R32 GTS25 Four Door Slow Progress
Thread in 'Project Cars and Builds Threads' started by Tommy59, Jan 6, 2015.
  1. BenRice
    BenRice Well-Known Member
    Mt Maunganui, New Zealand
    Nice!
    fwiw I had to trim my exhaust manifold heat shield to fit the compressor housing on the new turbo, so may pay to do a trial fit
    Like your choice of catch can btw, keen to do the same!
  2. Tommy59
    Tommy59 Active Member
    Milton Keynes
    Some goodies arrived and being stuck in at the weekends gave lots of time to get the bottom end sorted
    GYkkS4lI5QW5DNQt3duE6L-6Nx9oOEndDxZxpOAa912ExHSlxKSCRhJUTVWzqt85_kCmqJIw3Tvqu7Fr-c=w1250-h937-no.
    KvubHJjKUVKbTzleH4nFiAaRSbHZBL9Wy4G7pun20ixYlmm54cqRnog94VoehoDdfHGjaAesLI7rLs2WGB=w1250-h937-no.
    7u75rQjgrKfZkO0FsfNZEQt09nasnpsMdu33CHGu4NK6oOE5widCUtEYAFgs6HdjV5bu2o0_pRwpdDr8zL=w1250-h937-no.
    SfT7lZIVGtJekGU2MK6v-5840Q1prFJmr7yGbPFskiRCdJU0jxZ6sKLTGqEnF0uvrOJd8X7BpkESvMhb3Z=w1250-h937-no.
    For this build, I decided not to fit an extended crank collar, seeing as it's only going to be running around 350bhp and RB20's don't make enough torque to hurt themselves
    0hpiqEJxVoxVs2zBa6Yxb8YnBlpPu6v5FlWpPL1b25EbB74CilP5ccVVTXqV_3dULz9MPo0Y7eFqmYI3wP=w1250-h937-no.
    Gave the torque wrench a good work out
    _WIjr5PXcTSzUrMMLI62J_zWMLbmTyQO1fgDCX7YqMlCHnjTxxh4b9qln3ibyx1RDrR3K_Jx8bfFxqLbeV=w1250-h937-no.
    M63qKqRWLsaSgKw_3FpFaqbgP2tjAI8zvlVH3v8liNWGxwSMaNUFDA9gCw7C-y-T0yPTtMPR9NeH-6LYSQz=w703-h937-no.
    tJqdNEbsk_Y6aKPX-ZfukUftHHfaUzFbNtAaSHydR85IXaGTi4giUCMfOJBkkUFNpiUNB4fTK0CRQXSjgn=w1250-h937-no.
    New front and rear main seals were put in, the original oil pump was inspected and everything was inside tolerance with no damage so I reused it.
  3. Tommy59
    Milton Keynes
    I got the piston rings mounted with the gaps correctly set and aligned
    cAMVbG2hXVYXeAHo22oATECzGZOHWVGnZtHBI6bRyUns8pvxu-pgeFEs-xCYDILTUD2cO7faAzeN1AjuPpB=w703-h937-no.
    Pistons in
    DnSjUyqEyv3djDtaIhWLauB4D8FHcIQp9OvR1UAx7gWVKxsERCy7W-Ca5VSx--4MDUAcJWPSlIOUWmkMcrh=w703-h937-no.
    Got all of the pistons in and ready to go
    IFQCd0jDyWjHQDc2lixXJCNNZduyZmYkOZdWmCoaePdbIGbeIjt65MKIPPMW2Y-t-c833P44QffnRrfIzGa=w703-h937-no.
    GFVn2reomA1srNqyiAbKQc2QV1X8dtdnYggxEKwLdlU6F3ZsZpSxAwlqxjcd_UcrRsE2TW1LIweYcCEQIFe=w703-h937-no.
    Sump mounted
    69sEufLTyjjvmhPJ1dRHX5aKnboSyzy_3bhSPLmfXzkc6nKT5AU4KIw_6Nj26wqqVOEIsadW6hb9OdpkoFW=w703-h937-no.
    Popped the head back on, just to get a look, looks awesome!!
