Nissan Gloria 90's Vip. Update 30/8 manual swap!
Thread in 'Project Cars and Builds Threads' started by ianlea73, Jan 24, 2018.
  1. Adam-MGTF
    Adam-MGTF Member
    Teesside
    The 4 door is just sat there atm, it's in need for some proper rust treatment. it's not full of holes. but 1 or 2 more winters and it'd be totally shot.
    Message a bloke called mike sanford and search for a company called automodz on facebook. They are the 2 main guys who brake and work on z32s :) Manual boxs have suffered nissan Tax a bit of late. But if you see a NA one then don't be put off - unlike most nissasns the na boxs are as strong as TT. Just a different starter motor (as the TT has a larger flywheel)
  2. ianlea73
    ianlea73 Well-Known Member
    Bristol
    I've been looking at Z32 or Z31 manual parts. I'm not on Facebook dude but any contact info is appreciated.
  3. ianlea73
    Bristol
    Finally got the split rims sealed & the tyres fitted. Completely changes the look of the car.
    Just got the rears to do next!
    20180405_171544.
    20180405_171552.
    20180405_171606.
  4. ianlea73
    Bristol
    I also ripped out all the a/c system in the engine bay including the compressor & radiator. There's so much more room in the bay without all the rubber & hardlines.
    With the car in the air I noticed my tension rod bushes were a bit shagged so I fitted the hardrace ones off my S13.
    20180405_115743.
    20180405_113135.
  5. ianlea73
    Bristol
    When I got the car it had a Japanese no name cheap mushroom filter with random pieces of pipe from the turbo. It was crammed right up in behind the headlight.
    I had an apexi filter from my rb25det so I removed all the pipework & changed it up so the filter has more room to breath.
    20180405_140125.
  6. ianlea73
    Bristol
    I've been asked to show a few pics of my intercooler pipework so I hope this helps.
    20180308_160629.
    20180308_120849.
    20180405_140130.
    20180405_140138.
    20180405_140144.
    20180405_140147.
    20180405_140153.
    20180308_120915.
    20180405_140108.
  7. jbsauce
    jbsauce Member
    Those fake brides off ebay are getting good these days.
  8. ianlea73
    Bristol
    Yep fakes but very comfy!
  9. side slide
    side slide Member
    Manchester
    Hi bud, not checked in on this for a while but fantastic progress, with regards to the intercooler can you show me the setup to the inlet manifold?
    Yes 7 mpg. I assume the car is broken somewhere some pics of the big turd for you. 20160430_190114. 20160715_143832. 20160715_143641. FB_IMG_1459776411009. FB_IMG_1459776415135. FB_IMG_1459776418839. FB_IMG_1460920950882. FB_IMG_1460921000323. FB_IMG_1460920955484. FB_IMG_1460920966570. FB_IMG_1460920972160. FB_IMG_1460920976436.
  10. ianlea73
    Bristol
    The rear light bulbs always looked really dull & there was condensation in the housings so I wanted to investigate.
    So I pulled the light off the car & released the bulb holders. On inspection the light lenses are actually clear but have red vinyl on the lower half.
    When I pulled the bulbs out I noticed why my indicators look dull. The bulbs has been sprayed gold!!
    Refitted the lights with led brake/ lights & capless indicators.
    2739cfced771.
    f12026b8829c.
    Repeated on the passenger side.
    I know it's a bit marmite but as the parts are aftermarket & original to the car when imported I think it makes it even more individual to any other Glorias out there. 75ae7c6dcb83.
    85b130ca21e4.
    On inspection the front indicators are also covered in lense tape so when I remove the complete units I'll strip & sort them out too.
  11. ianlea73
    Bristol
    In preparation for the front hub change I needed heavier spring ratings than the ones on my bc coilovers. Those were for my s13 which is obviously a lot lighter.
    After a search I found some on here which were ideal. 16kg hsd springs.
    They arrived today so I stripped the coilovers down & changed the top mount for a pair I bought from Diggory on here.
    Then I built them up.
    So if all goes well I'll start the front end swap this week.
    20180416_123914.
    20180416_124009.
    20180416_124655.
  12. ianlea73
    Bristol
    Started on the lower arms as they are s14.
    Knocked out the balljoints & burnt out the bushes with my propane gun.
    20180416_173213.
    20180416_173205.
    20180416_165914.
  13. ianlea73
    Bristol
    I've ordered new powerflex inner bushes & balljoints. So for now I'll clean them up ready for paint.
    20180416_173135.
  14. WaynJohn
    WaynJohn New Member
    Florida
    I love these pictures:-) Thanks man. I used to have a Nissan but not in this class. Very nice work! :-)
  15. GeorgeHampl
    GeorgeHampl Member
    Surrey
    this is exactly what happens to rubber bushes when they are done up not being in their "ride-height" position.
    cool project
  16. ianlea73
    Bristol
    Thanks guys it's nice to get a bit of feedback.
  17. dave325i
    dave325i Member
    Ireland
    Love this car and how your keeping it how it was imported.
  18. ianlea73
    Bristol
    I took the lower arms to my mates unit & shot blasted them, gave them a prime & paint. Then a couple of coats of lacquer. Fitted the new inner bushes supplied by driftworks. Just waiting on ball joints & I can build the front end.
    20180419_163949.
  19. ianlea73
    Bristol
    Also removed the headlights to remove the old grill brackets & fit sidelight bulb holders.
    Originally these are located in the bumper with the front fogs.
    So I had to strip & split the lights. I wanted to fit the oem bulb holder so I dremeled the fitting.
    I also stripped the orange lense tape & fitted an orange bulb to the indicators.
    20180418_122239.
    20180418_122244.
    20180418_122318.
    20180418_132433.
    20180418_164111.
    20180418_164513.
    2018-04-20 17.11.13.
  20. ianlea73
    Bristol
    Pulled a bit more of the interior out today & found a nice ecu.
    Impul Y32-1203.
    Does anyone know how I can get any info or tune info from it?
    20180421_174303.
