R154 + bits
Thread in 'Parts for sale' started by dan200s14, Mar 9, 2017.
Tags:
  1. dan200s14
    dan200s14 Member
    Shepton mallet / wincanton
    Good working r154 with jz bellhousing & 3" extended gear linkage housing with gear stick and gearbox mount bush also inc with the gearbox is a used exedy hyper single clutch & flywheel. The clutch was working fine when I removed it but it had slipped when I exceeded 450lftlb rating worked fine on lower boost. Flywheel might do with a skim but as I said was working OK when it was removed! £1300[​IMG][​IMG][​IMG][​IMG]
    #1 dan200s14, Mar 9, 2017
  2. dan200s14
    dan200s14 Member
    Still have this!
  3. sideways dan
    sideways dan Member
    Hi mate what year is the box. What car is it originally from
    Cheers
  4. dan200s14
    dan200s14 Member
    I believe it was a mk3 supra and I vaguely remember a mention of 89 but nothing to confirm
  5. sideways dan
    sideways dan Member
    Not the newer one then out of the 1jz cars. Does it have a electronic speedo or wire?
  6. dan200s14
    dan200s14 Member
    Its has the cable drive but I just sold the converter to a guy in Spain with a bundle of conversion parts. I can ask him if he would sell it back if you wanted the box?
  7. dan200s14
    dan200s14 Member
    Sold!!!!!!
