Possible Lada build... SR20DET, 1JZ or RB20DET Engine?
Thread in 'Technical Questions' started by supernova-dw, Feb 22, 2015.
  1. supernova-dw
    supernova-dw Active Member
    Vientiane, Lao.
    Hello everyone from Vientiane in Laos (Yes most people probably have no idea where this is??)
    I'm running my own small garage and am going to start a project to attract some attention and get some work in.
    The car which will be used as a base is a Lada, I'm not using this because it's a top choice of car but simply as it's the only decent shell I can get for a sensible price... Cost less than £400 and it's very clean and tidy with very little corrosion etc... An E30 full of rot and filler starts at £3000 here!!!
    Anyhow I'm trying to think of the best engine choice?? Kind of down to 3 different choices which are SR20DET, RB20DET or 1JZ-GTE....
    As I see it so far:
    SR20DET: costs around equivalent of £900 for a Red top complete with gearbox, wiring, ancillaires etc... I know the SSR20DET is a very popular option and as far as I'm aware pretty reliable!?
    RB20DET: can be had very cheap! Complete engine, manual box, wiring and ancillaires I can get for the equivalent of £400... Be slightly more hassle to fit I'd imagine but no major issues... Quite an unknown engine to myself but from what I do know the RB20DET is supposedly the hardiest of the RRB's? Its seeming like a good option so far!
    1JZ-GTE: I can get for £600 equivalent which again is for the whole set up including wiring, ancillaires but an auto box.... A R154 to convert it to manual is around £600 again plus of course other costs for clutch and flywheel etc... No need for questions about the engine itself I know their great!
    So as I'm on a budget what should I do? To begin with I would run whatever engine I choose as stock... Just front mount intercooler, exhaust system and air filter. I won't be going for mad power but say 350 in future... I know the 1JZ will do that easily but as for the other two engines I'm not so sure... I understand the RB20 turbo is crap so would need changing which would add up cost wise.
    Any ideas and suggestions welcome! As soon as I get the car I'll begin a build thread.
    Thanks in advance.
  2. speedykonzales
    coffee cup
    How about a Saab engine with Opel gearbox R25/28? These engines here go around 200€, maybe less. Gearbox is around 50€. I just bought a full engine harness and ecu with 20€. To program the ecu yourself you need a canusb cable which should cost around 130€.
    E: Probably you already knew that.
  3. supernova-dw
    Vientiane, Lao.
    Thanks for your reply, I'd be more than up for this power plant but there is 0% chance of me finding one in this part of the world and also 0% chance of finding any parts for one here so sadly will have to dismiss it.
    At the moment I'm thinking RB20DET.... Seems to be great 'Bang for buck'
  4. gaz_moose
    gaz_moose .MTM.
    round a bend
    what is the front subframe setup like on the lada? id go for whatever fits in the hole the easiest.
    RB20 is a fair old weight over an sr20.
  5. S333FSL
    S333FSL New Member
    Any update on this? What did you go with in the end
