Nissan skyline R32 RB20-DET ignition coil conversion harness. This harness is a simple plug and play item. Used when upgrading your stock coil packs to Audi R8 4pin (red top) coil packs. This loom is made with raychem 55A spec wire. Heat shrink sleeving, flex guard oversleeving, standard rubber boots and adhesive transition. This harness has been designed so you can eliminate the ignitor box (Used with the stock coils). We are charging £140 for the harness with free post and packaging If you have any specific requirements for this loom please don't hesitate to ask. We are more than happy to build to your needs. {} {} {}
