For Sale Nissan Skyline R32 400HP 1.5JZ GTS Street and Time attack
Thread in 'Drift cars for sale' started by DaVViD, May 11, 2017.
  1. DaVViD
    DaVViD New Member
    Warsaw, Poland
    Hi guys!
    As I am about to make a big personal investment, unfortunately I need to sell my weekend toy 1f641. :(
    It is a 1990 Skyline GTS-T with many mods. Its rather a track car, however, its fully registered and I drive it often on streets, too (mostly, as I go on track once per year..).
    It is not a drift car, but can be easily transformed to, if needed.
    Car was imported from japan years ago, already had different than RB engine, currently running 1.5JZ. Engine is built from scratch, has done about 4000km only, with progressive boost, pumping 405hp and 500nm. Can go up to 550hp with just a step bigger turbo, but as I prefered to have this car more soft from the bottom - smaller turbo was a better choice in my case. What is the best in my opinion, is the suspension, many driftwork parts (below specs) - goes fantastic on track.
    Price can be slightly negotiated, asking 16.500EUR
    Can deliver this car anywhere in the world, also can change the car colour on demand, if yellow does not suit you 1f642. :)
    Car is currently located in Warsaw, Poland
    Engine:
    1.5 JZ fresh build (approx 4000km), 3.0 liter
    ECU EMU
    Borg Warner turbocharger
    Kakimoto modified exhaust
    Big aluminium radiator
    Transmission oil radiator
    Engine oil radiator with fan
    Intercooler Trust Etc.
    400+ hp with 500+nm (graphs available), progressive boost drives absolutely fantastic
    Gearbox:
    350z 6 speed gearbox
    LSD (1.5 way)
    Performance clutch (two disc)
    Brake: Front: Full AP Racing 6 pot Strap Drive 343mm on front Rear: GTR
    Suspension:
    Zeal Function coils
    Driftworks rear beam sleeves
    Driftworks diff support
    Driftworks all arms
    Driftworks rods
    Whiteline stabs
    Current setup is for time attack, however this suspension setup is fully compatible with any performance needs (drift, ta, drag, hill)
    Wheels:
    JR wheels, 17 inch front, 18 inch rear
    Work VS-XX set (optional)
    Body Kit:
    Front GTR conversion
    Light front fenders
    EPRacing Light hood with vents
    Rear custom wide body
    Light trunk
    Rear diffuser
    Carbon GT spoiler
    Car is currently wrapped in yellow foil
    Interior:
    Full roll cage
    Bucket seats (different setups available)
    Nardi Torino wheel
    Power cut
    Boost, oil, water temp gauges
    Carbon elements such as door panels etc
    Standard equipment (which is still active): Power windows Power mirrors with power folding Climate control (without AC)
    Many other parts have been changed recently, such as pumps, wires, cables, belts etc. Still need to work a bit on electricity to be perfect (eg. currently no rear reverse light, now high beams, so rather small details)
    _DSC2658 kopia.
    _DSC2669 kopia.
    _DSC2817 kopia.
    16734862_1275732422482159_353013326_o.
    DSC_6145 kopia.
    DSC_0987.
    DSC_6096 kopia.
    DSC_6070 kopia.
  2. chrisyboi
    chrisyboi Member
    Oh my god, I want this so bad!
    Don't suppose you want a Merc as a px do you?
    A couple of things, you say 1jz but then mention 3ltr? Is it a 2jz bottom end and 1j head? Do you have the specs of the build and the turbo?
    Thanks
  3. DaVViD
    DaVViD New Member
    Warsaw, Poland
    Hi! thanx :)
    yes, it's 2jz bottom with 1jz top, so one-and-a-half JZ :) freshly rebuild. Turbo is borg warner 200sx, new - other parts - as listed.
    Which Merc you want to trade? I am looking for a cheaper daily car (such Subaru or other Nissan ), but can consider any offer.
    I attach dyno.
    daV
    wykres_1.
  4. DaVViD
    DaVViD New Member
    Warsaw, Poland
    Thank you guys for your private messages.
    To be clear - car has its week points. Things that I wanted to go for in short future:
    • foil repair - on bonnet, due to heat, some foil needs to be replaced. It is actually being done right now, yesterday I brought skyline at detailer service (RS Detailing) for this repair and new best ceramic protection available on this foil. As previously said, any colour is possible if you want to change it.
    • electric - missing reverse light, speedometer, high beam lights - some wiring is not perfectly done, but car is quite simple so easy to repair. Wanted to do it so this year. From the other hand - many electric equipment works like a charm :)
    • front alignment - wanted to create new bumper support, for better look mostly
    • seat position - I am quite tall, so current seat position based on driftworks seat frame for R32 is not low enough for me. I planned to make them custom. However, for future owners I have two hq driver seats to choose from, depending on your needs. Seats can be still adjustable
    • probably some other details
    It is not a perfect car, but it is a brilliant car ready for track and a neck-breaker on street.
    Let me know if you have any more questions :)
    You can call me also on my mobile, messenger or other apps
    +48 608 091 024
  5. DaVViD
    DaVViD New Member
    Warsaw, Poland
    Little up :)
    Price is negotiable, if interested - make an offer, will consider any reasonable money :)
    Update: foil is repaired, polished, covered with best ceramic cover for foils n detailing studio. Looks awesome!
    • Informative Informative x 1
  6. Gazelle
    Gazelle Active Member
    Essex
    I think I remember this car....did it have a vvl Sr in for a while and used to be black??
    Originally from Powervehicles...
  7. mati
    mati Member
    Warsaw, Poland
    You're right, this is my ex car, it was imported by Powervehicles in 2009, it had a vvl SR, and later a 1JZ. It is still black underneath the wrap, the whole car was painted with a fresh coat of factory black in 2010.
    In addition to the spec that David put up, the car has a DW Hicas lockout, a DW power steering cooler, the diff is OS Giken, the clutch is an ORC twin plate on a custom flywheel, and the wheels aren't JR but Weds SA70 originally off of Stav's Sexy Knights RX7.
  8. Martin Gonzalez
    Martin Gonzalez New Member
    Hallandale, Florida
    hi mate, is this still for sale? I'm definitely late to this sale but I would still like to now to make sure I keep on searching...
  9. Jacob Rawa
    Jacob Rawa New Member
    Somewhere In The Mountains of Japan
    Hey man!
    Awesome car! Genuinely a clean build and I Love the photos. Could you tell me where they were taken? I'm assuming Warsaw, PL but i don't know many US looking spots in Poland and that underpass looks very interesting, like that one place in GTA V LOL
    Goodluck on your Investment and future builds
    #9 Jacob Rawa, Mar 13, 2020
  10. Wanyudo
    Wanyudo New Member
    Is this still available?