    WUi3ybh6NkM5-6hVDbPcm7pW624puVcTNz5JPvc03qjLlWfWDik3IpT0Rd2_uZBK2wZbK7nW6B3n9UJlD20=w703-h937-no.
    • Like Like x 2
  4. Sammyboi
    Sammyboi New Member
    Finland
    Tidy work. This is build quality! Nice touch with the brackets as well on the last page.
    Keep it up.
  5. Ben_Dean
    Ben_Dean New Member
    Dartford
    Awesome build mate!
    check out R32 Sedan OC UK on Facebook if you haven’t already
  6. Tommy59
    Milton Keynes
    Already there buddy!
  7. Tommy59
    Milton Keynes
    New headgasket on
    5jWeDFqM53DDTBX4Chgx5SUpbY7H2rmbQWvO3fi84on-OlpDbBIpYeTGOH8Hqh7S1jC9-jCfVpFZq7B-KFM=w703-h937-no.
    BR8u6zmcbBF7pOX-3fflLEcxpp92eiBd96A95J1qbFtal3rhO4sV6mUbimZWckUmJsoov7xo47A7PYpVW49=w703-h937-no.
    This time around I ended up threading each ARP head stud through the head into the block rather than fighting to try and get all of them to slide through the head.
    tF9XmvsNq8LBjpyc4_pXbBoZUI8iVTuacKgB8MzZQdBQxVVmdKBieTxlFTCSXen7pi09TJUiWynGJCptcb=w1250-h937-no.
    Neat bit of line routing and painted plate
    xWPOx3mVGMXGsfa8krVygMc9GwJI3HXG8xOtiX7Dds2tyZp687CnOgR7CadB_lL6t2lCDhOnjnE96m4UMRD=w703-h937-no.
    nche8hf_Vkfzzg1uNK5smAp1MQpbqI8evRzOGprMKXPAHxgCfkZFTWpjXiwXVCL0203CGhbxemwcoGTbTH=w1250-h937-no.
    Clutch isn't in perfect condition but works just fine and plenty of life on the disc.
    1VSitzexmmjfBaLe6c0AAckA68OBAi7U2etO9tbcmcTJ490M8Bv2LY7HJbYi3pK0S9iyZktOWeFAg0Ky6gK=w703-h937-no.
    izwef-UskqQEQO-ehJfV7e0Pb_WZXoqEnss4UP7KwsN8cAOs-8B_19VvldzZA-SCQ4KoDEsCEwtEPjXTx5Q=w703-h937-no.
    jYZkNJa7h7s2qr_5N6Zzk5F-5n4-UKnbOXIM_Q5jDHV0h2kMcC-oPEr_01KHbQjKF7EC-eQ0ue6UUsU-X0z=w703-h937-no.
    Now, I was expecting a fight with the gearbox, each time I've put the gearbox on it's taken 4 hours minimum to get it lined up and bolted on and it's been a disaster. I don't know what I did differently this time, I was a bit more pedantic with the alignment tool, it may have been that but I got the box on in under 30 seconds this time, unbelievable
    C_-YAMKGrxxuXoLa8wYGa0ziwbop3StoN2zQPpAFO0woXLv2llpI7kzxca7PbgTspxaKOTHOgTU9C2Pnor=w1250-h937-no.
  8. Tommy59
    Milton Keynes
    Time for the install.
    I was doing this on my own with an engine crane and a cut cross member which does make the job a lot easier but still struggled getting it over the lip to the garage. It did involve some sketchy use of a scissor jack but got both front legs over in the end.
    8aR8TkMdEc2GUZr0J1TPdtr91dwWP-evsVI883jmqxFP4Ap4rShYGBirhVrDEr2bffUHFopV2z1hHn7Gws=w1250-h937-no.
    A7FhLMjeOo62Xfbn_Jk50LCKMLhm_M9CdDx9p-IHwwFccvByFEKuedRDwvd6fCU6q_xj5nnql_vepfwYoZ=w1250-h937-no.
    And touch down
    5HIMcfo8SF2wyErhi5Xeok5BZXCFkLT8UZSpBilVvDv6ClYUAnKMzhmecRefZ3sCpHh2IFn7kr7tKNuAWJ=w1250-h937-no.
