Nissan S13 200sx 1JZ ( DriftWorkShop )
Thread in 'Project Cars and Builds Threads' started by Eddyprorace, Oct 17, 2018.
  1. Eddyprorace
    Eddyprorace New Member
    Hello and welcome to my Thread !! ( YOU WILL ENJOY LOADS OF JAPANESE BEASTS )
    My Name is Eddy as listed, and im a drift car project builder. specialty inthe field of nissan S-Chassis and Z-Chassis.
    I will first post up some photos for you to enjoy, then i will take you over my project step by step, as we will cover over in minor details the way i install and get things done.
    I know this thread will be of help to all of those who struggle with JZ swaps into s13,specially in the wiring section.
    Enjoy the Thread! give me your thumbs up of you like it, and DO NOT HESITATE to ask any question you have, on the thread or by PM..i would love to assist and help as much as i am able.
    cheers and boosted regards from the JDM COMMUNITY LEBANON IMG_20181011_003056.
    Below is a photo taked 2 days ago when i fitted my intercooler piping. i will be posting updates photos tomorrow as i finished closing off all the systems, AIR, WATER, FUEL, ENGINE OIL and PS. IMG_20181013_080731.
    Below is a couple of photos of the car seated in my private workshop after i installed my rocket Bunny v1 fender flares... i wont install a full kit, i am making something different with a diffuser project in the future.
    IMG_20180926_192136. IMG_20180926_192036.
    With Mad Mike, Alex and Robbie at RedBull World FInals King of Drift our Team Driver Oliver Kik Took First Place on his LSX 350Z!! will post up photos soon for you guyz !! IMG_20180922_140338.
    Egyptians Redbull Car park Drift King of Drift at the world Finals ! they took Third place over all on that 2JZ powered S15 Silvia... i must say, it was one hell of an S15 IMG_20180922_124231.
    Below, Will Jordanian 4 Times Middle east Redbull King of Drift, red bull driver,and good friend Ahmad Daham! he owns an s15 silvia 3.4 liter stroker 2jz.. he is a tuner as well. but for this competition he decided to lend a local friends car.. 2jz powered e46 850HP
    IMG_20180922_135846.
    Below, Back in 2014, at my backyard workshop. 2 more s13's rested inside !!!!
    FB_IMG_1538529259821. Below, My 240sx powered by ca18 stroker from JUN. 2.0 liter 9000rpm.. i took the engine out for future project and sold the car as a rolling chassis with coilovers, interior as it is, gauges, sumitomos and volks 17inches. FB_IMG_1538529216886.
    Bellow, Hand made Plug and play patch harness to fit my Greddy Emanage Ultimate
    FB_IMG_1538529232835.
    Who isnt a fan of Bee*R ?? i simply love that unit and never had any issues with it. if wired rightly it lasts a lifetime! FB_IMG_1538529298160.
    FB_IMG_1538528976753.
  2. Danimaldrifter23
    Have you wired the standard ecu and harness into the s13 ? If so how have ypu done it . Thanks
  3. Eddyprorace
    i installed the standard ECU and stock JZ EFI harness with stock injectors... but i havent yet wired them to the s13.. i am finishing up some other work on the car .. i leave the electrical for last !!
    I will for sure update the details of my wiring and explaining by color codes from both engine efi and body harness of the s13 !!
    if you will stay updated, you will get the information that you need. probably will wire up during next week if nothing stalled my process !
  4. Eddyprorace
    Hello again everyone.. this is my s13 currently sitting on volk te37. bellow the pictures of new paint for the wheels. i will post later tonight a photo of the car sitting on 4 painted te37 after i install my rear s14 5 lugs !!! IMG_20181026_150917. i used p400 wet sand paper to smoothen out the surface.. it is recommended to use 1200 for final give, but my paint can handle the 400 pretty well!!! IMG_20181027_153811. Here after the paint, and before the Lacquer coat.. i mixed it myself using Green metallic, Dark Navy Blue, and Metallic Silver to get the turquoise i want !! IMG_20181027_180042. Night Photo of the what the wheels look like After Lacquer !! STAY TUNED FOR DAY TIME PHOTOS !!!! IMG_20181027_181628.
    IMG_20181027_153955.
    IMG_20181027_172917.
    #4 Eddyprorace, Oct 28, 2018
  5. Eddyprorace
    Hey Man... i have had the car running now for about a month or so.. all good . the wiring is pretty simple.
    IF YOUR EFI HARNESS IS CUT-FREE then your job is easy.
    first of all,you need a couple of wires to wire up you Battery (Power) to the engine, alternator and starter.
    Next you need to wire the ignition signal wire coming from the ignition switch itself ( if you have a clean wiring chassis, u can find that wire somewhere in the engine bay ) or u can also run a new wire through the fire wall and splice it properly ( solder and shrink tubes ) to the ignition switch ( the switch that activated the starter relay ) so if u still have your stock starter relay fitter, then u can use the wire out of that relay that activates the starter... the engine will crank.
    At this stage its good if u want to have oil in the engine and cranking it up to pressurise the galleries, i would also take compression at this stage ( fuel pump fuse taken out, throttle pedal fully pressed, crank for 10 revolutions ) repeat same process on all cylinders, make sure to always tighten well the gauge... PS : if there is dirt or dust or anything near the coil packs, blast with AIR before taking off the spark plugs.
    Next in the wiring is to wire up the ECU. 3 or 4 wires depending on your model, and the engine will RUN and idle - JUST like THAT.
    B+, BATT, B , GROUND. those are the wires you need to wire up. ALL fused 7.5.
    u need to give constant 12v from battery, or from ignition switch which is where u put ur key in. there, you can a wire that always has 12 v. splice that up and give that 12v power to B+, BATT, B.. and there is a ground or 2 that u need to give the ecu.
    PS : IF ur car doesnt run, there might be an extra wire from ecu to the igniter. ( ofcourse of all other connections are proper and spark plugs are new, fuel pressure is delivered, and u have pulse and 12v on injectors and coils )
    let me know where are u stuck at the moment and what excatly is fitted to your car, and il be able to help you further, even give u ecu pins locations that u need to wire, and all the rest.
    IMPORTANT :
    ALL ELECTRONICS MUST BE RELAYED AND FUSED AND WIRED PROPERLY
    FUEL SYSTEM MUST HAVE GOOD PRESSURE AND SEALED WITH 0 LEAKS OR FUEL PRESSURE DROPS
    BREATHING SYSTEM MUST BE COMPLETELY SEALED WITH NO LEAK ( INTAKE / EXHAUST )
    ENGINE OIL CHECKED WITH NO LEAKS
    COOLANT IS LEAK FREE
    ps : you can get your engine to a first start up ONLY without FMIC piping or water or exhaust. .
    enjo your build
