Nissan S13 ca18det complete engine and gearbox 300bhp stage 3
Thread in 'Parts for sale' started by danjohnston92, Oct 13, 2017 at 12:07 PM.
  1. danjohnston92
    danjohnston92 New Member
    full complete 300bhp nissan Ca18det engine and gearbox can potentially be broken for parts 134k mix of miles and Km, was told rebuilt @90k although no proof
    seems to be slightly low compression on 1 cylinder, could be valves, worst case scenario piston ring?
    engine swapping anyway so haven't got time to look into this further.
    tested 145 / 144 /145 / 120 on cold engine
    also slight leak from turbo gasket if this may be effecting?
    starts first time, can be heard running before removal on the 14th october.
    spec:
    New t28 turbo and tubular manifold
    ported and polished intake manifold
    Z32 afm and cone filter
    mines adjustable FPR
    fenix alloy rad
    Greddy intercooler
    stage 3 ECU from turbonoz
    walbro 255 pump
    and parts i've forgot
    can potentially sell as whole engine and gearbox or can split to block/ gearbox/ stage 3 turbo kit (ecu, turbo, manifold etc) loom/ all other ancillary's.
    any questions please contact on 07710258474.
    20171007_173626.
  2. danjohnston92
  3. danjohnston92
  4. danjohnston92
  5. danjohnston92
    after first inspection everything seems to be fine.. wondering if it was just a sticky valve and the fact it hadn't been run in over a year, seems to hold pressure in cylinders, maybe a gas leak, engine seems sound, all parts are pretty much available minus a few bits and bobs.
  6. danjohnston92
https://www.googletagmanager.com/gtm.js?id='+i+dl;f.parentNode.insertBefore(j,f); })(window,document,'script','dataLayer','GTM-BR4Q');