    There are a few marks in the purple on the firewall from some swinging donks but these things are very difficult to avoid when you're doing this sort of thing on your own. Hopefully can get them touched up!
    Now I have to admit that the engine mounts need replacing but at the moment I can't collect my new ones due to the current situation so I'm planning on swapping them out one by one before I get anything else fitted up.
    Started work on some smaller jobs like redoing the factory black paint on the headlights
    ris7aQ1VZQsrisf-EbtLyNhdRVQnitg9_5-lmvQVEKCr9iZwnOxMMZGWsAm5vSm-LNIdt9IE0flaQZo7Lo=w1250-h937-no.
    You can see the difference between the two
    wxtE3KDJ16o8g4-NG9N4pQI6Czhd37Zf4pa5Jn3CuFnZMnxF-ZmYLc8c4zUE3MnPK8wEgbKL04x_92PxDJ=w1250-h937-no.
    Plenum placed on to check clearance
    Kr_L57F2f6SzX9j7r0XgD6K80Rqyo92QVQTgd2NpODo5zSfjba6Py-EitXOvi5Z6LQdGETyLpnMojsUECn=w1250-h937-no.
    I've also wired in and placed my AEM wideband gauge
    _KvfyJ0clbzi4Aw5giUZNVagc2rb1V7TTtn_Zf8wSy2obxYbWwM5RwC5LGwUR1MzWdnupRIaVwQMqO-lVA=w1250-h937-no.
    I also started some work on future parts I'll need. I want to retain the recirculating BOV that was on before but I couldn't find an adapter for the stock flange to match 2.5" pipe, I measured what I'd need and out it into CAD. Hopefully can get someone to make it out of billet for welding on to the pipework.
    N29ufKn9Z6_WVO5y2x2RFkxZpC-9U0t88hwGCFCIkal6IRlW6BGjQqMjfxNy4-gZAWUSVX2sMB2d5Pw08q=w1250-h937-no.
    • Winner Winner x 1
  9. BenRice
    Dude, awesome attention to detail!
  10. Tommy59
    Milton Keynes
    I started to get working on the inlet side of the engine
    Everything is close enough to where it needed to be
    it6F1odaFBaB6hA-iL4jD1FZfn8NKOVMw4m-zpC-pGXETdKMyhxiJi62TFFrWiUyilZn6SZA=w703-h937-no?authuser=0.
    I added the oil cooler sandwich plate and lines.
    You'll notice the fuel filter isn't in the usual place, I thought that moving it here would make it much more serviceable than usual.
    Also note the length of the oil cooler lines, I'm not sure why I made them this long, it may have been easier to install with the plenum in place.
    JEj_e3lDsSokpC_6LNkyHPa08nTh0WWprpb_ee3b37zRvV6rFKkCtWNkc6ZCMkzGx_ugG6PQ=w703-h937-no?authuser=0.
    New inlet gasket on which I was loathed to buy, there are £4.30 in Japan but all about £30 here.....
    KXFy52HTFNLWkXoAIbwrbMB8tXvCs_xlvOdoDPq2BGNDO1WweSCuc_oFhyWaiVn0XUu8Q6g=w1250-h937-no?authuser=0.
    Power steering reservoir painted in the usual wrinkle VHT, I've had one of the returns welded up as the whole HICAS side has been blanked off and the lines removed.
    ICFSIfJRmK4VKYdu2WX0KAla28QdOvqjfg9dSKILMWE-CY6Cquvsjdpelh3t87ZTGzY4LVw=w1250-h937-no?authuser=0.
    Lower runners on
    p-D9ZyDVB78IIxcK08RwVYh0FnokXG6esT3bnqLZnxdX0Qh9187MSWu-VF_dyE8ui53LBnFA=w703-h937-no?authuser=0.
    2zjJqwx-LDRK0lRBrQ1lqkJuuMF00BtgkfnoNcm5ODf2HW2uVv6BuxuBhpNpWJLfYVdoBOvQ=w703-h937-no?authuser=0.
    Now adding the top plenum was a bit of a disaster, unfortunately the bracket for the throttle cable hit the fuel filter and the oil cooler lines.
