As above is this a big job I’ve rattled my bent cam and been offered this at good money. The engine is from a rwd car so is there much wiring work to do? thanks in advance
first link on google, might be helpful http://om1kron.blogspot.co.uk/2008/12/converting-s13-sr20-redtop-harness-to.html
The engine itself will drop right in. If you can get the engine loom and ecu with it, your job will be a lot easier. If you can't, i don't think it's many wires that need to be moved.
yea but usually on a site based on drifting, it's usually a given that it'll be Rwd. Especially since it wouldn't make sense to put a Fwd engine in an S14.
I’m currently doing this conversion also on my s15 , Engine in and plumbed up was easy and can be done in a day, I’m now looking into the wiring too, looks scary but that writeup looks pretty good, Going to start it next week ....so can let you know how I get on.....
