R-Body Geomaster Prototypes
Thread in 'Driftworks Products & Enquiries' started by PhilMorrison, Apr 12, 2013.
  1. Tumic
    Tumic New Member
    Awsome!
  2. R33build
    R33build New Member
    Wow well done! Any idea about the price?
  3. jayz
    jayz Member
    Price?
    Will I need to purchase a set of s body front hubs?
    When are these going to be available?
  4. ash1987
    ash1987 Active Member
    Any update on these as i want to make an order but i really want to include these in it
  5. PhilMorrison
    PhilMorrison Driftworks Owner
    Staff Member
    If all goes to plan the price is going to be about £60 more expensive than Sbody.
    You will need Sbody front wheel bearings.
    They are still working on the jigs, as we cannot have any mistakes with them. We hope to have the first batch in about 3 weeks now, but there's no guarantee's at the moment unfortunately.
  6. DtheBUK
    DtheBUK Active Member
    do you prefer running these to the s body conversion you had on the r32? can you give any sort of comparison?
  7. snaptec
    snaptec New Member
    @ Phil
    is there a possibility of pre ordering?
    Would like to drive them in october.
  8. PhilMorrison
    Staff Member
    As soon as I have a more accurate arrival time, we'll get them in the shop for pre-ordering :thumbs:.
  9. thai mai shu
    thai mai shu Member
    I will be pre ordering as soon as possible!
    - - - Updated - - -
  10. PhilMorrison
    Staff Member
  11. crazyae86
    crazyae86 Well-Known Member
    thats great news .
  12. Tumic
    Tumic New Member
    Do you have any set up guide lines for the front end on the R body? caster/camber etc?
    My knuckles would land in my box on thursday but it would be good to have some tips on a basic set up or do you run them similar to the S body set ups?
  13. PhilMorrison
    Staff Member
    As always, offering set up advice is difficult. I can only tell you how we've set out car up, but depending on many factors like lower arm length, wheel size and offset, tyre size, and clearance in your arches, you may not be able to get the same set up.
    We have around 4* negative camber, and set the castor quite low (we don't have a figure as it is set to maximise steering lock primarily). The low castor angle means the wheel is quite far back in the arch, and we've had to massage the inner arches (hammer them lots :D).
    We've found the the offset rack spacers make a big difference, and I now genuinely feel that our R32 is one of the best steering drift cars I've ever driven.
    It is very very important to make sure you have full clearance in your arches, as at high angle any small contact between tyre and metal is like putting the brakes on on that wheel, and makes the car feel very unstable.
  14. MALX
    MALX Active Member
    looks good fellas, any ideas on price?
    - - - Updated - - -
  15. kam
    kam I've touched Chris Parry
  16. Tumic
    Tumic New Member
    So am i the only one who ran in to this problem on the geos?
    The knuckle hits the upright..
  17. PhilMorrison
    Staff Member
    What car is it? we've tested with an R32GTSt and R33GTSt upright.
  18. Tumic
    Tumic New Member
    -93 R33 gtst 4dr
  19. jaffa
    jaffa New Member
    Do you know if the fronts will fit the z32?
  20. kam
    No they won't, different setup with Z32.
    You can convert using R32 wishbone though :)
