For Sale *PRICE DROP* EX DORI LABS S14 ZENKI
Thread in 'Drift cars for sale' started by Robbie_Roo, May 4, 2019.
  1. Robbie_Roo
    Robbie_Roo New Member
    Birmingham, UK
    Hello all,
    The time has come to part with my much loved s14, most of you all will know of the car and is fairly well known especially at driftland.
    I've owned this car for approx 9 months, I've done one santa pod drift day and a bit of road driving.
    Pulls well.
    Here's the spec from the previous owner.
    No expense spared, recently just rebuilt the engine costing over £2,500 with every receipt. Brand new Garret gt2871r at £900, new ACT Clutch and freshly painted engine bay.
    all work has been carried out by myself including all the custom work.
    1994 JDM Nissan silvia k's so not your usual uk rotten shell
    12 months mot.
    Engine
    Recently rebuilt with the below work being carried out.
    Head skim
    block deck
    chem clean head and block
    new valve guides
    Double angle valve faces
    Triple angle valve seats
    crank polish and measure
    Deglaze cylinders
    Blacktop Sr20det on standard internals.
    Siruda 1.5mm multi layer steel head gasket
    Driftworks rocker arm stoppers
    ARP Head studs
    ARP main bolts
    ARP Conrod bolts
    ACL Race main, big end and thrust bearings
    Genuine Nissan full gasket set
    Genuine Nissan oil pump/front cover
    Genuine Nissan water pump
    Genuine Nissan piston ring set
    Genuine Nissan valve stem seals
    Genuine Nissan rear main seal
    Brand new ACT Extreme paddle clutch rated to 565 ft/lbs.
    ACT streetlight lightweight flywheel .
    Brand new Garret GT2871R
    Nismo 740cc injectors
    Z32 maf
    Apexi intake
    Apex stainless intake pipe.
    colder plugs.
    walbro fuel pump.
    Viscous fan and shroud removed.
    Mishimoto aluminium radiator.
    Mishimoto fanshroud with twin electric fans.
    Mishimoto fan controller.
    H-Dev Manifold heat wrapped and modified for external waste gate.
    Genuine Tial mvs 38mm vband external waste gate with screamer pipe out bonnet ( can be spun round to point to floor).
    Front Mount Intercooler.
    custom Stainless 3" exhausts all the way with no cats or silencers! done by EMP Performance.
    sits nice and tight to the chassis so great ground clearance.
    Engine damper.
    braided turbo lines
    Greedy profec b spec 2 boost controller
    Horsham developments stage 3a ecu that’s been custom mapped.
    old engine made 340bhp on this ecu at 1.2 bar of boost. I’d imagine with this engine and 1.3 bar you should easily see over 350bhp.
    New AEM Uego X series a/f ratio gauge
    Greddy style baffled sump
    Handling
    Full 6 point weld in roll cage including rear x brace,harness bar and door bars.
    Carpets and rear bench put back in.
    Driftworks cs2's new May 2016
    Driftworks geomaster's new Jan 2016
    Adjustable rear camber, toe and traction arms.
    tein tie rods and japspeed rod ends.
    +25mm and notched front lower arms with adjustable lock stops.
    Geomaster tension rods.
    Modified front cross member ( rack moved forward 27mm)
    Front and rear strut Brace.
    4:3 welded diff with 5x1 driveshafts.
    5x1 driveshaft spacers
    2 pairs of 3x2 driveshafts
    Hardrace "street" engine mounts
    Japspeed polly Gearbox mounts.
    Poly bushed rear subframe
    R33 gts-t from calipers, discs and pads
    R33 gts-t rear calipers, discs, pads and internal handbrake mechanism.
    Front and rear braided brake lines.
    Handbrake locks up perfect!
    Braided clutch line.
    Nismo power brace.
    Exterior
    Rear wheels
    BLITZ TYPE 03 special edition.
    fully stripped and polished to a mirror finish by "Mike the Polisher"
    Brand new 6" lips
    18x12 et-3
    275/35/18
    Front wheels
    18x10 et -10
    Brand new 5.5" lips and 4.5" barrels
    245/35/18
    326 Power 9cm wheels nuts in gold with gold long spikes
    Vertex front bumper (damaged)
    Vertex side skirts
    M Sport Rear bumper
    Vented metal bonnet
    BN Sport front wings (pretty beat up)
    Origin +50mm rear over fenders
    D-Max roof lip
    Kouki rear wing
    Ganador mirrors
    Custom tubular front crash bar.
    Rear arches tubbed
    Front arches half tubbed
    Front upper leg raised for clearance
    Clear headlight covers
    Crystal clear side lights
    Crystal clear front indicators
    Fuse box relocated behind glove box
    Engine bay recently stripped bare, rubbed down and freshly painted, gold flake.
    Interior
    Bride Brix reclining drivers seat on a driftworks super low rail.
    Fly off handbrake button.
    DEPO water & oil temp and oil pressure
    gauges
    Stack Boost gauge
    Nismo gear knob
    Driftworks FIA Approved 4 point 3" harness in orange in drivers seat
    Standard black leather passenger seat with Luke 3 point harness.
    Battery cut off switch.
    Silvia digital climate controll.
    Sony head unit.
    JL audio sub and amp in boot.
    Fusion encounter parcel shelf speakers with separate tweeters and X over's.
    Car has only done 15-20 miles since rebuild so will need another 450 miles before it can be driven hard or the map altered.
    Bad bits.
    This is a drift car so as you would expect it has some imperfections cosmetically. Some cracks on the front wings and some chips on the front and rear bumper.
    I've recently fitted a new gearbox which came with a different speed sensor so I had to cut and join my loom to this speed sensor, unfortunately it seems to be the wrong speed sensor as the Speedo reads double what I’m actually traveling at.
    Drive shaft needs replacing, knocks like a bugger, can include one in sale depending on selling price.
    Apart from those small issues the car is solid, everything works and is a ready to go drift car with everything you'd ever need, honestly can't think of anything else you'd want to put in this.
    Car will be up for sale in 3 different specs,
    Dirt Nasty standard s14 wheels with god knows what tyres £ 6500
    720 wheels £ 7000
    Blitz wheels £ 9000
    Pictures can be seen on my instagram robbie_roo
    Will add some pictures to this thread when I can.
    Many thanks,
    Rob
    #1 Robbie_Roo, May 4, 2019
  2. Robbie_Roo
    Birmingham, UK
  3. Robbie_Roo
    Birmingham, UK
    Hi
    IMG-20190101-WA0010.
    IMG-20190101-WA0013.
    IMG-20190102-WA0000.
  4. Robbie_Roo
    Birmingham, UK
    More
    received_289456595274426.
    received_425296391594705.
    received_2358772157668027.
    received_638755493218908.
    received_2056779974448785.
    received_496939290842834.
    received_385704222286336.
  5. Robbie_Roo
    Birmingham, UK
    PRICE DROP
    720 wheels £ 7000
    Blitz wheels £ 9000
  6. Spence.tubs
    Spence.tubs New Member
    Birmingham
    Is this still for sale?
    • Informative Informative x 1
  7. Robbie_Roo
    Birmingham, UK
    yes hun
