of driftworks and japspeed adjustable arms for camber, caster front and rear toe. driftworks geo masters front hubs so loads of lock the wheels are rota think they are gtr 9.5x17 on the back 9 on the front not sure on the et but pretty low 22 ish brakes are s14 front with drilled and grooved discs with z32 rears still runs the standard handbrake for parking. it is a well set up car which over the years has competed in drift all stars/ French drift cup/RDC and drift cup. Always has been reliable never let me down will be sad to see it go perfect for someone moving up to competition. Has 10 months MOT and have log book for it. probably missed something out please phone for more info 07850442177
    £7950
    IMG_2568.JPG IMG_2569.JPG IMG_2570.JPG IMG_2571.JPG IMG_2572.JPG IMG_2573.JPG IMG_2574.JPG
  2. Barnesy
    Barnesy Member
    Manchester
  3. jap scrap
    jap scrap Active Member
    Mayo, Ireland
    what ecu is it running
  4. Tomae86
    Tomae86 Member
    West Yorkshire
    Sorry this is now sold
  5. jap scrap
    Mayo, Ireland
    Thanks anyway