    At this point the only way to get it to fit was to put the fuel filter back in the stock location, so I had to move that back and remake all the fuel lines to suit.
    I also had to cut about 150-200mm of oil cooler hose out to lower them down below the runners, thankfully the AN fittings went back on with no troubles and I didn't get stabbed by frayed braid.
    I also had to work out all the sizes for the vacuum fittings on the bottom of the plenum which took a few attempts but they're all in now.
    The bolts also needed spacing by about 6mm to engage the threads and clamp properly.
    vYsrCDFa_Tz78phhEZsn7m23X0aD9Km88quBZaVDrByJlMy6IYBgoD8jhuLv0bhT6FtF7Kw=w1250-h937-no?authuser=0.
    • Like Like x 2
  11. Tommy59
    Milton Keynes
    I added thermal shielding to the turbo oil and coolant lines
    BtkrFwG_bIZvcNpFCqgILjSTpr69E7gzBuEKl9qZWN8tyCkaa_MmN89Vo9xsj8vDkPKq5qWw=w703-h937-no?authuser=0.
    I remade the intercooler brackets out of thicker metal and got those swapped over
    z9D4IYPTsr8rEYASa10U5Dha-WApFuXSdBIk6WmqyfVdPckL1zU-HvHXX3L9rsQvHYVo_4A=w1250-h937-no?authuser=0.
    Now the stock throttle cable was slightly too short for the new throttle body location
    Plus had some lovely rusty brackets
    qxaMzO-MxRfeBmoKKbxFWAs0TYMKfFOq54sO3EyCbj9IhM8mRXp527pTEbrxXBWxFUm6iwQ=w1250-h937-no?authuser=0.
    I bought a universal cable but it wasn't OE quality so I decided to try and make an amalgamation of the two
    Throttle pedal was just as rusty but I'm starting to get bad at photographing everything
    Rust all cleaned up
    fUfu8tHS5UMu3d9eeuFFJ9xRb64Cu6vD7XgF-6LacYS1Oe4OFiwrbj4OR1tDyXYre_YlFx-A=w703-h937-no?authuser=0.
    Painted up and reassembled
    KvsobFyJe2kVSWZ-0keCFwOUdTX1EgVHKeLLNNx_EKsuBhNWYG9GfSkrHLoQt8mm61wrPjLA=w703-h937-no?authuser=0.
    I transferred the new longer cable and sheath to the stock hardware.
    I had to cut the end of the stock cable to take the pass through for the pedal and the flat end stopper.
    I used a 2mm drill bit to drill through the stock stopper, fed the cable through, moved it all over the car to get it in position and measure the length the cable would need to be. I marked it up, took it all back out and cut the cable to length.
    I ended up putting the stopper in a vice with the cable through it, now the hole is 2mm, the cable is 1.5mm. I used a blowtorch to heat the stopper up and fed solder into the stopper to flow between the cable and the stopper. Once it started dribbling out the bottom I stopped and it seems to securely hold the cable.
    Now I'm not 100% confident on this, I'm not sure what everyone else thinks?
    I added the bolt stopper behind as a second stop just in case.
    8Ss-ODPwhapG1hTO5dl8mc4j4VS_9DFtBOGqvdK_Hse_P6LR5pxKsE0FMl7oxZYuycly6yBQ=w703-h937-no?authuser=0.
    I picked up an RB25 fan with now cracks compared to my collection of cracked RB20 fans.
    4t9g0fOT9IrK4I_eHaJSiEgwpxbHT-2XstdoEPN9ATLpc5b6CxVOxsYJETsnfA8Ui-5gTOvg=w703-h937-no?authuser=0.
    bWjJNgKNWCFK1opB4SszKXu0YhMBgYCMCZbkrNoRRGjDDzy7-pO4vRgf18spa86H328IQUQQ=w703-h937-no?authuser=0.
  12. Tommy59
    Milton Keynes
    Just a small update for this one.
    I picked my turbo core back up after a new oil seal and re-balancing, seems it was 4g out of balance
    6Fxkr-OZ80lOXP39ZzTFwOshiGBtIHOqxkPaWH87iQmA_bco1MkUKi6iuOhVp3uALIHMAnPQ=w703-h937-no?authuser=0.
