Problem with my MIG welder- Buzzing and not feeding/welding right
Thread in 'Technical Questions' started by Stavros, Apr 13, 2011.
  1. Stavros
    Stavros Active Member
    Isle of bollocks
    As title really.
    All was fine until the other day, but last night I went to use it, and though the wire feeds fine when you pull the trigger, when you go to weld it seems to not move much/all, make a buzzing noise from the machine, and do just the odd sparky spatty shit bit of weld then nothing.
    Obv if the earth was shit it wouldnt weld either, but surely itd just feed out a load of wire wouldnt it?
    If the wire feed was fucked, why it feed ok into open air when i pull the trigger?
    Bastard thing! :cry:
  2. MW99
    MW99 Member
    Camberley, Surrey
    Could be a tight spot. If the feed wire is tight does it come through better opposed to having it slack or depend on how you hold it angle etc? I had this problem before. Ended up being moisture on the wire and a dodgy nib.
  3. jon1200
    jon1200 Active Member
    In Sunny Blackpool :)
    It could be the Wire feed. Try to tighten it. then put your hand you and push the trigger and if you wire can curl up in your can then you have enough pressure.
    Also it might want a new liner putting in. If you have a bad earth try grinding way a clean area and try to keep the earth close to your weld...
  4. Pikey
    Pikey Active Member
    Cheltenham
    Gas run out?
  5. Sliderman
    Sliderman Absolute Slag
    Highlands.
    As above, many things. Wire feed tension sounds likely (are you using 0.6 wire with a 0.8 wire feed? worth checking), check gas, check for rusty wire, reel turning freely without too much friction?
    Is it a clarke? If so then just learn to deal with it haha
  6. gaz_moose
    gaz_moose .MTM.
    round a bend
    what welder is it?
    how old is the wire?
    is the wire rusty?
    does the spool say machine wound?
    dont go mad on tightening the feed roller
  7. Mighty_Mini
    Mighty_Mini Go!Go!Auto
    Cornwall
    Funnily enough mine did exactly the same thing the other day. Fan still works, gas is coming through but the wire wont feed.
    The Bridge Rectifier went on the board. Just randomly i was welding, put the torch down to clamp up the next piece and then just stopped...
    Just trying to source a rectifier as a replacement board is £56 and a bridge rectifier can go for a couple of quid. if that.
    EDIT: mis-read that it wasnt feeding.
    Sounds like the pre-tension on the wire isnt enough.
  8. benlewismav
    benlewismav Member
    Gloucestershire
    Haha is it an issue with clarke welders then? I've got a 220e and the bastard thing has been jamming up a lot recently. Have to have the cable from the machine to the gun pulled taught when using it overwise it seems to do it....
    It causes the wire to then jam up in the feed mechanism and then spool up inside of the welder! The only way to sort it is to pull it back through the gun and cable, snip off all the crap thats spooled up inside the welder and refeed it again.. end up using like 5x as much!
    Considering buying a new gun/wire feed cable thing if its the insides that are sticky etc? I'm just dealing with it as and when it happens at the moment but its becoming more annoying esp when I'm in a rush
  9. jonofd3
    jonofd3 Active Member
    Milford Haven (West Wales)
    more than likely it is down to slightly corroded wire coming through the nozzel.... basicaly slightly thicker and when you weld the wire swells because of the heat and it bites on the tip untill it cools enough to feed out again, giving you the stop start welding!
    If you take the tip off the gun and give it a clean out with one of the files used on the oxy torches then give it another go ;)
    Jono
  10. warby
    warby Lifestyler Deluxe
    Isle of Man
    Could be catching in the tip or the liner in the big cable to the torch, had this on most of my MIG's from cheapie single phase to my big expensive 3 phase one ...
  11. steady eddie
    steady eddie Member
    Teesslider
    I think you and the opening post may find the problem is the feed liner. It works fine when pulled straight and taught but then it's bent or twisted to actually weld the wire is jamming inside.
    The liners have a metal coil and a grove can wear in them that snags the wire, it's also possible the wire is fusing to the liner with heat.
    I've replaced my liner and it's made a world of difference (mine does get a lot of use though) but they are fairly cheap so it's worth a try.
  12. warby
    Isle of Man
    Feed liner, that's the word...I'd check him first, went through 3 in a year once. Was welding most days like :)
  13. Magic21
    Magic21 Active Member
    liverpool
    I had similar problems, I changed the feed/swan neck liner to a steel one and braced the wire feed and it was sorted.
  14. Sliderman
    Highlands.
    Haha, yes mate, they are well known for their bastard wire feed issues. I have one myself, have replaced the liner, swan neck, wire, tip....etc.
    And don't get me wrong, it's better, but I still get the old tangle of wire inside the case at least once each time I use the fecker.
    One thing that can cause these issues is as mentioned, dirty or kinked liner. They're around £15 (from memory), but apparently boiling them then pulling them taught and allowing to dry works well too. Not sure if you'd rather just spend the £15 though haha.
    Don't forget to check your wire feed and tip size though, I know it sounds obvious.
  15. gaz_moose
    gaz_moose .MTM.
    round a bend
    you know you can get different kinds of torch liners.
  16. supraslide
    supraslide Member
    In a house
    Are you welding the same guage material as before when it worked?
    Is the wire burning back to the tip if so wind a bit more wire speed on.
    Check the tips especialy the gas diffuser is screwed in to the torch tight. Check that it isn't arcing out through the shroud. i.e spatter build up on tip.
    Wouldn't recomend overtightening the feed roller as everytime you get burnback and it sticks to the tip you'll get a birds nest in the wire holder and spend half your time re threading the torch. At work ours are set so as they can slip on the wire if there is a blockage.
    try turning the gas down especialy if you use co2 as it cools the weld effectively reducing the power of your welder. the output on mine is set at 8psi. Not a big fan of flowmeters.
