For sale from my Nissan RB20det (all items in good working order): Air filter with z32 MAF adapter - £30 Braided Oil feed for turbo (from HKS, but long enough for a top mount. turbo fitting is M12x1.25) - SOLD HKS Adjustable actuator with brackets - SOLD Holset Adjustable actuator (brand new & will fit Nissan turbos) - £30 Nissan RB20 viscous clutch fan in good working order - £35 (I've moved the clutch housing from behind to in front of the fan, which sets the fan back towards the engine about an inch. I've trimmed the backs of the blades slightly for clearance to the pulleys. This mod gives you more clearance for a thicker radiator, and reduces risk of the fan catching the radiator core when the engine pitches under load. Kept my engine cool no problems!) Rear Nissan S14 brake calipers in good working order - £15 Japspeed alloy radiator cap (brand new) - £7 OEM turbo Heatshield (small square cut out for clearance, doesn't effect performance) - £10 Exhaust manifold with heat shield (couple of heatshield bolts snapped) - £25 Happy to post at buyers cost. Deals on multiple items. {} {} {} {} {} {} {} {} {} {} {} {} {}
Yes it would be perfect. It actually came off of a 2530 HKS turbo, and rb20/rb25 have same feed from the block.