    Reassembled the cold side
    Ct5r7kVf-8iP33Tw3dtsuZv1Nsyxxeo2hfNc0dOEVaUxapLZ8AgNpDsOGz_sK8pgvVmQkzlw=w703-h937-no?authuser=0.
    ZZTGoITEANlU3496Teb2VD7ZCq8OPksJ_XJ8plD11diiGlcABqDXElgC-fdQuKYjeuhmPcw=w1250-h937-no?authuser=0.
    I'm waiting to get the exhaust housing back as one of the threads got stripped so is being helicoiled.
    I started another mini project which in my opinion is completely unnecessary but I could do it, so I did.
    Intercooler sprayer
    S6zDrIMOof_ALCt2tgGwpm6jiNdsoUt908vqGWmq_Vg7woausGIGN7rt3tVt9k6GObhwjXQ=w1250-h937-no?authuser=0.
    I have no idea how well this will work, if at all, but for the sake of £4 mist sprayers and £2 of aquarium tubing might as well give it a go. It's hooked up to the pump for the rear window spray nozzle. Will try it at some point and report back.
    • Like Like x 2
  13. BenRice
    Nice!
    Word of warning on the sprayers - run a check valve otherwise the water just slowly leaks out after the first squirt
  14. Tommy59
    Milton Keynes
    Got the turbo mounted up
    _yfJRvVTDp6wIcoUZd2twZ2L9ZVd-A4HFdBWRzEqjiv62IxnZnAT__PBEa72Ns9noxfiLeDA=w703-h937-no?authuser=0.
    oEYjIDVkvUn_0XXn8t0XQXIJmmqWKodhuV1GJgW13XO_O44n2IsrhYREI3NOCoXfXxsXOcXA=w703-h937-no?authuser=0.
    fwoTCxZKrv7fF3YuvJh6-qx-G9RZR0_rceTHS92npCLEdB33mpnFHGBk1gZBJrzDUtTO9CA=w1250-h937-no?authuser=0.
    f8B_K3iat7ix-EgxycQM_Dt_aZPDLqkVfmgub5q4Tet3n1_-nPdks_xICLWHAG2eCIp8GFQ=w1250-h937-no?authuser=0.
    I needed to slightly adjust the heat shield for the manifold
    i5KKHtJG37Mfy7SWSAVjdw5wcp906UdsCEy1-v6hQIVJWEzrZA5lNA99-BPRPJjmnatiFfA=w1250-h937-no?authuser=0.
    Made a small covering blank to cover the gap between the defi's and the headunit
    qeFFGjEzq4IuQdsgP6W0FUb3A4nHzfJUaORiLc6C5Z-gBJCIvVRxdKdLy8NKku0HRaiV71g=w1250-h937-no?authuser=0.
    Started making up some of the pieces I need for the engine bay
    jXXFh7wgbv2h8E6igFuB1capn9i1Mwl5L5TYQpqXOA7IQDGSl5WrwHs_5N-Kh9nEoClziUg=w1250-h937-no?authuser=0.
    Next up is the pipework which I've been putting off for ages
  15. Tommy59
    Milton Keynes
    Started chopping up the previous pipework to see if I could find a combination of existing pipes
    OC3bBzKfsmAX2PuF0FND4OGiXNQzni6FeXefxzE8a4eSZ3g4Ac8wtR1N3OCR9YQteCAnvBdA=w703-h937-no?authuser=0.
    Aksd6y0vdR24mghVIzpjwibz4Mxj3eaUkpwTNR2eKUxe1T_UNH0AWiamuI18nF52Y2TCGHA=w1250-h937-no?authuser=0.
    9NNSiW5KCrRPKVb7Y-k59bvuPoYYoPcbkk52YcLqA-gqf8_KGMHOJ18lWgBVtPOMKyQJbLQ=w1250-h937-no?authuser=0.
    xzJOi_-O9RNIpPiTEs7hqBoGH3XZehyZcEqgz9nfNkI_0lcgS4auUGywW0efbqYJyUBYzOw=w1250-h937-no?authuser=0.
