Not so N/A S13 anymore...
Thread in 'Project Cars and Builds Threads' started by Bu11et, Dec 18, 2016.
  1. Bu11et
    Bu11et Well-Known Member
    Halifax, West Yorkshire
    Thanks man!! Ye IVF is such a long process and expensive!! For what we've put into it I could have bought another S13 the same spec as what mine will be when its done for this year lol - but its totally worth it!!
    • Winner Winner x 1
  2. Bu11et
    A few engine parts have arrived :dw: Although at the moment I can't fit them as I need the Tomei Valve Springs to arrive and get them fitted before I can fit the head etc... so on the shelf they go.
    IMG_20200122_122141-1984x1488.
    More goodies arrived from JDM Garage UK - Z32 rear brake pad holding kit and new Pagid brake pads(I'm not too sure how good these will be but I'm hoping for the best...
    IMG_20200122_131841-1984x1488.
    Also new braided brake lines front and rear along with Skyline driveshaft bolts
    IMG_20200123_155120-1984x1488.
    Finally got my front wheels test fitted against the new brakes :alschaser
    IMG_20200124_015917-1984x1488.
    Got the Z32 rear caliper built up with new pads :worthy:
    IMG_20200123_034701-1984x1488.
    Fitted to the knuckle and then was tightening my new rear braided brake line and I thought it was funny how it kept just tightening and tightening, and tightening and tightening. Eventually got bored so undid it the other way and pulled it out to find it had stripped the threads inside the caliper, without even much force at all!! Thats what you get for running aluminium calipers I guess :smash:
    IMG_20200124_020840-1488x1984.
    Lucky for me I have a spare rear Z32 caliper, but it was 1 piston down, so I spent about half an hour trying to get a piston out of the current caliper before remembering I had a compressor with air in it and used that to push it out.
    Got the spare one built up, fitting it to the car and the bottom mounting bolt goes really tight, so instead of forcing it I have removed it and got the tap & die set out ready to clean up the threads before it goes on properly next time I have a spare hour or 2.
    IMG_20200124_035130-1488x1984.
    Managed to squeeze in 10 minutes to get the driveshaft bolts fitted too finally.
    IMG_20200124_033803-1984x1488.
    Question - The spare caliper I have got is for the drivers side as the bleed nipple sits at the top if bolted that way, am I going to have any problems with the bleed nipple being at the bottom of the caliper when mounted?
  3. sidewaysman
    sidewaysman Member
    essex
    With the bleed nipple being at the bottoms you will not be able to bleed the air out, brake fluid is heavier than air so will just drain out, leaving the Cali per full of air.
    Quick fix is to unbolt, endure bleed nipple is at the top, place on the brake disc (to stop pistons closing) bleed it and then bolt back up
    • Useful Useful x 2
  4. Bu11et
    Small update with a fair few photos - gonna keep the text short with this one...
    Nipped down to Retro Speed Shop and picked up the bits they have kindly done for me this year - a spare pair of Extended LCA's, and their new V2 Hyperknuckle with a bit more lock and some bump steer correction added in aswell now! Mega excited to try these
    IMG_20200128_104539-1488x1984.
    Only fitted the knuckles as the lower arms didn't have any bushes or balljoints in the new arms, plus they are no different to my current ones anyway..
    IMG_20200128_151648-1488x1984.
    Also bashed my inner arch to aid for more clearance with the new wheel setup.
    IMG_20200128_145640-1488x1984. IMG_20200128_144812-1488x1984.
    Fun task of bleeding the brakes up on my own - few friends on facebook suggested a bottle with brake fluid in the bottom - did that and it seems to work, although I'm struggling with the hydro so maybe need somebody to help with that...but the brakes themselves feel alright
    IMG_20200127_143808-1488x1984.
    Had some spare time so sorted out my drivers door (after the smash at Drift Matsuri...), had to swap the loom out of my old door and also re-attach a few wires
    IMG_20200127_192635-1984x1488. IMG_20200127_205512-1488x1984.
    and door card
    IMG_20200127_212116-1984x1488.
    Then spent some time removing all the residue and stickers off the car as its going for paint on Monday.
    IMG_20200127_214351-1984x1488. IMG_20200127_215210-1984x1488. IMG_20200127_231726-1984x1488.
    Last year I bought a pair of +20mm non vented fibreglass front wings for the S13 - trying to keep a subtle/street look about the car...
