r154 gearbox markings
Thread in 'Technical Questions' started by gtirtrack, Dec 29, 2009.
  1. gtirtrack
    gtirtrack Member
    surrey
    is there any markings on r154 that i can look out for to check the box is an r154. thanks :thumbs:
  2. jdmjza70r
    jdmjza70r Member
    mayo ireland
    Unfortionatly no there is not as toyota do not mark any of there gearboxes as far as i know, why not is anyones guess
    but if you are looking for ways to spot an r154 i can tell you that they weigh about 45kg without oil, and take about 3 liters of oil
    also the slave cylinder is within the bellhousing
    what car is it coming out of??
    Also measure the sandwich plate should be 9.5"
  3. Jason
    Jason Nurse?
    Kent
    i could take some pics of mine if that helps? they look pretty dam similar to the w58, unless they were side by side it would be hard to tell... they are chuffing heavy!
  4. gtirtrack
    gtirtrack Member
    surrey
    had some brilliant info from mrsteveo on here, so all sorted now.
    cheers
  5. the stig
    the stig Active Member
    SE london
    ive just recently completly rebuilt 1 of these!
    yes there heavy,but man there quality internially:nod:
  6. BMC
    BMC Member
    N Ireland
    can you sheer it with us please :p
  7. gtirtrack
    gtirtrack Member
    surrey
    i will find the link and put it up for u guys.
  8. jdmjza70r
    jdmjza70r Member
    mayo ireland
    A w58 is 35kg dry and a r154 is 45kg dry
    the w58 is connected to its bell housing using 9 bolts and two dowles where as the r154 is connected to its bellhousing using 9bolts and 4 dowles they are both exactly the same lenght but an r154 is an inch or so wider and the input shaft is slightly longer than a w58
  9. DaveM
    DaveM flickwandoops
    Stroud / Fife
    I could be totally wrong, but does the W58 not have 3 "ribs" along the top, and the R154 has 4? Something like that anyway...
  10. jdmjza70r
    jdmjza70r Member
    mayo ireland
    ya somthing like that dave but in nt exactly sure w58has 3 but nt sure how many r154 has
  11. DaveM
    DaveM flickwandoops
    Stroud / Fife
  12. MR-steveo
    MR-steveo TNS MAN CHILD
    mk
