up for sale is my c33 laurel project, its not that far from being finished but i just dont have the time looking for £4000 or part ex or swaps brought the shell non rolling, used to be owned my sid crowfoot BODY laurel c33 shell brand new hsd coilovers never been used brand new driftworks front tension arms modified front knuckles 30mm extended front lower control arms poly bushed brand new longer steering rods and new track rod ends whitleline front anti roll bar poly bushed 5 stub hub conversion all round s13 rear subframe solid subframe bushes brand new driftworks rear arms whiteline rear anti roll bar poly bushed welded s13 diff s14 front brake braded brake lines front and rear front and rear lights front grill front and rear bumpers 30mm real wheel spacers bonnet has a few dents Wheels 5x114.3 18" x 10.5j rota boosts brand new 225/45/18 tyres ENGINE rb20det gtst rb25det turbo and manifold braded turbo and water lines front facing plenum acl bearings metal head gasket mines jdm ecu alloy rad oil cooler and lines paddle cluch rb20det gearbox hpi intercooler head oil drain wiring specialist coilpack loom INTERIOR stripped out full bolt in fia fabricage carbon unbranded bucket seat from japan super low drift works seat runners race tech 2 digital dash brand new still boxxed to finish this it needs the shell has a little rust that need repairing needs a custom prop made up iv got the ends to send away exhaust may need a new front hub bearing need to get a r32 gtst wiring loom and have it wired in needs digital dash wired in unless changed back to original clocks that i dont have car does not have a fuel tank but is already flat floored so can bolt a fuel cell and pumps down brakes and clutch need bleeding rack relocation spacers to go with the modified knuckles skyline power steering lines intercooler pipework and a full going over the car its 90% dead straight but front bumper needs so work as it was has been run over and dragged in front on the car would make a pretty awesome car once painted and a kits been fitted
Alright man, I know I am a bit late on this post. Don't suppose you still have the front and rear standard bumpers for sale? Text me on 07515483595 if you have Thanks.
