Nissan s14 with 1jzvvti
Thread in 'Technical Questions' started by Leonard Gunderman, Nov 20, 2018.
  1. Leonard Gunderman
    Leonard Gunderman New Member
    Hamburg nj
    Hey guys new to this forum. I have a s14 with a 1jz vvti I just picked up, I am trying to trouble shoot a issue I've bin having (stock motor) beside aftermarket intercooler exhaust and clutch set up. So the car idles a little high around 1200 to 1500 rpms ( no air filter on it maybe be a issue there) car revs great will idle and rev forever but as soon as you start driving it dies...so I jack the back of the car up and tried it and it didnt dir out only stayed in first gear...so has anybody had a issue like this or know what it could be
    20181117_162731.
  2. MaccyD
    MaccyD Active Member
    Norfolk
    Put some hose on the MAF, thaty dont like being free to air like that. Its a start at least
  3. Leonard Gunderman
    Hamburg nj
    Ok ....do you think that has something to do with it dieing when driving it
  4. Leonard Gunderman
    Hamburg nj
    What else guys does anyone else have any input I gotta get this thing going
  5. Leonard Gunderman
    Hamburg nj
    When it's in gear and you start to drive it will die.....I jacked the back of the car up and put it in first and gave it a little gas got it to about 2500rpms in first gear and it didnt die it stayed running I cant figure it out..
  6. MaccyD
    Norfolk
    Just if you have one, put a hose on the MAF. It makes the flow through them more regular and less turbulent so it reads better. It will definitely have an effect, if it will fix it or not i dont know, but it will run crap without, so will make it harder to identify another problem.
  7. Leonard Gunderman
    Hamburg nj
    Ok thanks I'll let you know what happens when I do that
  8. Leonard Gunderman
    Hamburg nj
    Ok guys so I put the filter on idles fine but as I start to drive it shuts down and take About an hour of the car just sitting before it will fire backup
  9. Murf
    Murf Member
    Bangkok
    Any trouble codes?
  10. Leonard Gunderman
    Hamburg nj
    Cant tell it's not wired to dash
  11. Leonard Gunderman
    Hamburg nj
    Any way to tell other then counting check engine lights
  12. Murf
    Murf Member
    Bangkok
    You are pissing in the wind.
    Get the light wired up, it's not difficult. That should point you in the right direction, even if it throws no codes up at least you know what it isn't.