    Screenshot_20191217_210136_com.facebook.katana.
    The only problem was they were 4 hours away and the seller wasn't willing to post...
    Screenshot_20200130_134357.
    Anyway after work on Thursday, I went home, had tea and then set off about 8pm, arrived at Aberystwyth around 11.45pm , threw the wings in the car and set off home again... Got home at 3am...urgh!
    Got the wings test fitted on the car and they aren't great fitment unfortunately... IMG_20200131_143542_copy_1984x1488.
    Even after a bit of fettling with the heat gun and drilling the mounting holes a bit higher up they still aren't amazing - but they're cheap fibreglass and I'm not sure who made them so I guess thats what you pay for...
    IMG_20200201_012819_copy_1984x1488. IMG_20200201_014842_copy_1984x1488.
    Fingers crossed the bodyshop have some ideas but if not they will have to do for now until they explode and then I'll pay a bit extra and get some decent ones I reckon...
    Many new parts too!
    Ordered this thermal intake gasket from America and it arrived within a week! Real happy! Supposedly these keep the intake nice and cold and it was only about £30 delivered all in.
    received_798154830701914.
    My Tomei Cams and Valve springs finally turned up after Customs had their way with them!! (Apologies for the story screenshot...)
    IMG_20200131_134655_153.
    Also came across these on facebook - 6 Genuine Bosch Audi TT 1.8T coilpacks for the same price you'd pay for 4 ebay versions! And I've got 2 spare incase of any issues...
    FB_IMG_1580198395392.
    The last bits I did were fit all the fenders/kit properly just to get an idea of what it looks like, plus it makes it easier transporting it all to the bodyshop, and I can just unbolt it all when I get there
    IMG_20200201_023604_copy_1984x1488. IMG_20200201_023739_copy_1984x1488.
    The next updates will be on the engine - Monday night the lads from AB Auto-works are coming round and helping me put it back together now that the Valve springs and cams are finally here! Exciting times and progress finally!
  5. Bu11et
    Loaded the car onto the trailer Monday and dropped it at the body shop - the next time this will be seen will be when its fully finished, paint & livery ;)
    IMG_20200203_150621_copy_1984x1488.
    Got a message off Adam saying that whilst he was fitting my new valve springs - he found numerous stem seals that were knackered! The engine shop had replaced some of them with new but not others oddly?! Luckily I got some new stem seals with the Genuine Nissan Gasket Set I bought so dropped them with Adam straight away. Need to ring the engine shop at some point to find out what the crack is
    received_194645898400063.
    Had a tidy up in the garage now the car had gone and got all the parts out ready to crack on with the engine
    IMG_20200203_164901_copy_1984x1488.
    Then Adam and Ali turned up from AB Auto-works and they got cracking on the engine whilst I made drinks and stayed out of their way.
    IMG_20200203_192805_copy_1488x1984.
    Got most of the bits buttoned up, head on etc, and then when cleaning up the rockers, we realized how bad they were! Really big ridges that you could feel very easily with your fingers - argh!
    IMG_20200203_195456_copy_1488x1984.
    Messaged Harry and he had loads spare, so he dug out 8 good ones and sent them up - arrived next day surprisingly!!
    IMG_20200205_154006_copy_1488x1984.
    Bled the lifters and then installed them along with the rockers
    IMG_20200205_165007_copy_1488x1984. IMG_20200205_163501_copy_1984x1488.
    Then got the upper sump on along with the baffle plate and oil pickup
    IMG_20200206_173356_copy_1984x1488.
    Then the baffle before the lower sump pan
    IMG_20200206_193923_copy_1488x1984.
    then the lower sump along with a new sump plug washer
    IMG_20200206_194234_copy_1984x1488. IMG_20200206_195557_copy_1488x1984.
    Thats how the engine sits at mo
    IMG_20200206_202121_copy_1488x1984.
    Bits left to do:
    Fit Tomei cams
    Fit turbo and new braided oil/water lines
    Time engine up
    Fit rocker cover
    Create new air filter pipe
    MAF Wiring
    Also some shielded cable arrived so that I can re-route my MAF wiring as I'm running an R35 MAF this year and it is located close to the Throttle Body on the Intake side of the intercooler piping.
    IMG_20200205_080007_copy_1984x1488.
