The car is as follows- SR20DET Engine 2.0l turbo running a Garret 2871R. Japspeed Elbows, Full custom EMP performance exhaust with silenced shotgun tailpipe. Nylon gearbox mount, 4.1 auto diff, solid subframe mounts, solid front/ rear diff mounts, apex adjustable rear toe arms, apex adjustable front and rear anti roll bars, 6 puck paddle clutch, Full c's garage 555 knuckles, extended lowering arms and tie rods. Meister r coil overs front, apex rear coil overs. R34 GTR Brembos up front, R33 full rear brake and handbrake setup, project mu pads. Recaro SPG passenger seat, Recaro SPG racer drivers seat with takata harnesses, Driftworks super low rails, Nardi dished leaher wheel, 6 point Apex roll cage. New battery in boot. The car has Japan racing JR5 alloys with 9.5 fronts and 10.5 rears wrapped in Fallen 453s with loads of tread left. The car was resprayed in Porsche slate grey, body work is in good condition, however the carbon roof needs addressing. Exterior has Origin lab full race line body kit, and Origin lab carbon under panels, the front has +25mm fenders and the rear has +50mm fenders, Rocket Bunny rear spoiler. Engine - Nistune ECU road mapped to 1.2 bar, Greddy boost controller, japspeed top mount intercooler, Apex 56mm rad, Bosh 044 pump, Apex intake, HDEV tubular manifold, Apex Pidgeon mod, Uprated oil cooler. Air leak in hose or small blockage in fuel line needs sorting which is making the drive a bit sluggish at moment. Should be quick fix by blowing lines out or smoke testing. Cash or swap just shoot me a message {} {} {} {} {} {} {} {} {} {} {} {} {} {} {}
Just tried finding a link for the door cards. They was bought a while back and I can't seem to find them where I get them from. (Assuming they don't sell them anymore)
I have no idea how to edit. Think I forgot to mention that the s14 has around 65k miles on clock. This was an automatic until around 50k miles then converted into a manual. Also had a sunroof which has been taken out and fabricated over
I did the manual conversion at 50k. Probably loads of photos still if you need them. Solid car during my ownership!
Some very very nice S14s im seeing for sale lately and this is up there with the best. Credit to you man. You've done this to a very good standard.
Hi Matthew Is there any obvious bad rust underneath etc? Would you be happy if I had a local mechanic/inspector do a report as its a bit tough to view with the current restrictions at the moment?