    6lFh7Cf23BnmApB6wvecWI1NdT6ulTZegrQyMm4RH5DiUYqhSEb1VVKsauoepLQybh6eAyg=w1250-h937-no?authuser=0.
    Test fit of the bumper to check everything clears
    XA1gsVcbrvqFR3mTtRWDeC3KotzfbSM7F4RcWOGJwkn_LbLHoIFeQK9LajYVyIb__fHjR-Q=w1250-h937-no?authuser=0.
    Seems to work OK and managed to redo the pipework without having to buy any more so that's a small success!
  16. Tommy59
    Milton Keynes
    Now for the fun part, well, bit of an unknown for me as I've not attempted anything like this before.
    It seems you can't buy a weld on adapter for 2.5" pipework and for a stock Nissan BOV pattern, so I had to get creative.
    I also needed to replicate the coolant bleed point on the stock upper plenum I no longer had.
    Plus I needed to add the holes in the pipework for various vacuum ports and adapters.
    Cue the pillar drill
    VsRyuh2Dg9LoIFMTe0CIKeTIkYWlZf6i62CZJYqbO7adks45X6ehW3ijMp2YYpMFbcWwydA=w1250-h937-no?authuser=0.
    1TM6sYW0DSrZHmKlp2p9fIZBhzuzIlaSRWydyHsVXz470pX5vNWGBNMJRudergzedeTWQrg=w1250-h937-no?authuser=0.
    ZZzipbdDkpYDD5PODTaSUsHORjruGZLMPD5aYBBihuPdnDjH2JkuIl0Wx4pN4B2EHGF1Opw=w1250-h937-no?authuser=0.
    5j8L6mQ7mqHp7h2iseB8p1vJZorU6Mtr4SGHDNFXtcWQX9oxedK_4c9efpzXS1GGT_uuyQg=w1250-h937-no?authuser=0.
    nAw8WiixyrzvM__YnoCTaGL46e6Hfv05bfvMWNmQDfUsr0i03IBpdshjUd80lXetmBk25nA=w1250-h937-no?authuser=0.
    -GGjkdI7Zt3LbjP1xUDZ2NoY_m9KX29eW8oXOSUqX4DXd6MyoT0s8_uaht2uHrDGFF5bsJA=w1250-h937-no?authuser=0.
    f7OZu4nnkBZr00HrusM06RnFLRYfDWOQFmOsewUNHP5ErPMy8VOmEJLqBZZGeJjNYAQlH5zg=w703-h937-no?authuser=0.
    LzT4ElVA17Erita-Jhz0v9o8E5_xvsr77o1uduMSRb1TJSGm6ZMTVkJ9HKyZD8yI2-r9W9BA=w703-h937-no?authuser=0.
    TmwcGkb20I-I59q_KxcviiUIOJmU7bVTMrIuZ7lmZqqM02FCiK6jvKMQVTcMo0WXw-IZt9zg=w703-h937-no?authuser=0.
    a3xjBMCN0UmaljTxIO3Pa9VhKZUzKQnOU2Ua2rFXv2R0fr4970rUvdbMgqx3jYZH0V0b1iCA=w703-h937-no?authuser=0.
    3qCFtzg_1wefSql8R3pd9IigPUe79oaNnen0juUBI7acE52giTt5pVDvbi0IDTvmocYngOoA=w703-h937-no?authuser=0.
    oaYR5t_pVqxRml31PYMqpt-DtYICCVkdWVqMGBi1kFALwKBUAW9RuJtPJGqY4cGHPP0eY4w=w1250-h937-no?authuser=0.
  17. Tommy59
    Milton Keynes
    Fabrication part 2, the BOV flange, this was a tricky one and it was by no means perfect but it worked correctly!