  6. Bu11et
    I had a crack at trying to wire up my own MAF plug with shielded cable and it came out looking horrible, think I might leave this one for Martin to do for me... Wiring has never been my strong point (Infact, I can't really think of any strong points of mine :smash:)
    IMG_20200207_221040_copy_1488x1984.
    Test fitted the Audi coilpacks with the loom and its a perfect fit
    IMG_20200207_201210_copy_1984x1488.
    Got the Tomei Poncams fitted up aswell finally! This was scarier than it sounded as the instructions were Japanese translated into English so made it sound alot harder than normal...
    IMG_20200208_234627_copy_1984x1488.
    Also Ali from AB came round and helped me finis off the last few bits of the engine that I couldn't do on my own, such as the timing. This is the first time I've built an SR20 ever so having these guys on hand to help with any issues has been great and I think I definately would have struggled otherwise!
    IMG_20200210_183242_copy_1488x1984.
    Fitted the rocker cover and test fitted the Audi coilpacks, I think they look pretty good tbh and fit extremely well!
    IMG_20200210_185250_copy_1488x1984. IMG_20200210_185259_copy_1488x1984.
    Then got a call from the bodyshop to advise the car was done so could go and collect it... Headed upto where I store my trailer and was greeted by this. During the heavy rainfall we had on Sunday it had washed away the road that leads upto where the trailer is stored so that was a no-go...
    IMG_20200210_131036_copy_1488x1984.
    Adam from AB Auto-works has kindly agreed to help me out and collect the car with me today(Tuesday) using his recovery truck seen as I can't get to the trailer :cry:
    Heres some teaser pics - even got the wheels re-done...
    IMG_20200211_042634_copy_1984x1488. IMG_20200211_042654_copy_1984x1488.
    Just waiting on an oil restrictor for the turbo, then I can get that fitted along with the new braided lines for oil/water feed/returns etc... Then it's just a case of mating the Engine & gearbox back together and fitting it into la vehicle! :wack:
  7. Bu11et
    Restrictor received and fitted
    IMG_20200211_144329_copy_1488x1984.
    Modified the oil drain to fit the new turbo
    IMG_20200211_152416_copy_1488x1984.
    Fitted said turbo with manifold and all the lines - looks sweet!
    IMG_20200211_164508_copy_1488x1984.
    Also lopped the backbox off my exhaust as I want the car to be louder this year
    IMG_20200212_144938_copy_1488x1984.
    Really excited to find out what it sounds like with the cams and manifold - Hoping its going to be nice and raspy. In reality its going to sound like a normal bent cam just louder and fartier...lol
    IMG_20200212_145235_1_copy_1488x1984.
    Took the car down to Driftnuts so they could work their magic with the vinyl, but whilst it was down there they also let me fit the engine. We had a bit of drama after plumbing and plugging everything in, the car would just crank over...not even attempt to fire.
    IMG_20200218_084041_copy_1488x1984.
    Checked it was getting fuel, made sure the lines were on the correct way (ey ey @BenRice), checked the coils/plugs were sparking and also removed the cam cover and double checked the timing and made sure the CAS was set correctly. We were stumped.
    In a last ditch attempt I nipped home and grabbed a few bits. Came back and fitted the stock S15 coilpacks, the bloody thing fired straight up! Without hesitation or anything... and idled perfectly for a good 2 minutes until it started warming up and then just died seen as there was no IC piping or AFM attached - My video only shows the last 12 seconds before it died haha - massive thanks to Brad at Driftnuts and Jamie from Jimbobs Motors for helping with the engine fitting and help getting it running! Hope this link works
    Friday just gone was Valentines Day, so of course me and Amy spent it doing couple stuff, this involved spending 6 hours in my mums van(with my mum driving) to pickup my tyres for the season that Kenda have kindly sent over!! I picked up 82 tyres in total and they filled my mums Peugeot Boxer LWB Hi-top to the brim, we could not fit 1 more tyre in so we got lucky there!!
    IMG_20200214_122551_copy_1488x1984.
    I can not put into words how grateful I am that Kenda have stayed onboard for 2020 and are helping me out massively! Even supplying me with their KR20A in 265/35/18 flavour for the rear and 235/40/17 for the front! Fingers crossed my car has a bit of speed this year and I can throw some shapes! This picture shows half of the tyres, stacked 2 deep in rows...
