So I have made the very hard decision to put my 200sx s14 saab engined drift car up for sale. Firstly I am not in a rush to sell and I will keep the car if I don't get the asking price and finish it when I can afford to. As far as I am aware there is 1 other b204 s14 in the UK. I have plenty of photos of the car from before the build started all the way up to where it is now. I would advise anyone interested to please view the car rather than deciding on it by seeing pictures on the internet. A lot of work has gone into the car and it needs to be seen to be appreciated. The shell has been taken to bare metal and under sealed properly with rot removed and repairs carried out. Firstly this car is an 80% finished project and was built to be a competition car not a road car, that being said I do have the v5 and it could potentially be mot'd. I started to build the car back in 2017, it had been used at a few drift days and there were some significant issues with the suspension so the decision was made to sort it all out, during this time I decided it would be best to just completely rebuild the car as I was planning on competing in 2018. The build ended up being a lot more than I thought it would and before I knew it I was replacing everything on the car. I haven't had the time and money to get the build where it needed to be over the last year or so and now I have completely lost all love for the car and drifting itself. So the car, Its an M reg Nissan 200sx s14 manual UK model. The cars underside has been completely wire wheeled down to bare metal and undersealed with schultz, any rust and rot has been cut out and replaced (by myself) New chassis rails fabricated and welded on All the suspension arms have been replaced with adjustable arms (minus rear traction) Apexi coilovers, fully adjustable All bushes have been replaced with polybushes by driftworks and rear subframe and diff are solid Running stock size breaks with drilled and grooved disc and uprated pads Rear boot floor cut and fuel cell fitted with 044 (rep) pump, swirl pot, new filter and fresh braided lines (requires lift pump) Front end has been cut and tubed (have a rough front end mocked for mounting lights etc) Have rear quater windows and door glass still, front windscreen cracked Interior completely stripped Single drivers bucket seat (homemade rail) x2 harnesses Still has dash board Door inners cut out Has a full body kit that will require some work to be perfect again some of which has already been started 25mm front wings and 30mm rear overfenders 25mm wheel spacers front and rear DRIVETRAIN Saab b204 turbo engine t25 turbo from a saab 9-3 Custom oil and water turbo lines and fittings Bonnet exit exhaust off top mount turbo 3 bar map sensor Stage 3 ecu running t7 apc (roughly 270-300hp) Saab viggen clutch Saab solid flywheel Omega gearbox with slave spacer Custom braided clutch line Custom CNC made engine and gearbox mounts Custom made front subframe for sump clearance Braided clutch line Custom made sump (will require baffles for extra safety) Bmw and Nissan prop shafts for making custom 2 piece shaft Oil take off made from billet with oil lines, external filter housing and oil cooler (uses mx5 filters x2 spare filters) Large alloy radiator (damaged but usable no leaks etc) Custom fuse/relay wiring and switch panel Full wiring loom for engine The engine is fully fitted and the car does run, to get it driving it will require a propshaft making. To have the car completed fully I would say it would need: Propshaft paint and bodywork windows tube front wiring completed (lights and body accessories etc and loom tidy up) This would see the car usable at drift days etc but would require more if you wanted this car to be perfect. I currently don't have wheels for the car so buyer would need to bring wheels or I can sort some for an extra cost. Car will obviously need to be taken via trailer. Any spares and parts I have will go with the car. The car needs someone who has the means to finish it, it will be a well built car when its finished and be one of a kind. Price is £3500 firm for the car as is with everything I have. I am not looking for a swap or trade. Cash is king, first to turn up with the cash can have the car. Delivery is also available at extra cost. If any more info is needed please get in touch and as above I urge any interested parties to view the car in person, I have a lot of photos of the build available to show whats been done so don't hesitate to get in touch. {} {} {} {} {} {} {} {} {} {} {} {} {} {} {}
Damn, if I had the cash I'd be all over this! Watched a bunch of your youtube videos and you've put some amount of work in! Well worth the price! GLWS - Free bump
I STILL HAVE THE CAR AND IT IS NOW RUNNING WITH PROPSHAFT JUST NEEDS A CLUTCH BLEED. ALSO HAVING A TUBED FRONT COMPLETED THIS WEEKEND (13/12/20) AND WILL BE PUTTING AN EXHAUST TOGETHER AFTER THIS IT WILL MAINLY BE COSMETIC WORK TO BE COMPLETED WILL BE RELISTING ONCE THESE JOBS HAVE BEEN COMPLETED Cheers man appreciate it, it's been a long old build like
