building our comp car here with a 1.5jz will be around 500bhp what gearbox would people recommend cheers james
I'd go BMW. Cheaper to replace than the R154 and CD009. Also depends what car it's going in as the CD009 is a fat and long gearbox.
It's going in a 180sx which we have already modified the tunnel to enlarge it what conversion kit would people recommend
good timing for me to see this, i'm putting my 2jz in my SX and want to use a 6 speed bmw box, stuck between the GS6-53BZ (petrol) or the GS6-53DZ (diesel). Apparently the petrol ratios are longer and a bit more friendly especially for my 3.9 diff I just need someone to 100% confirm this. The diesel ones are 10 a penny though and common as muck compared to a petrol one...
If you already have the space, go for the GS6-53DZ. Nice shifting dual synchro, very strong, well priced clutches and good gearing. The diesel ratios are going to be fine, especially with a 3.9 diff. The 6th gear of the GS6-53DZ box is almost the same as 5th in an R154 (which is plenty long enough).
What i would say is i bought the PMC kit for the 1uz to GS6 53DZ and wasn't impressed. For not much more money i would have gone for the Driftmoto conversion.
So you want the box from a E60/E61 530d with the code GS6-53DZ. The code is on a yellow label on the side.
CD009 Would be the best bet on it, there seriously strong and proven already and the ratios are good. Although if your building a comp car you would need to be more concerned on how much youve cut out the firewall
"Competition vehicles must retain the original OEM unibody and/or frame structure between the original most forward suspension or sub-frame mounting points and most rear ward suspension or sub-frame mounting points, as seen in Fig 1 + 2 (Front) Fig 3 + 4 (Rear). This includes floor pans, bulkheads and ‘A’, ‘B’ or ‘C’ pillars. A small amount of material can be removed for a rear mounted radiator, excessive removal is not allowed. Strength must not be sacrificed."
For example, also the tunnel is being made from 3mm steel so will be around 3 times stronger than factory 1mm {}
