Not using lockstops
Thread in 'Technical Questions' started by shirunai, May 6, 2013.
  1. shirunai
    shirunai Active Member
    ornskoldsvik sweden
    Is it a mistake not to use a "lock stop" while drifting?
    I use Driftworks offset spacers so i guess they may have to take some pounding? since the rack is limiting how much lock i can have
    Driftworks geomaster knuckle
    Driftworks R33 GTR kinked tension rods
    28mm extended s14 LCA
    By the way its on a s14
  2. kam
    kam I've touched Chris Parry
    Yes, you want a lock stop.
  3. silvertop
    silvertop der drifte schlag
    Reading, Berks
    any particular reason why?
  4. Clark3y
    Clark3y Member
    To save putting shitloads of stress on the offset spacers, presumably..?
  5. silvertop
    Reading, Berks
    shit, i cut the lock stops off my r32 :s it did some weird shit yesterday at pod. steering was going over centre i think, do the offset spacers stop that?
  6. smoody
    smoody Member
    Sunderland
    im sure without the lock stops you have a high riask of over centering?
  7. Ste333
    Ste333 "The Shoulder"
    Solihull
    The rack spacers will prevent over centering in most cases as they effectively move everything 20mm further forward. But if your not running a lock stop, the steering has no limit effectively so it could still occur.
  8. Clive
    Clive Active Member
    chichester, west sussex nr portsmouth
    I don't run any lock stops. geos, z32 rods, offset rack spacers.
    Haven't for years. Done more drift days then I will ever know and never bent/broke anything (Jinx'ed that now)
  9. kam
    We don't run them on our cars either, but you "should" have them.
    If we say "no you'll be fine" and you break something = our fault.
  10. superclarkey
    superclarkey DORITECH MOTORSPORT
    West Midlands, Halesowen.
    No lock stops, the world will now end,lol
  11. Clive
    Clive Active Member
    Fair one that :nod:
    But, the biggest causer for shit to break is rack's not being centered due to lazy alignments and big wheels hitting inner shit... :smash::smash:
  12. kam
    Indeed it is :)
  13. Rossc0
    Rossc0 Diesel Skidder
    ★Tongue punching your Mums fart-box★
    I cut mine off. Fuck lock stops. I dont want my lock to stop
  14. smoody
    smoody Member
    Sunderland
    haha +1^^ :p
  15. Toph34
    Toph34 New Member
    Hey guys just to add on this lock stop thread.. I've just installed the geo knuckle, offset spacers kinked tension rod and completely cut the lock stop off. But still can't get full lock as the tie rod end is hitting the lca. Any ideas how I can get full lock?
  16. HOODS
    HOODS Member
    Glasgow
    Either buy driftworks lower arms (as there skinnier) or notch your current lower arms to allow the track rod end to actually sit beyond the point where they would hit the lca.
    Like my arms here
  17. superclarkey
    You don't require notches if your knuckles are made right and you know how to set the car up, I've never had to notch the lower arms with my hubs...
    Doritech – Super-Tech Knuckles | DORITECH
    You need to change your caster :p
  18. HOODS
    HOODS Member
    Glasgow
  19. Clive
    Clive Active Member
    But caster is a personal thing.
  20. superclarkey
    Not wrong, there knuckles require it because that's how they have designed it, mine don't, and caster is what causes most people's problems, by adding and removing caster its like moving the steering rack forwards and backwards :p