    IMG_20200215_110142_copy_1488x744.
    Then took the car over to Eclipse Motorsport for a full alignment and some final bits before mapping! Gave it a full alignment with fresh settings that I'm keen to try out - also got all the IC piping on, bolted up the new R35 MAF
    IMG_20200216_135229_copy_1488x2976.
    Made up a new intake pipe that accommodates the stock intake pipe breather setup - this worked perfect last year with no issues so don't see why I should need to change it?
    IMG_20200217_155458_copy_1984x992.
    Then swapped the injectors over for the new 740cc jobbies
    IMG_20200217_163701_copy_1488x2976.
    and some fresh colder BKR8EIX spark plugs
    IMG_20200213_200052_copy_1488x1984.
    The car is now done pretty much and ready to go down to Martin Battye for mapping hopefully end of this week, the car will be with him for a week or 2 and then once its back, final checks and get it to a practice day and see how it feels!
    • Like Like x 3
  8. BenRice
    BenRice Well-Known Member
    Mt Maunganui, New Zealand
    Glad to see someone else struggle with a first start up :D
    This thing is going to feel like a whole new animal this season. Bigger tyre & more power will open up a whole new style of driving
    Did i miss any gearbox/clutch upgrades? And what axles you going to run?
  9. r3k1355
    r3k1355 Well-Known Member
    Wasn't a Z33 gearbox going in?
    • Like Like x 2
  10. jon07043278
    jon07043278 Well-Known Member
    North Wales
    I thought that was already in?
    • Winner Winner x 1
  11. Bu11et
    Can't wait for this man - just driving it is going to be a whole new experience, so I'm excited to try and tame it!!
    Jon is correct lads - After I blew up the stock 5 speed box at BDC R5 Three Sisters, I threw a Z33 box in it straight away, so thats already done
    Clutch wise I'm running a Driftworks S15 6 speed lightened flywheel with a CG Motorsport 5 paddle clutch
    Diff/Axle I've upgraded to a Skyline GTS 5 Bolt Diff and shafts - Kazz 2 way 4.1 Ratio - no more welder haha
  12. Bu11et
    Apologies for the lack of updates - the car has been with MB for a while now but hes been busy so he hasn't had time to get round to mapping my car unfortunately. Hoping it'll be done in the next week as I've booked and paid for Three Sisters on the 15th March as a first test day...
    Had to trim my front bumper to fit over the intercooler as it hadn't been fitted before with all the pipework on
    IMG_20200219_175059_copy_1984x992.
    IMG_20200219_180604_copy_1984x992.
    Also (finally!!) bought a new jockey wheel and clamp for the trailer as the old ones were pretty shonky and barely did the job!
    IMG_20200219_115128_copy_1984x992.
    Dropped the car with MB - but I can't show you the car just yet...so heres a pic of my trailer looking pretty ;)
    IMG_20200220_133248_copy_1984x992.
    Also bought some Auto-Collect Storm wing braces as now running fibreglass I don't want them flapping about everywhere!
    IMG_20200225_135420_copy_1984x992.
    Also treated myself to a HANS device for this year - with the discount BDC Drivers get from Simpson, it was well worth investing in a Hybrid Sport as they are mega comfy and you can't feel it when you have it on!
    IMG_20200303_150359_copy_1984x992.
    So hoping that the car is done this week as I need to do a few finishing bits on it before drifting next Sunday!
    • Winner Winner x 1
  13. Bu11et
    So - I had the first test day on Sunday at Three Sisters - and it went really good!! (Despite the car breaking just after lunch, but we will get to that later...)
    We got there in the morning and got the car all kitted up etc and I got some pictures of it with the 2020 look, I am mega happy with this and it has come out ALOT better than I expected!! Many not be to everybodies taste but it definately is mine!! IMG_20200315_090627_copy_1781x890. IMG_20200315_090640_copy_1781x890. IMG_20200315_090648_copy_1781x890.
    The car performed amazing in mapping too - quick rundown of the specs
    SR20DET VVT
    Tomei Poncams
    Tomei Type A Valve Springs
    Siruda 1.2mm MLS Headgasket
    Modified SR Injectors(750cc)
    R35 MAF
    2871r Turbo
    Japspeed RS Manifold
    Nistune ECU
    IMG_20200312_121502.
    It is so fast and yet still responsive! And it is really exciting to drive!