    WmY8OLKPJqmeQb2lR1odcIFnkkH3dgGSsHLNw4PBUQj6SkyFbOlhFZ0KcLHDk5HUvzjjdAQ=w1250-h937-no?authuser=0.
    ws6AJOKsty9T8qpBu_B_4QnF8J7lwQnTKmBAO85WqBM4zuOcbbuzTGemd4rnXRUgdD09pBSQ=w703-h937-no?authuser=0.
    ykRthWhfuIibJvaHhLCG2UQCz1lD_Bl1EiRWIEBXeI_fBSWFk8dVehzOVDlrfQN4ZzUOnqMA=w703-h937-no?authuser=0. nWwU0Tbh2veLRtjVFcwlk60M3Im6BAf1MTTTufMQsMRvcjZfYpW1nB-1aAMeWfku9DIzjNHw=w703-h937-no?authuser=0.
    qCeEOdkvfIRUHIV5nITTELNpj8l9p1i4Q7Ae0LFlQYznTVgCa3qbm9g6GqHps7CKZtp14qg=w1250-h937-no?authuser=0.
    _ne7-d82giB5hlvLEC9xq8-ncZlFrrE6-32gm9HVmWDTWBFqKxet6zv7o2cAw4RvbLos-ZQ=w1250-h937-no?authuser=0.
    Swarf, swarf everywhere and took a good few hours but got there in the end!
    Will sit something like this with the BOV piping sorted
    65yJI8x0HYBgJewn2dCG75yoyJ1MZTXb4AZv0X_3yvlDQijcHwuuIrGB8N7Ql9v5QesQAThg=w703-h937-no?authuser=0.
    l7pz8lhnX_AQaZTG0J-k7RgvYpIbCCPvoKaM5lEUCUAxli-fNKBNwv5tL9dA2yF93_1SQuA=w1250-h937-no?authuser=0.
    Yes I know the BOV should be as close to the throttle body as possible but rather than having a giant hose lying across the top of the engine I've mounted it on the other side and it will still work properly.
  18. Tommy59
    Milton Keynes
    Time to get the paint out again, of course wrinkle black
    FSEpCNBuPbJu0pcSi1mitatWnfBENRD-ZlfjXbLMWpKytU7mvlm6jREPRbYGKnv2214N04g=w1250-h937-no?authuser=0.
    lLdqvaAm1eshYWh_dnQ4cmTAoEVFUkaEeCSFrsCt6kCAyW5Xuz6V7Xi4leJc8Up4T7YZcFA=w1250-h937-no?authuser=0.
    FZ3Zag4MxWq2FzWo7DzhKWPWMc3vEmMsvuVaQw9BRVyhrC7bpm4-gu_CWatuFRsc4NVoasg=w1250-h937-no?authuser=0.
    Z-ocl3Z7CQUKUNROyCsc7YQMk9KDGT21Og7IutjfXmolnShyU7PWBApUJNWyp6EOw9EYkOQ=w1250-h937-no?authuser=0.
    7g94sOF5S_lIcAcR3lZm4kcQiIwjb1gp4XpNqcDxNwcvAoSqobbP8hfIJBM8WOXVrPrdDBig=w703-h937-no?authuser=0.
    txXxM2X9iuBu5zZFOqo_9BKzMR3-ylEWvbIlin7gR6u0YMI4p1FNSMGa1dhvEKnBJcCZ4L8A=w703-h937-no?authuser=0.
    8iP6oZrWcZJEJZRFT9pIUKyMl6_IXNKD3OQF0crKRRDKImpPTePqIw_gz--gvjuFh9nKOQQ=w1250-h937-no?authuser=0.
    6qn_moUNKm5urNYCafsAo9re6gtTgwNVOYABxIe1iXEb-qvZBDJLtAiv1f7ypJrwJubbMLg=w1250-h937-no?authuser=0.
    e3ghl-zkxnG5lS1qGntY7LCjuyo8phP5MrPVGNSy6vvtWwu4RCinUTs6EW3VtZQC1ZRyQlg=w1250-h937-no?authuser=0.
    Here's a Skyline pro tip for you, if you want to check for vacuum leaks and need to plug up the intake, good old John West has you covered
    AIOl_zOHaNezKKZnangOwQx9-PI7MUZ_LKd2WXiSEu_ICZcsYtgWjmJAl6tXaePQ-w8kuWZQ=w703-h937-no?authuser=0.
  19. BenRice
    Dude, what paint is that! Looks like it sticks to anything
    Btw - for your idle-catch issues try put a plate in between the BOV & adaptor to see if it's related to that or not. Otherwise the throttle body stop might need a few turns up to let the throttle wheel rest on it
