R154 gearbox s14 1jz conversion
Thread in 'Parts for sale' started by carters14, Nov 29, 2012.
  1. carters14
    carters14 Member
    berkhamsted
    Hi got the hole gearbox setup out my car
    R154
    Jz bell housing
    S14-r154 prop
    Slave with braided line
    Folk
    Shifter
    Gearbox mount
    Extended shifter location
    Lightened flywheel
    Starter
    Act 6 puck
    Everything neded to do the conversion all in one package pics on my face book (matt carter)
    £1800
    #1 carters14, Nov 29, 2012
  2. carters14
    carters14 Member
    berkhamsted
  3. hpidrift
    hpidrift Active Member
    Dont suppose you would, but would you sell the extended shifter and braided clutch line seperate?
  4. carters14
    carters14 Member
    berkhamsted
  5. carters14
    carters14 Member
    berkhamsted
  6. james_eurospec
    woking
    You got the gearbox mount and prop dude?
  7. dale_b
    dale_b #DriftFactory
    Surrey UK
    ^they may not fit James, your using a 1uz so not sure the gearbox will be in the same place as a JZ would put it.
    Don't worry man, we can make a mount once the engine is mounted.
    Free bump Matt :wack:
  8. james_eurospec
    woking
    Okay dude, I have a mount now, only just seen this :( but it ll make a good template :p
  9. C1arke
    C1arke Member
    If you do split I will take the bell