    The car is amazing to drive... The gearing now with the 4.1 Diff, 350 box and the 18" 265/35/18 rear setup is amazing - the car is pretty much 3rd everywhere and 4th in the faster corners!! Can't fault it one bit!! It squats and picks up so much more speed now, I really can't wait to drive it again!!
    Also the new RSS V2 Knuckles are really good, took a bit of getting used to and I'm still not 100% but they steer alot faster! I cant wait to make full use of them with more testing!
    Only had useable footage from the afternoon of my 1 and half laps haha - so here it is!
    Few external stuff aswell - Please just listen to how it sounds... Right now it is perfect!! I could not wish for my SR to sound any better! The only issue I'm having is its a tad loud - Measured at 112db so need to fit a silencer in which I am worried will affect how it sounds...
    Chasing Damien in his JZ E46 Compact
    Onboard from Damien chasing me in his JZ E46 Compact
    Heres a few photos from Sunday of the car in action
    BSB_9195_copy_1781x1038. BSB_9230_copy_1781x1022. BSB_9275_copy_1781x1065. FB_IMG_1584439108510. FB_IMG_1584439113707.
    and 2 more from the pits that somebody took FB_IMG_1584374398960_copy_1781x1335. FB_IMG_1584374394646_copy_1781x1335.
    After lunch I went out and did my first outing lap from the pits - bob on! Queued up to go again and managed the first 2 corners fine, then as I was mid-way through the 3rd corner, the car cut out and started spluttering!
    Me and a few mates spent the best part of 2 hours trying different things left, right and centre with no luck - changed plugs for new ones, changed coilpacks, took cam cover off to check for any damage to the cams or rockers, nothing!
    Spoke to Martin @ MB Automotive(the guy who mapped the car) and he said best to get it plugged into a Nistune, but from what I've explained it sounds like either the injectors leaking or the AFM is dead due to how rich it is running.
    Followed his advice and luckily one of my sponsors, AB Auto-works had the Nistune software so he let me borrow it. Plugged it in and boom straight away. MAF issue - checked the wiring but can't see any issues anywhere...so I am presuming the MAF is dead itself. IMG_20200316_194035_copy_1781x890.
    I have ordered a new MAF(this time a genuine nissan job) so fingers crossed its the issue and I can happily plug it in and be on my way!!
    • Winner Winner x 3
  14. Bu11et
    Another small update...
    Ordered a brand new R35 GENUINE MAF - got that fitted which fixed my issue so the car runs sweet now! Fingers crossed no more silly issues
    IMG_20200319_120443_copy_992x1984.
    Also fitted some stickers i've bought over winter :dw:
    IMG_20200318_165631_copy_992x496. IMG_20200318_165642_copy_992x496.
    Bought these aswell, Auto-Storm Collect wing braces - now that I'm running fibreglass front wings I don't fancy them flapping about if I ever run front bumper-less. Very easy to install and good quality.
    IMG_20200318_143507_copy_992x496.
    Aerocatch also sent me a fresh new bonnet catch as the one on the left had seized up and wouldn't open without the use of a screwdriver - great service!
    IMG_20200321_153257_copy_992x496.
    Purchased a new hydro handle aswell from Andy @ Icefab - mine was just an old bit of bar bolted to the original hydro handle, but I like the style of this one so thought I try and spruce up the interior.
    IMG_20200323_122904_copy_992x1984.
    Before & After
    IMG_20200325_121242.
    Finally fitted a fresh pink tow-strap as last years was looking filthy!! and for £15 each they are well worth it in terms of aesthetics!
    IMG_20200318_210026.
    Also did the school run in the S13 - Scarlett loved it haha
    IMG_20200320_151249_copy_992x1984.
    Heres a few more pics from The Three Sisters test day :alschaser - now we are in Lockdown in the UK, I'm super glad that I got to test the car before all this kicked off!!
    FB_IMG_1584467676257. FB_IMG_1584467674313. FB_IMG_1584461153126. IMG_20200317_170454_736. FB_IMG_1584914735175. FB_IMG_1584461366662. FB_IMG_1584537152436.
    Also BDC Round 1 has been post-poned until the 2nd Weekend in September - so not even sure I can make that anymore - we shall see!
    Fingers crossed this all blows over fairly quickly! Stay safe everyone and stay home!! :wave:
    • Winner Winner x 1
